How replace TPS
Discussion in '1st Gen. Tacomas (1995-2004)' started by Luis, Apr 18, 2011.
  1. Apr 18, 2011 at 10:52 PM
    Luis
    Luis [OP] New Member
    Luis
    California
    95 Tacoma sx
    The past weekend I remove the STP to clean it but I put it back wrong or something cause my truck idles at 2000 n it doesnt feel the same
  2. Apr 19, 2011 at 8:29 AM
    DblCabMN
    DblCabMN Well-Known Member
    Mpls, Minnesota
    03 DC TRD/LTD
    Bilstein 5100's all around - Toytec/Eibach 112-620 Coils, Wheelers 5-Pack+Wheelers 2"AAL. 33x10.5x15 KM2s - Siped on Summit Racing 84-5883 rims with 3.750 BS. 4.88s. Demello HD round sliders. Home built full skids. Home built front bumper. Plasti'd badges. Energy Susp. steering rack bushings. Sway bar delete. Deck plate mod. aFe Pro-Dry. Gibson exhaust.
    Take it all apart again, then put it all back together, make sure you have everything lined up right, make sure everything's tight. Make sure nothing is putting stress on the throttle cable... Good luck!
  3. Apr 19, 2011 at 3:55 PM
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    ...too much shit to list.
    I'm guessing you didn't disconnect the battery when you removed the TPS?
    Pull the battery cable.
    Step on your brake for a few seconds.
    Hook back up your battery.
    Drive around the block and see what happens.
  4. Apr 20, 2011 at 4:55 AM
    Luis
    Luis
    California
    95 Tacoma sx
    Thanks alot guys. So buy disconecting the battery it will fix My proble
  5. Apr 20, 2011 at 9:31 PM
    Luis
    Luis
    California
    95 Tacoma sx
    My Tacoma hesitates when I'm taking of on 1st gear. The clutch is so sensitive I got to let out really slow or the truck starts jumping like a chicken with no head. Is there something I could do to fix that or is that normal. Thank u for the advises
  6. Apr 21, 2011 at 8:32 PM
    Buggys3sgte
    Buggys3sgte Well-Known Member
    Psycho state of AZ
    97 BUDGET Taco
    Newly rearranged front end, sick Hurst shifter yo gives it lightning fast shifts, thats it more to come.
    Usually when you pull the TPS off you have to use a multimeter and reset it using the multimeter and watching what it specs out at certain areas. Also what did you clean the TPS with they don't take kindly to carb cleaner or other harsh cleaners.
  7. Apr 21, 2011 at 10:24 PM
    Luis
    Luis
    California
    95 Tacoma sx
    I used throttle cleaner. I think I'm going to take it to a shop Im working 56 hrs a week rightnow got no spair time. Thanks alot
