how soon did you have to change the air filter on your new truck?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by BSP4x4, Jan 19, 2010.
  1. Jan 19, 2010 at 1:30 PM
    BSP4x4
    BSP4x4 [OP] Guest
  2. Jan 19, 2010 at 1:30 PM
    Rucas
    Rucas 1st gen > 2nd gen
    Lucas
    Northern Colorado
    1st gen. 4x4 MANual
    sparkles, fairys, and happy things.
    around 30k
  3. Jan 19, 2010 at 1:32 PM
    BSP4x4
    BSP4x4 [OP] Guest
    thanks!
  4. Jan 19, 2010 at 1:35 PM
    Rtrn2taco
    Rtrn2taco Nostalgia...
    Philadelphia
    08 DC PreRunner (silver)
    I check mine every oil change. Its all relative to the enviroment the truck is used in, there is no rule of thumb for when one needs to be changed.
  5. Jan 19, 2010 at 1:36 PM
    BSP4x4
    BSP4x4 [OP] Guest
    I'm assuming "i'll know" when to change just by looking...thanks guys!
  6. Jan 19, 2010 at 1:42 PM
    Kyouto42
    Kyouto42 Iron Beard
    Jake
    Ahwatukee, AZ
    BSP '10 4x4 TRD Off-Road DC
    See build thread in signature
    I change them out every oil change, if I'm using replaceable. I recharge ever oil change (5k, k&n drop in) if not more often. However, I am in the desert. The cleaner it is, the better it breaths. That's always a good thing, and they're cheap. Especially if you get an AFE dry... wash it, let it dry, and it's good as new.
  7. Jan 19, 2010 at 1:46 PM
    NWtacoma
    NWtacoma Well-Known Member
    Kent,WA
    2011 TRD Sport 4x4
    265/70/17 bfg AT
    i changed mine around 17K miles. it was dirty as fuck too.
  8. Jan 19, 2010 at 1:48 PM
    Crom
    Crom Outside
    Nick
    San Diego, CA
    2009 4x4 DCSB Overland Build
    Millions
    Exactly. I went through one dust storm in the Yuha desert and mine was done.
  9. Jan 19, 2010 at 1:50 PM
    Rucas
    Lucas
    Northern Colorado
    1st gen. 4x4 MANual
    make sure when you change it you clean out the rectangular box that you took it out of because there could be some dirt and grime in there.
  10. Jan 19, 2010 at 1:51 PM
    Jeff
    Jeff Well-Known Member
    Hopkinton,MA
    Nice 6spd,V6, very solid truck
    None currently, but I would like a better sounding exhaust and perhaps a cold air pack and some color coded step bars
    I had mine done at 15K, it was not to dirty, I use stock Taco or Fram. I live in central Mass. I would like to try the K&N or the wash and dry type. My neighbors who have 04's use k&n all the time.
    I am having the truck serviced for the 30K this week and will have them replace the filter if necessary.
    Jeff , 06, V6, SR5, 6spd.
  11. Jan 19, 2010 at 2:53 PM
    PA452
    PA452 Well-Known Member
    Western PA
    15 Access TRD Offroad, V6, 5spd Auto, 4x4
    I replaced mine at about 43K. It wasn't terrible, but it was definitely time for a change.
  12. Jan 19, 2010 at 3:58 PM
    crittergitter
    crittergitter Proud to be Canadian Navy
    Stu
    Shearwater, NS
    '06 Tacoma 4WD Double Cab
    Bugger, skid plate, colour coded cap, bed mat, AFE Air Filter, Rear diff breather mod, Chirp on door lock;unlock, ABS mod, Weathertechs front and rear, 60" Hi-lift jack, LED light mod in rear bed, 12V accessory in bed, n more stuff.
    I changed mine to an AFE Super Dry the first week I had it. Mind you I got mine used from my Dad. He had it serviced right by the book at the local Toyota dealer. Don't notice any gas mileage increase, but she sounds more like a truck now!!!!
  13. Jan 19, 2010 at 4:31 PM
    vg05
    vg05 Active Member
    2008 Tacoma SR5 AccessCab
    PIAA 400/500MHz Horn, XRain Wipers
    normally around 12k
  14. Jan 20, 2010 at 9:05 AM
    Lurkin
    Lurkin Well-Known Member
    Rod
    Pearland, TX
    09 PreRunner SR5 DC
    If it's just a stock-type paper drop-in, annually.
  15. Jan 20, 2010 at 9:12 AM
    raskal311
    raskal311 Well-Known Member
    S. Cal
    5100 set to max, pending LSD and TRD CAI
    30k but i'll be doing it every 3 oil change since its only about $15.
  16. Jan 20, 2010 at 12:13 PM
    DIRTRIDER
    DIRTRIDER Active Member
    EAST AURORA,NY
    07 WHITE SR5 4X4 V6
    BULL BAR,DRIVING LIGHTS W/ OEM SWITCH,BLACK STOCK WHEELS,265/75/16 TIRES,XM RADIO,EXTRA BED D-RINGS,SPRING TSB,5100'S @ 1.75",FOG LITE MOD, A/C COMP.MOD
    I change mine out once a year, about 10,000mi, with the OEM Toyota filter.
  17. Jan 20, 2010 at 12:42 PM
    aficianado
    aficianado Well-Known Member
    bay area, california
    2006 access cab. 4x4, TRD-OR
    back to bone stock.
    my last truck..chevy. i used stock..went to a K&N drop in, then a CAI..i went back to stock after seeing all the oily, dusty film downstream.
    i change air filters now upon inspection. last time, i followed a pair of 4x4 sportmobile vans, down many miles of dirt road. the crap in my filter was amazing.
  18. Jan 24, 2010 at 9:39 AM
    m303803
    m303803 Member
    Western Mass
    2009 SR5 V6 4x4 Tacoma
    Does anyone have a picture of where the air filter would be on a 2009 V6 and instructions how to change it? I saw the great instructions for changing the 4banger air filter but I Just popped the hood of my taco for the first time since the day i bought it a month ago....thought it would be more obvious!
    I'm a newcomer to working on my truck. Actually It's the first new vehicle I've ever owned! I just moved back home after traveling for work for the past 5 years. My dad is handy and said he'd help me work on it. Tried google etc, no clear cut instructions yet.
  19. Jan 24, 2010 at 9:45 AM
    PA452
    Western PA
    This isn't a Tacoma engine compartment, but your air intake will look the same. Undo the two clips (refer to arrows) and pull back on the assembly to the left. You'll see the old air filter there. Pop it put, wipe out any dirt, dust, or leaves out of there, insert new air filter, pop the assembly back into place and fasten clips.
  20. Nov 20, 2010 at 10:44 AM
    sernv99
    sernv99 Member
    northern VA
    2010 Tacoma TRD Sport
    found where the air filter box is located.....there are two clips towards the front but is there anything holding it in the back? Do I have to unscrew the clamp on the hose?
