How Strong is the Tailgate?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Suprasabre, Jul 8, 2019.
  1. Jul 8, 2019 at 10:07 AM
    Suprasabre
    Suprasabre [OP] SOCal Motorcycle Commuter. Yes, I Split Lanes!
    Bob
    Cedar City Utah
    2016 Tacoma Limited MGM 4x4
    none
    I asked this in an old thread in the Gen 2 (I didn't realize it was 2nd Gen post, until I posted it) but it's what came up when I inquired for "Re-enforced Tailgate"
    I'm thinking of loading up a wrecked ST1300 into the back of my 2016 ShortBed and was wondering what others have done to make sure the tailgate doesn't buckle under the weight of a heavy motorcycle sitting on it? The bike will probably weight about 600 lbs, since it's missing a few parts.
    I'm thinking 3/4" plywood into the bed, then make a piece that will fit over the tailgate too.
    Any thoughts?
  2. Jul 8, 2019 at 10:11 AM
    127.0.0.1 AKA ::1
    /etc/hosts
    2013 NBM AC 4.0 4x4 Auto OR
    yes to the added plywood deck, if you are planning ahead for that much weight in the space of an mc tire footprint, it is a good plan.
    strap it down or bolt it down so it won't slip.
  3. Jul 8, 2019 at 10:20 AM
    Tullie D
    Tullie D Well-Known Member
    Tullie
    Wilson, NC
    2019 SR5 V6 SSM Access Cab
    Reminds me of this:
    https://www.youtube.com/watch?v=xMjxOD1lJq0
    tonered likes this.
  4. Jul 8, 2019 at 10:39 AM
    Tacoma3rdGen
    Tacoma3rdGen Well-Known Member
    New Mexico
    2018 Tacoma Limited
    Make just one piece that will fit over the entire area carrying the weight... above appears like two separate wood pieces (not as effective in weight distribution).
    DanoT and kahanabob like this.
  5. Jul 8, 2019 at 10:47 AM
    Suprasabre
    Bob
    Cedar City Utah
    none
    I was thinking two pieces since I need to drive 500 miles up to go pick up the bike.
    Maybe a 2x2 and add to the tailgate piece, and place between the tailgate and bed.
  6. Jul 8, 2019 at 10:49 AM
    Tocamo
    Tocamo .
    Ottawa
    Bug-out vehicle
    I believe the manual will tell all......
  7. Jul 8, 2019 at 10:52 AM
    Suprasabre
    Bob
    Cedar City Utah
    none
    Tullie D[QUOTED] likes this.
  8. Jul 8, 2019 at 10:54 AM
    Suprasabre
    Bob
    Cedar City Utah
    none
    :rofl::rofl::rofl:
    I wouldn't trust the manual on that! :crapstorm:
  9. Jul 8, 2019 at 11:05 AM
    cruxofthebisquit
    cruxofthebisquit Well-Known Member
    Orange Texas
    2000 TRD
    OME and worth every penny.
    Most weight will be on front even of a ST. Prob. 200#'s at most on rear tire. As long as cords are in good shape no worries.
    jmneill likes this.
  10. Jul 8, 2019 at 11:09 AM
    wood714
    wood714 Got any Quaaludes?
    Kevin
    East Coast Florida
    2018 4x4 V6 SR5
    I thought about having something like this made that would sit just a fraction of an inch above my tail gate. Then using a 8' piece of 3/4" plywood in the bed. There shouldn't be any weight on the tailgate then.
    I wanted to haul my bike from FL to Cincinnati and back later this summer.
    Then I thought about loading the bike...plywood would raise up during loading. Seeing how my bike is right at 8 foot long and weighing in close to 900 pounds...a trailer would be a lot better option.
    Tullie D likes this.
  11. Jul 8, 2019 at 11:20 AM
    Tacoma3rdGen
    New Mexico
    2018 Tacoma Limited
    Recommend you drive up with the tailgate down, using a single piece. The 2nd piece (on the tailgate only), will distribute weight across the tailgate however do nothing to relieve pressure on the cables as the weight would be the same (plus the wood). By using a single piece, some of the weight would be distributed to the main bed, and will reduce the load (static and bounce) applied to the tailgate.
  12. Jul 8, 2019 at 11:26 AM
    Sgt.Tee
    Sgt.Tee Well-Known Member
    Pete
    NE Pa
    2019 MGM SR Tacoma 4&4
  13. Jul 8, 2019 at 11:45 AM
    Sgt.Tee
    Pete
    NE Pa
    I been reading about this because I needed this info. Most suggest removing the tail gate, some are using a sheet of plywood.
    Myself I am removing mine if I must
    I also bought a utility trailer for my quad,so you can go that way also. Mine has a drop down ramp and I paid 500 bucks for mine. If you have a hitch, this is your best bet. Look on Craig’s list, I see them all the time for sale, good luck
  14. Jul 8, 2019 at 11:56 AM
    Tullie D
    Tullie
    Wilson, NC
    A trailer is the best way to go.
    Sgt.Tee likes this.
  15. Jul 8, 2019 at 11:59 AM
    Sgt.Tee
    Pete
    NE Pa
    Rent a trailer if you do not have one, I would let you use mine
  16. Jul 8, 2019 at 11:59 AM
    Tullie D
    Tullie
    Wilson, NC
    Heck, I've got one that I used to play wìth! :thumbsup:
  17. Jul 8, 2019 at 12:49 PM
    Suprasabre
    Bob
    Cedar City Utah
    none
    Okay, after reading the other thread posts and all, I guess my best bet would be to use my trailer. I just hate hauling it up 500 miles...
  18. Jul 8, 2019 at 12:59 PM
    ShirtTucker
    ShirtTucker Taco Tip Line: 248-434-5508
    2017 V6 Sport AC MT
    Lots-o-stuff
    You'll be fine without it. I was really worried about loading up a GS into the truck, because I've seen how flimsy the supports inside the tailgate are, but
    in the end, I didn't need to worry. The thing about that piece of plywood on the tailgate is that it can possibly go flying backwards if it's not secured properly.
  19. Jul 8, 2019 at 1:13 PM
    Sgt.Tee
    Pete
    NE Pa
    Good for you, this way you have peace of mind and no regrets
    Suprasabre[OP] likes this.
  20. Jul 8, 2019 at 1:16 PM
    tomwil
    tomwil Well-Known Member
    East Coast USA
    2014 Reg Cab 4x4
    You can do the chain support mod to relieve the tension on the cables.
    Sgt.Tee and Suprasabre[OP] like this.
