how should i lift my taco to fit 285's
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Surfinpig, Sep 30, 2010.
  1. Sep 30, 2010 at 3:57 PM
    Surfinpig
    Surfinpig [OP] Well-Known Member
    Eric
    Philadelphia, PA
    10 2.7 4x4 SR5
    Avid Offroad light bar, trd skid plate, are cap, billy 5100's
    i have a 2010 4x4. i want to fit 285's with out doing anything crazy. im thinking 5100's and a rear leaf. i am adding a cap on the bed and tow my single axle with 2 quads. when my 285's wear out i think ill go down to 265's. any tip would be great thanks.
  2. Sep 30, 2010 at 4:11 PM
    YotaDan
    YotaDan Dan
    Dan
    Oregon
    The parts you suggested should fit the 285s just fine.
  3. Sep 30, 2010 at 4:13 PM
    tacos
    tacos Well-Known Member
    Andrew
    NKY
    05 A/C Off Road 4x4
    BHLM,5100's set 2.5,Toytec 2" aal,FJ TRD wheels,AFE pro-dry, Duratracs
    If your just going to replace the 285s with 265s why not go with the 265s now?
  4. Sep 30, 2010 at 4:14 PM
    1337Taco
    1337Taco Sold all 3
    Kevin
    NorCal
    2012 4x4
    Kings
    Any 3" lift will be able to fit 285s.
  5. Sep 30, 2010 at 4:25 PM
    pojo82
    pojo82 Well-Known Member
    Josh
    NE Wisconsin
    06 TRD double cab
    flowmaster exhaust, URD cold air intake, URD MAF calibrator, Thorley Headers Billy 5100s set to 2.5 lift in front, Billy shocks with add a leaf in the rear Wet Okole seat covers
    I put 5100s and AAL on my 06 and was able to put 285s on with different rims with 4.5 backspacing. i had some rubbing issues with the cab mounts, fender flares, and some plastic molding inside the wheel wells.
    the 9th post on this link shows what needs to be done to the cab mount
    http://www.tacomaworld.com/forum/wheels-tires/115936-rubbing-my-285-75-16-a.html
    after that i just took a dremmel to the fender flares and other plastic molding.
    it took quite a few times of driving up a slope with the wheels turned either way to find all the spots it was rubbing but i didnt want to take off too much. as it is now you pretty much have to have your head right in the wheel well to notice its not any cutting. hope this helped
    by the way these trucks look like they should come stock with 285s
  6. Sep 30, 2010 at 8:16 PM
    Surfinpig
    Eric
    Philadelphia, PA
    10 2.7 4x4 SR5
    i have 4 almost new bridgestone revo 285's off my F250 that i traded for the taco. they cost $1100 new. so ill rock them till its time for new ones. thanks for the replys.
  7. Oct 1, 2010 at 4:43 AM
    757southpaw
    757southpaw Well-Known Member
    Jay
    757
    07' DC LB TRD Sport 4x4
    BAK BakFlip Tonneau cover, 30% front tinted windows, AVS vent shades, Black Billet Grill,Pop& Lock, secondary air filter removed, Goodyear Duratrac's, Billies @ 2.5" on front, Billies on back w/ 1.5" AAL, Toytec Diff drop, NOKYA Hyper Yellow fog light bulbs, LaminX Weathertechs, Rear diff breather mod, BHLM
    Prolly need new wheels for better fitment. Consider offset, etc.!
