How;s my possible sub woofer setup?
Discussion in 'Audio & Video' started by Phuket, Jun 28, 2012.
  1. Jun 28, 2012 at 9:33 PM
    Phuket
    Phuket [OP] Well-Known Member
    Travis
    Los Angeles
    03 4X4 TRD
    Eibach/Toytec coils, bilstein 5100's all around, Kenwood DNX7100 Navigation
    I'm thinking about purchasing a 10" sub for my truck and want to put it behind the seat. I have a 1st gen so under is not possible. The subwoofer I want is a pioneer 10" shallow mount TS-SW2501/S4 (4ohms/$100) the amplifier I want is a SoundStorm SSL EV1500M($89)
    and here is the box
    http://caraudiofactory.com/2001-toyota-tacoma-prerunner-p-386.html
    Am I doing this right? I know I need a wiring kit, but a buddy of mine may hook me up with one and install. I'm trying to stay under $450 installed. I want that sub but i'm flexible on the amp.
    EDIT: sorry about the title fuck up lol
  2. Jun 28, 2012 at 10:00 PM
    CUtigerfan
    CUtigerfan Well-Known Member
    South Carolina
    04 Base
    Daystar 1.5" coil spacers, bedlined bumpers, clear corners, aftermarket stereo, 20% tint, half debadged
    Theres no sub in your cart but spend a little more if you need to now. We put a cheap 12" sub in my brothers truck and we ended up pulling it out a year later to put in a JL 12W3. Its such a better sub. I have 2 10W1s sitting in my closet to put in my regular cab at some point. You should be able to get one 10W3 and a good amp for 450 or a little more. Don't buy a good sub and skimp on the amp though. Its just as important if not more. If you need to spend 550 to get what you want do it. $100 more now is nothing compared to redoing it all later because you tried to save a couple bucks
  3. Jun 28, 2012 at 10:46 PM
    Phuket
    Travis
    Los Angeles
    03 4X4 TRD
    when I click it, there is a sub in there. Is the amp ok or is it a crappy one? The sub i want is a 10" pioneer shallow mount
  4. Jun 29, 2012 at 10:09 AM
    Hillingdoner
    Hillingdoner Well-Known Member
    Rio Rancho, NM
    95 LX xtracab 3.4L 4x4 5spd
    140 amp Cadillac alternator, Audio system in progress, 4Runner map light mirror conversion, foot well lamp addition, buckets and console from 99 Tacoma regular cab, big three, tint
    Reason your cart shows up for you is that Sonic popped a cookie on your computer to store your cart info. We don't have that so nothing in the cart when we look.
    Post up model numbers, description and price for what you want.
    Also, what work are you willing/able to do your self?
    What equipment do you have now?
    What is already in the truck?
    What sort of space are you willing to give up?
    Willing to look at factory refurb/used?
    That should get a start and better responses. Lots of good equipment out there depending on extent of what you need and what you already have. All the good equipment in the world can't make up for a bad install/planned box etc. though.
  5. Jun 30, 2012 at 10:37 PM
    Phuket
    Travis
    Los Angeles
    03 4X4 TRD
    I may try to install myself, as far as space goes i'm trying to utilize the space behind my rear seats.
    I currently have a Kenwood DNX7100 for a headuntit with stock door speakers
    The factory refurb is a little sketchy, but i'm trying to get my stuff a little cheaper than retail.
    Looking into amny suggestions as far as wiring kits though.
  6. Jul 1, 2012 at 1:34 PM
    06yfz450ridr
    06yfz450ridr Well-Known Member
    Austin
    CT
    HID's
    I just ordered 2 12" mtx terminators with the box for 156 shipped. 400w rms @2ohm 1200w max . They are decent i heard but what is the rms and max power on the sub? Ive been searching around for an amp now and heard ssl is pretty good for the money. Ssl is actually owned by bOss audio which owns planet audio as well. Just make sure your sub can handle up to 1600 watts and what ohm it runs at so you dOnt kill your amp or sub. Let me know on what you decide as i am throwing one in my 1st gen as well
  7. Jul 1, 2012 at 1:42 PM
    Phuket
    Travis
    Los Angeles
    03 4X4 TRD
    sub can handle 300 watts RMS with a max of 1200 watts RMS. I'm gunna wire the amp and sub at 4 ohms, the amp puts out 600watts RMS at 4ohms. I figured I'd give it a little extra power.
  8. Jul 1, 2012 at 2:58 PM
    06yfz450ridr
    Austin
    CT
    HID's
    I dont think running that much rms is a good idea. Maybe a 100 or so over is ok but not doUble. And also i dont think it its 1200 rms its just max wattage of 1200 but i could be wrong. Do you happen to have amp installed for your speakers? I have all aftermarket speakers and deck but no amp and they dont sound as good as they did in my old car with a stock amp. Bass and all is good but if you can only hear that its not going to be that worth it.
  9. Jul 1, 2012 at 5:07 PM
    Phuket
    Travis
    Los Angeles
    03 4X4 TRD
    my bad i meant 1200 watts max!:eek: Yea my friend installs amps and subs for a living and told me that it'd be fine... 50% of the max rating is ok, 300 is a little low don't you think?
  10. Jul 2, 2012 at 4:00 AM
    06yfz450ridr
    Austin
    CT
    HID's
    Yea it seems a hair low but your better off trying it at around the recommended rms first until they are broken in. It either will handle that much constant power or not or could just sound bad with distortion. Just let them break in first before you bump it up high. Also get some good thick wire for yOur amp youll need it and a capacitor
  11. Jul 2, 2012 at 12:00 PM
    Phuket
    Travis
    Los Angeles
    03 4X4 TRD
    Yea thats exactly what my buddy said, i'll keep the volume down and the gain down for a while then i'll bump it lol
