How Screwed Am I? Ignition Coil wire issue.
Discussion in '4 Cylinder' started by SynysterNate, Dec 30, 2013.
  1. Dec 30, 2013 at 2:46 PM
    SynysterNate
    SynysterNate [OP] Active Member
    Nathan
    Yakima, WA
    05 Speedway Bruised
    TV Screen, 2 10" Subs, 3" Lift, Blacked Badges, Custom USB drive for tunes!
    I am at work and don't have a picture on hand.. But the situation is, I replaced my ignition coil (under the distributor cap) in extremely cold weather. While doing this, the wire running from the positive end to the block snapped. No, I didn't pull too hard, it was just freezing and the damn thing had enough apparently. It goes almost right into the block and is surrounded by a 1/2" of goo (not sure what it is, but solid filler). It broke RIGHT at the filler and I have no way or stripping back wiring and using a butt connector. Any thoughts on how to replace that? I stared for a while, but am beyond pissed at my truck and that was nearly the final straw. My only thought was trying to solder the tiny bit exposed and hope it makes enough contact.
    I cant even google to find anything slightly related, most searches return coil pack issues and spark plugs. I have the 2.7L and am just lost at this point.
  2. Dec 30, 2013 at 5:18 PM
    Fordless
    Fordless Well-Known Member
    Jack
    Central Alabama
    2015 Tundra DC SR5+
    I think a couple of pictures may help
  3. Dec 30, 2013 at 5:23 PM
    Texoma
    Texoma IG: Triple C Chop Shop
    Chris(Topher)
    Lago Vista, TX
    10 Taco 4x4
    A bunch a cool stickers, a bada ass MetalMiller Tx Longhorns grill emblem painted Hemi Orange, JBA long tube headers with o2 sims, Diff breather mod, Red LED interior lights, Fancy head unit that plays ipod n movies, Also DIY install factory stuff like, factory cruise control, factory intermittent wipers, OME nitro struts with 886x springs and toy tec top plate, JBA high caster UCA's for better alignmnet and dey beefier too, Old Man Emu Dakar leaf springs in da rear with the gear, U bolt flipper, Ivan Stewart TRD rims with 33" K Bro 2's, some bad ass weather tech floor liners so I don't muck up my interior, an ATO shackle flipper for mo travel in da rear wit the gear, also super shiny Fox 2.0 shocks back there too, all sorts of steal armor for bouncing off of the rocks like demello sliders, AP front skid, trans skid, n transfer skid, demello gas tank skid, and a tough as nails ARB bumper with warn 8k winch, I'm sure there's more
    You can solder it for a temporary fix maybe, worth a shot til you get a chance to tear it a part.
  4. Jan 1, 2014 at 8:04 AM
    SynysterNate
    Nathan
    Yakima, WA
    05 Speedway Bruised
    Sorry about the delay, I finally got pictures. This is what everything currently looks like. The distributor cap, Rotor and Ignition Coil are all removed. I'm wondering if I cant just run a wire and bypass the whole mess completely??
  5. Jan 1, 2014 at 9:45 AM
    Fordless
    Jack
    Central Alabama
    2015 Tundra DC SR5+
  6. Jan 2, 2014 at 10:45 AM
    SynysterNate
    Nathan
    Yakima, WA
    05 Speedway Bruised
    Awesome! Thank you so much! I might have to look again, but I don't see how the heck to remove the little guy. I'm headed to Toyota to order the part today. I cant wait to have her back on the road!
  7. Jan 3, 2014 at 7:06 AM
    Fordless
    Jack
    Central Alabama
    2015 Tundra DC SR5+
    Although I can't see it in your pictures, based on the parts diagram my guess would be a screw or a bolt on the outside of the distributor housing.
  8. Jan 6, 2014 at 8:50 AM
    SynysterNate
    Nathan
    Yakima, WA
    05 Speedway Bruised
    It was a small screw on the side, it gets about 90% of the way out and wont quite go. Looks like I have to remove a few other things to get to it. I appreciate the help in targeting this! I'm impatiently waiting until the part arrives Wednesday, cant wait to have her back!!
  9. Jan 6, 2014 at 9:26 AM
    Fordless
    Jack
    Central Alabama
    2015 Tundra DC SR5+
    No problem, honestly it's been awhile since I've had to diagnose a distributor problem. It's a whole new world these days. Kinda nice to go back to the days of simple.
  10. Jan 8, 2014 at 2:09 PM
    SynysterNate
    Nathan
    Yakima, WA
    05 Speedway Bruised
    The part finally arrived, the same day snow fell. Ugh. Took a whole 15 minutes and I got it installed and everything back together. The truck is running like a champ, the best it has since owning it. Also figured out my mystery stutter problem, DO NOT order a replacement Ignition Coil off of eBay because its cheap.. Lesson Learned. Thank you again for all the help. Glad to have it back!
  11. Jan 8, 2014 at 6:27 PM
    Fordless
    Jack
    Central Alabama
    2015 Tundra DC SR5+
    No problem, glad we got cha rollin again
