How should I level the front end 2013 dc
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 20taco12, Nov 14, 2012.
  1. Nov 14, 2012 at 4:32 PM
    20taco12
    20taco12 [OP] Member
    2013 double cab trd sport 4x4 long bed
    tonneau cover, bed mat
    Just wondering whats the best way to level the front end on my 2013 DCLB TRD Sport? Can I just replace the front shocks or do I have to replace shocks and coils. If I have to do shocks and coils how much more would it be to do a 3inch lift. Just getting the ideas going not sure how much I want to spend yet.
  2. Nov 14, 2012 at 4:56 PM
    j753301
    j753301 Active Member
    South Hadley , Mass
    2010 Toyota Tacoma TRD Sport double cab
    I put in a 2" spacer in the front and I have the tsb springs in the rear and it's level and looks good. But I do haul a little so I'm putting a 1" block in the rear soon
  3. Nov 14, 2012 at 5:03 PM
    BradleyScottETC
    BradleyScottETC Class IV Category 8 Elite VIP Member (Only)
    Bradley
    Lake County, FL
    10 4.0 AC 4x4
    Bilstein 5100s set at 2.5" seem to be the fan favorite around here. A good place to comparison shop in my opinion would be
  4. Nov 16, 2012 at 4:16 PM
    20taco12
    Can I do just shocks or do I have to change the uca's also
  5. Nov 16, 2012 at 4:18 PM
    2000GTacoma
    2000GTacoma Well-Known Member
    Snow Hill NC
    00 Tacoma Ext. 3.4L SR5
    for leveling i think you would be okay with just coilovers and stock uca. but i may be wrong im a 1st gen
  6. Nov 16, 2012 at 4:22 PM
    mtwil9
    mtwil9 Well-Known Member
    Birmingham
    12 TRD Off Road 4x4
    Bilstein 5100 F&R Eibach at .85 with top plate spacer, 1.5 AAL,LR UCA's Tinted Windows, Weathertech Floormats, Ultra Gauge, 20" light bar behind grill
    Bilstein and eibachs set at 0. It will have a great ride
  7. Nov 23, 2012 at 6:38 AM
    KFD208
    KFD208 Active Member
    Delaware
    2016 Tacoma TRD Sport
    I used ProComp 2.25" leveling kit in the front of my 2011 DC and 1" blocks in the rear, (1" blocks were recommended by ProComp when I called them). I felt the 1" left the rear end low so I replaced them with 2" ProComp blocks in the rear. I have since had the TSB springs put in which now puts me about 3/4 of an inch higher in the rear than the front.
  8. Nov 26, 2012 at 7:45 AM
    StellerJay
    StellerJay Member
    coastal North Carolina
    '11 TRD Sport 4WD
    17" Pro Comp rims 265/70 Grabber AT2s Factory skid plate Yakima racks
    what are the STOCK billsteins that came on my TRD sport? are they 5100s? are they adjustable???
  9. Nov 26, 2012 at 7:57 AM
    StellerJay
    StellerJay Member
    '11 TRD Sport 4WD
    what's a tsb spring in the rear?
  10. Nov 26, 2012 at 7:58 AM
    Large
    Large Red
    5100s all around and eibach coils.
  11. Nov 26, 2012 at 7:58 AM
    Large
    Large Red
    Dealer removes the 3 leaf pack and installs a similar but poorly manufactured 4 leaf pack. Does not apply if you already have a 4 leaf pack.
  12. Nov 26, 2012 at 7:58 AM
    ntilehman
    ntilehman Well-Known Member
    Seth
    Charlotte, NC
    09 Prerunner Off Road
    Rock Sliders Front Light Bar +1.5" Front Arms with Ext. Kings
    There are a few ways you can do it. Use a 1.5" spacer in the front if you want cheap and effective and leave the rear alone. Use a 2" front spacer and the rear tsb springs if you want a little higher level look. Get a nice coilover in the front if you have the money. That way you can adj the height exactly where you want it. Even can compensate for the driver lean a little bit.
    If you use the Bilsteins set at 1.75" then you are compressing the stock coil springs before they are even being used. This makes the ride a little harsher. Eibach springs with the Bilsteins set at 0" is about a 2.5-3" lift. This will make the front much higher than the back.
    All in all my point is if you want the "perfect" looking level ride height then I would recommend getting some nice coilovers. Radflo, Icon, and King all makes nice kits. I'm pretty sure they are from cheapest to most expensive in that order. If you are not going to be doing a lot of serious wheeling or high speed runs then the Radflo's would work good IMO. You will get your level ride height, a nicer ride, and a much beefier shock. Fox also makes a OEM style coilover.
