How screwed am I?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by mattski81, Jun 26, 2024.
  1. Jun 26, 2024 at 10:50 AM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    You are not screwed at all.
    Address the axle seal and control arm bushing now.
    Then do the valve cover gaskets next time you do plugs.
    The rear main and front cover are time consuming jobs. Depending on your budget and time, you might push those back until the problem gets "bad".
    b_r_o likes this.
  2. Jun 26, 2024 at 11:06 AM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    I had some trouble with a pesky drivers side rear axle seal too. The lip of the seal was resting in the groove between the sleeve and spacer where the wheel bearing stuff is stacked up on the axle shaft. I had to reposition the axle seal out-board a bit to get the lip on a better surface.
    I found the problem by putting caliper grease on the axle, installing it and then removing and looking to see where the grease got wiped off. That showed where the lip of the seal was resting.
    My understanding is the drivers side axle seal was common for this problem on our trucks
  3. Jun 26, 2024 at 12:34 PM
    54_96
    54_96 Well-Known Member
    Holy crap I'd have to live in another country if I got busted for a valve cover leaking.........
  4. Jun 27, 2024 at 4:51 PM
    mattski81
    mattski81 [OP] Well-Known Member
    BC, Canada
    2007 Tacoma DCLB TRD OR
    Yep, as soon as it stops pissing rain here I intend to jump under the truck and investigate. I am quite sure that the "leaks" they are talking about are so damn slow, it's more like condensation so I will need to verify and check back. Might even go ahead and just do a video with a decent flashlight to document as well. Ill check back in a couple days when the weather gets a bit better.
  5. Jun 28, 2024 at 8:36 AM
    FishaRnekEd
    FishaRnekEd Well-Known Member
    New Orleans, LA
    2005 4.0 6spd 4x4 Dbl Cb short bed
    There are UV dyes for different automotive fluids.
