How powerful is the outlet in the bed?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Tacoma SS, Oct 26, 2015.
  1. Oct 26, 2015 at 4:01 PM
    Tacoma SS
    Tacoma SS [OP] Well-Known Member
    Denver
    Supercharged 09 on 35s
    Boost and flex and 35s
    The back of my truck has a 110V outlet and I'm wondering what the biggest thing you can plug into there is. I have a truck tent and during the winter I was planning on plugging an electric blanket or possibly a space heater into the outlet. Do you think that it is strong enough to power these things? I am also curious about other things like a power drill or small air compressors. Checking to see what other people have plugged in and what has worked.
  2. Oct 26, 2015 at 4:06 PM
    moondeath
    moondeath Well-Known Member
    Pa, Gardners
    2013 TRD Sport DCLB 4x4
    5100 @ 0” w/ 2.5” Eibach spring, 1.5" Icon Progressive 3 leaf + 1” block, Procomp Wheels, Grill Thin Lip (Custom Car Grills Mod), Access Tonneau Cover, Pop & Lock Tailgate Electronic Lock PL8521
    400 Watt is the max power. Look at the wattage usage on the device you plan to use. If it exceeds that, it'll trip.
  3. Oct 26, 2015 at 4:08 PM
    Tacoma SS
    Denver
    For the portable heater I was thinking about getting a remote start system installed in the truck so that in the middle of the night if I get cold I can just start up the truck and have the heater run for a little bit to heat up the tent and then I can turn the truck back off. I thought that was a pretty clever idea but I don't know if it will work the way that it will work in my head haha
  4. Oct 26, 2015 at 4:10 PM
    moondeath
    Pa, Gardners
    You would still need to turn on the inverter inside the truck every time you start it.
  5. Oct 26, 2015 at 4:11 PM
    Tacoma SS
    Denver
    I knew it was too easy...
    ManBeast likes this.
  6. Oct 26, 2015 at 4:13 PM
    Tacoma SS
    Denver
    Why would Toyota even bother putting an outlet in the bed if all you can do with it is charge phones? Bummer
    TxStVanWilder likes this.
  7. Oct 26, 2015 at 4:14 PM
    Tacoma SS
    Denver
    What about a smoke machine? I was thinking about putting a smoke machine in my bed for Halloween :cool:
    Atomic47 likes this.
  8. Oct 26, 2015 at 4:23 PM
    XCDave
    XCDave Well-Known Member
    David
    2015 TRD 4X4 long bed dbl cab
    None at this time.
    Mine wouldn't power a a HD circular saw. I use it for a fan at the track/riding. It's weak.
  9. Oct 26, 2015 at 4:53 PM
    Ostrichsak
    Ostrichsak Don't taze me bro!
    Jer
    Northern Colorado, USA
    Supercharged '10 Tacoma 4x4 TRD
    TRD Supercharger + too much stuff to list. Click sig pic
    Speak for yourself. I bought a pancake compressor from Harbor Freight for like $50 that is low enough amp draw that the bed outlet powers it just fine. Perfect for airing up tires after airing down for a trail.
  10. Oct 26, 2015 at 4:57 PM
    Capt. Obvious
    Capt. Obvious Fearless Keyboard Warrior
    Darrick
    Gig Harbor
    '12 DCLB TRD
    6" body lift, LEDs errwhere, Jesus mural on the hood
    I've used the outlet in bed on numerous occasions to power smaller power tools (drills, reciprocating saws) and flood lights. I don't use it a lot, but it comes in handy when I do use it.
  11. Oct 26, 2015 at 5:02 PM
    Lars
    Lars Radio Active
    Lars
    Cedar Creek, TX
    '10 Tundra TRD RockWarrior
    Yes.
    400w is about 3.6A at 110v - with the truck idling.
    there are a lot of things that will run at 3.6A or under.
    For instance the charger for your DeWalt cordless tools (including impact.)
    With the truck in gear you're looking at 100w which is .9A (round up to 1A)
    The ARB Fridge pulls 72W DC. The AC draw is going to be similar, and as a result the truck's inverter should easily power that even while driving down the road.
  12. Oct 26, 2015 at 5:03 PM
    mred20
    mred20 Well-Known Member
    Garner, NC
    2015 Gray Tacoma Limited
    I used it to plug in a shop vac to vacuum the truck. It worked but seemed a little weaker than if I plugged it in an outlet in the garage. I've also plugged in a box fan and it did fine.
  13. Oct 26, 2015 at 5:13 PM
    muisejt
    muisejt Well-Known Member
    YMM
    08 TRD Sport DC LB
    Katzkin, Bi-xenon Morimoto Mini Stage III Kit (D2S), 4Runner Mirrors, Complete Stereo Upgrade with Backup Camera, Pop&Lock PL5400, Extang Solid Fold Tonneau, TRD OR Tow Hook, rcbs204 4x4 Illuminated Switch, Grillcraft, 10" Rigid light bar behind grill, relocated horns, Redline Tuning hood struts, 5100's with 883 and Wheeler 5 leaf, OME carrier barring drop kit, ECGS Bushing, MarionB2B front hubs
    can always install a more powerful inverter in the bed with a quick disconnect so you can remove it when not needed
  14. Oct 26, 2015 at 5:41 PM
    spp
    spp OC, Kalifornia
    OC California
    And when dealing with motors 746 Watts= 1HP if I remember correctly so a 1/2 hp motor driven device would be no problem.
  15. Oct 26, 2015 at 6:07 PM
    Tacoma SS
    Denver
    I was also planning on getting an inflatable mattress with a built in pump and I was wondering if it would have enough power for the pump
  16. Oct 26, 2015 at 6:14 PM
    Ice Horse
    Ice Horse Stalking horse
    Lauren
    Florida
    Two 1998’s and a 2025. All TRD Offroads.
    ADS Racing Shocks 2.5" Extended Travel Coilovers with Reservoirs, 3 inch All Pro rear suspension kit, factory E-locker, Trail Gear sliders and front stinger bumper, CBI Offroad rear tube bumper, XRC8 Winch, 33 inch BFG KM2's, 16 inch Ivan Stewart Wheels, Uniden CB radio, flip up license plate, white tail lights, LED front signals, Tundra front brake upgrade, new radio, rock lights, sub woofer, remote start, satoshi grille with Prius emblem, Rigid DOT/SAE Fog Lights, 12" Light Bar
    Could always just leave the rear window open and make a tube to the tent and just have the interior heater on full blast and maybe it'll come into the tent if you do that lol. May take a while.
    But what about...a pancake maker?
  17. Oct 26, 2015 at 6:16 PM
    Tacoma SS
    Denver
    And what about my smoke machine!!! Haha
  18. Oct 26, 2015 at 6:18 PM
    08TacoTrD
    08TacoTrD Well-Known Member
    08 TRD Offroad
    I've run a lot of things at once off of it. It's not the most powerful thing but it will run more than a cell phone charger.
  19. Oct 26, 2015 at 6:19 PM
    Ostrichsak
    Jer
    That's your job. No plug-in required!
    Ice Horse[QUOTED] likes this.
  20. Oct 26, 2015 at 6:21 PM
    KB Voodoo
    KB Voodoo Well-Known Member
    Chad
    Glenwood, NY
    www.kbvoodoo.com
    Powerful enough to warrant 27,000 threads asking the same question.
    jmaack and Alfred like this.
