How sensitive is your accident avoidance/adaptive cruz?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Freeheelbillie, Dec 1, 2021.
  1. Dec 1, 2021 at 2:35 PM
    Freeheelbillie
    Freeheelbillie [OP] Well-Known Member
    Billie
    Saint Clair, MI
    2019 Tacoma SR, DCSB
    FRONT END King Stage 3 3” RR Coil Overs SPC UCA’s REAR END King Stage 3 BAMF Shock Relocation Rear AAL Heavy ARB Universal Diff Breather Kit TIRES & RIMS 16” Method Bronze BFG K02 (315/75/R16) ARMOR Demello Off Road Baja Hoop Front Bumper Main Line Overland Rock Sliders w/ Top Plate ¼” Aluminum RCI Fuel Tank Skid RCI Fuel Tank Straps RCI Rear Diff Skid RCI A-Arm Skids RCI – Front, Transmission, and rear Transfer Case Skid DRIVE LINE YotaWerx, BlackHawk Tune Re Geared w/ Nitro 4.56 Package Front ARB Air Locker Rear ARB Air Locker 8” Reverse Clamshell 3.73 & Down Carrier RECOVERY ComeUp Seal Gen2 9.5RS Winch, Synthetic Line ComeUp Seal Hawse Fairlead ARB On Board Twin Air Compressor LIGHTING Squadron-R Pro Amber Fogs (Wide Cornering) Baja Designs Rock Lights Squadron Sport Fogs (qty 4) Baja Designs Bed Light Kit SPODS, HD 8 Circuit Switch Panel
    My light has been on for a few days...
    Since I have owned the truck anything other than bone dry pavement roads, on a sunny day seems to set it off. It's more temperamental than a high school girl that got dumped on prom night.
    My bumper to bumper runs out in a couple of weeks so if there's an issue I need to take care of it ASAP.
  2. Dec 1, 2021 at 2:36 PM
    RedWings44
    RedWings44 Well-Known Member
    Michigan
    2017 Black TRD Off Road 4x4, 2019 MGM 4Runner SR5
  3. Dec 1, 2021 at 2:38 PM
    mrtonyd
    mrtonyd Well-Known Member
    Tony
    Colorado
    2019 TRD OR DCSB cement
    what light is on?
    mine has popped up with big red letters saying BREAK only 3 times since ive had the truck. only once was it almost a close call, others were me driving aggressive when people are merging.
  4. Dec 1, 2021 at 2:42 PM
    Freeheelbillie
    Billie
    Saint Clair, MI
    The yellow light that shows a "crash" radar unavailable with adaptive cruise.
  5. Dec 1, 2021 at 2:44 PM
    Jerry311SD
    Jerry311SD Well-Known Member
    Jerry
    Ramona Ca SAN DIEGO
    2019 tacoma TRD Quicksand
    KDMaxx tune K&N drop in AFE catback Oil catch can Bill's 6112/5160 Dynomat whole inside of cab TRD skid plate
    Take it in
  6. Dec 1, 2021 at 3:01 PM
    Chew
    Chew Not so well known user
    Chewy
    Midwest
    19 TRD OR
    Amazon dog poo bed mat mod
    Mine works fine, though each time I use the cruise I need to turn down the sensitivity which is a very minor nuisance, as it only takes a second to click to the button twice.
  7. Dec 1, 2021 at 3:06 PM
    Freeheelbillie
    Billie
    Saint Clair, MI
    Taking it in tomorrow...hopefully, the light stays on.
  8. Dec 1, 2021 at 3:06 PM
    MeefZah
    MeefZah -----------
    Mark
    Lexington, Ohio
    2020 GX460
    I've only seen the yellow light a few times, maybe 4 times in 10,000 mi, and in each instance there was snow or mud obstructing it. Mine has worked pretty much flawlessly. Looks like you have a 3" lift though so I wonder if that isn't partially the culprit.
    Chew likes this.
  9. Dec 1, 2021 at 3:10 PM
    Freeheelbillie
    Billie
    Saint Clair, MI
    That has crossed my mind. As in, possibly the eye isn't OEM aligned as it's higher than factor setting. I will say this is an intermittent issue that has gotten worse this fall season. But with over 15k this year the issue hasn't been a real issue.
    Has anyone else with a lift encountered the same issue??
  10. Dec 1, 2021 at 3:14 PM
    MeefZah
    MeefZah -----------
    Mark
    Lexington, Ohio
    2020 GX460
    Plus you got a bull bar thing on your bumper, and lights set up on top of the bumper, right? You have a pic I seen in the SR thread. None of that can be good for the sensor. I have a 1" lift with 32s and like I said mine is pretty much flawless unless something environmental is obstructing the sensor.
    Chew likes this.
  11. Dec 1, 2021 at 3:15 PM
    Freeheelbillie
    Billie
    Saint Clair, MI
    just odd that it’s getting worse…
  12. Dec 1, 2021 at 3:30 PM
    Fatback17
    Fatback17 Masshole
    Billy
    South of Boston, Massachusetts
    2020 TRD Pro MGM
  13. Dec 1, 2021 at 3:45 PM
    Chew
    Chewy
    Midwest
    19 TRD OR
    And an aftermarket grill. I'd expect a lack of warranty help, unless you've already have an established relationship with a mod-friendly dealer.
  14. Dec 1, 2021 at 3:49 PM
    Freeheelbillie
    Billie
    Saint Clair, MI
    Grill has a factory style fitment for the sensor. Again, 15k miles and not really an issue…but seems to be getting worse.
  15. Dec 1, 2021 at 3:57 PM
    Snoman002
    Snoman002 Well-Known Member
    Sno
    21 DCSBORSWMT
    your first post says that since day one it has been sensitive. You cannot say “no issue” and “since day one it’s been sensitive” at the same time.
    it sounds like you DO have issue with it. It may have been very very marginal but not something shifted, or the cover has a chip, or a light moved a mm, or the sun spots are more active but “no issue for 15,000 miles” isn’t true from everything you have said
    Chew likes this.
  16. Dec 1, 2021 at 3:58 PM
    philth
    philth .
    Put some washers on the top screw. Drive around. Light comes on, add a washer. Repeat until light goes away.
    I have like 5 washers on mine. Works perfect.
  17. Dec 1, 2021 at 3:59 PM
    Freeheelbillie
    Billie
    Saint Clair, MI
    Fair enough, I should have said it’s more sensitive. But from day one anything other than perfect driving conditions made it fault out.
  18. Dec 1, 2021 at 4:01 PM
    Snoman002
    Sno
    21 DCSBORSWMT
    yeah, that’s an issue
    you have been having issue since day one so see above comments
    Chew likes this.
  19. Dec 1, 2021 at 4:03 PM
    Freeheelbillie
    Billie
    Saint Clair, MI
    Excellent, I’ll try this for sure!
    philth[QUOTED] likes this.
  20. Dec 1, 2021 at 7:37 PM
    BMH
    BMH Well-Known Member
    Bruce
    Pend Oreille County, WA.
    2020 4x4 SR AC 2.7 liter - Bare Bones Base Model
    Yeah, when I was considering getting a bull bar (Didn't) almost every one I looked at had some sort of 'Warning: May interfere with radar doohickey thing in front' ...
