How strong is the composite bed?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Scott B., Feb 6, 2015.
  1. Feb 6, 2015 at 7:27 AM
    Scott B.
    Scott B. [OP] Well-Known Member
    Scott
    Georgia
    2015 ACLB SR5 4x4 Expo
    I'm sure this has been asked before, but a quick search did not find answer.
    How strong is the bed to mount things to? I'm not thinking about massive weights, but securing things like on a steel-bed truck. (A Hi-Lift, for instance.)
    I assume it is, just want to verify.
    I also assume a backing plate is good to use, just like on a steel-bed.
  2. Feb 6, 2015 at 7:46 AM
    Wiggins
    Wiggins Well-Known Member
    Jacksonville
    14 MGM DCSB 4x4 TRD OR
    TRD Sport Hood, ICON 3" Lift - 700lb coils, Total Chaos UCAs 5% Tinted Windows Crystal Front Window Film 2.5 resi shocks front and rear, dakar leaf packs Wheelers Bump Stops All-Pro Offroad APEX Front Plate Bumper, PIAA Fog Lights, PIAA Fog Lights, Black Line-X All-Pro Offroad Skid Plates, Black Line-X All-Pro Offroad APEX Rear Plate Bumper, Side Armor for Plate, Hidden Receiver Hitch, Black All-Pro Offroad APEX Sliders,Line-X All-Pro Offroad APEX Pack Rack, Black Line-X, 16" height ScanTool 427201 OBDLink LX Bluetooth Hankook Dynapro ATM 285/75/16 Vision Manx 16"x8" rims, 4.5" Backspacing Warn M8000-s Winch, Factor55 Flatlink, Factor55 1" Hawse Fairlead RIGID Industries Ditch Lights Tractor Supply Bed Box 260amp H.O. Alternator Big 3 Cable Replacement NorthStar AGM34 battery Pelfreybilt Battery Cage Plefreybilt Fuse Plate BlueSea fuse block Kenwood TS-B2000 Short Wave Radio, Remote face, Pack Rack Mounted Antenna Uniden Bearcat CB Cab Mount Chop (BAMF Inserts) TODO: ARB Air System ARB Rear Air Locker w/ 4.88 gears ARB Front Air Locker w/ 4.88 gears HID Retrofit Headlights Rigid Industries RDS-Series 54" Midnight Edition LED Rigid Industries R2-46 Combo Round Light (x2)
    It is plenty strong, when in doubt about what to mount/whether or not to mount... please see the following:
  3. Feb 6, 2015 at 8:24 AM
    KB Voodoo
    KB Voodoo Well-Known Member
    Chad
    Glenwood, NY
    www.kbvoodoo.com
    I wouldn't be drilling holes in it to mount stuff unless you reinforce the composite from the back side with steel.
  4. Feb 6, 2015 at 10:19 AM
    DanceswithWolves
    DanceswithWolves palabra a tu madre
    Jerry
    Roosevelt UT
    13 DCSB OR
    I think they are strong enough for tools and jacks but I wouldn't mount a spare tire. Search site for spare tire issues.
  5. Feb 6, 2015 at 10:30 AM
    neonlazer
    neonlazer Mechanically Goofy
    Lafayette, LA
    '23 DCSB 4x4 SR5
    I mounted my extinguisher with bolts with huge washers on the outside.
  6. Feb 6, 2015 at 10:41 AM
    bjmoose
    bjmoose Bullwinkle J. Moose
    San Jose CA
    '11 Std Cab 4x4 5sp
    I used backing plates or fender washers - just like when I mounted tiedowns by drilling holes in my previous truck's steel bed.
  7. Feb 6, 2015 at 10:45 AM
    Scott B.
    Scott
    Georgia
    Thank you for the replies.
    That is pretty much what I thought.
    On my previous steel bed, I always used either a fender washer or backing plate. I will do the same with this truck.
    I will be building a sleeping platform, and plan to anchor it to the bed in 4 or 6 places. It sounds like as long as I use a backing plate, I will be OK.
  8. Feb 6, 2015 at 10:46 AM
    TacoGlenn
    TacoGlenn Nobody Makes a Monkey Outta Me!
    PNW
    '13 MGMAC 2.7L SR5
    Hellwig 1251's, Leer 122, Kahtec smart stop delay flashing 3rd brake light, de-chromed, de-badged, WeatherTech mats, WeatherTech side window deflectors,
  9. Feb 6, 2015 at 10:48 AM
    Caduceus
    Caduceus Well-Known Member
    in the Bluegrass
    09 DCSB TRD 4x4
    Problem with RTT's is you have to pack up shop whenever you want to move.
    With a platform bed, you can leave it any ole way and move. Plus center of gravity issues.
  10. Feb 6, 2015 at 10:51 AM
    darkfader
    darkfader Will this fit without rubbing?
    Josh
    West Virginia
    2018 DCSB6MTFTMFW
    Quickfist?
  11. Feb 6, 2015 at 11:22 AM
    Scott B.
    Scott
    Georgia
    I have a teardrop - see my sig...
  12. Feb 6, 2015 at 11:52 AM
    Scott B.
    Scott
    Georgia
    Of course, I want to be able to sleep in the back of the truck, too. There are times when I will be without the teardrop...
  13. Feb 6, 2015 at 12:24 PM
    darkfader
    Josh
    West Virginia
    2018 DCSB6MTFTMFW
    :taco::humble::taco:
