How the heck do i get this bed bolt out....or in...or anything!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TacomaPrime, Dec 31, 2011.
  1. Dec 31, 2011 at 3:12 PM
    TacomaPrime
    TacomaPrime [OP] Cybertronian Tacoma
    Greg
    Illinois
    05 Prerunner SR5 TRD off road
    Put in 3 d rings in 3 of my bed bolts today, but this 4th little bastard. Grrr.
    Had to use the impact gun on him, and he came out this far, and stopped. The bolt doesn't spin. Won't come out anymore, and won't go back in either. Already doused him in an entire bottle of pb blaster. I was gonna take it to a buddies house and try an air impact gun, but was hoping maybe you guys had some other advice too.
  2. Dec 31, 2011 at 3:15 PM
    jackhart
    jackhart Well-Known Member
    11 DCLB
    can you heat it from below (assuming you are not near the gas tank)?
    sometimes pb blaster has to soak for a day or so to be effective. i'd hit it with more of that stuff and give it time to work in.
  3. Dec 31, 2011 at 3:16 PM
    wildjerseyfirefighter
    wildjerseyfirefighter I sell fishing and fishing accessories
    Joe
    NJ
    05 Tacoma TRD Sport
    stock, for now
    The nut underneath isnt spinning is it?
  4. Dec 31, 2011 at 3:24 PM
    TacomaPrime
    Greg
    Illinois
    I think we were gonna try that tomorrow too, heating it up I mean.
  5. Dec 31, 2011 at 3:28 PM
    TacomaPrime
    Greg
    Illinois
    i can't imagine it is. Isn't is welded to the frame? Besides, the bolt isn't spinning either. It won't budge.
  6. Dec 31, 2011 at 4:18 PM
    JKD
    JKD Well-Known Member
    Die grind two flats on the bolt head and use whatever size wrench it takes.
    Buy new bolt...install with anti-sieze.
    Be prepared to weld the nut back on the frame if necessary.
  7. Dec 31, 2011 at 4:21 PM
    samsung
    samsung Well-Known Member
    George
    Sugar Land, Texas
    2011 PreRunner doublecab TRD Offroad
    undercover lid/Ipod integration kit/Pop n lock/bed rug, fumoto drain valve, full piping Wet Okole covers, Blacked out badges, Lamin-X fog light cover yellow, window tint, ARB deluxe bumper with fog light kit,DSM UCA'S,3 support shrockworks sliders,complete OME lift with 886X coil and dakar leaf spring with 3 degree axle shims and center pin lenghtener,warn VR10000 winch,amsteele blue synthetic rope, daystar winch isolator, daystar delrin rollers, IPF 900xs Extreme Driving H9 Kit 900XSD (900XSD),Horn on fire with shot Penning,
    sawzaw !!!
  8. Dec 31, 2011 at 4:26 PM
    jflan
    jflan Well-Known Member
    Vancouver, WA
    09 Access 4x4 2.7L manual SR5
    SnugTop SuperSport Sportsman keyless cap Weathertech mats - OEM skidplate - OEM hitch
    :confused:
    I saw Esaw swingin' on a sawzaw ?
    Cut the two flats and work it back and forth like a it was a tap.
    With a BFW.....big fukkin wrench.
  9. Dec 31, 2011 at 4:26 PM
    TacomaPrime
    Greg
    Illinois
    sorry, i'm retarded. what does "die grind two flats" mean?
    And if the nut has to be welded back onto the frame, I will have to have someone do that. I don't know how to weld.
  10. Dec 31, 2011 at 4:52 PM
    lj973gm
    lj973gm Sold it, dont miss it yet.
    Ohio
    06 DCSB 4wd
    I had the torx on mine strip out, the star pattern in the head was pretty soft if you ask me. I got it out about as far as yours before it stripped the head.
    I live in chicago the land of salt in the winter (rust) so I let it sit for a day with penetrating oil (spray from top and bottom) and then went at it the brute force way since the bolt was toast anyways. I used a 18" pipe wrench. Toss it on the large diameter of the head and give it hell.
    Bolts are about 8 bucks at the dealer.
  11. Dec 31, 2011 at 4:54 PM
    Scalded_Dawg
    Scalded_Dawg Not as new as my post count would appear
    Brent
    Yorktown, VA
    Stripped Steel and Sex Appeal
    Tacoma daily and 4Runner to play
    Loosen all the other bolts... It may just be bound up. ??
    If the bolt threads are jacked up when you do get it out, I would replace the nut as well as the bolt.
    If you can access the nut to replace it, welding probably will not be required - so long as you put some thread lock (Loc-Tite) on the bolt upon install.
    Edit -- "die grind two flats" means to flatten out opposing sides of the round bolt head, making it easy to put a pipe wrench or large vise grips on it for turning.
  12. Dec 31, 2011 at 5:02 PM
    jflan
    Vancouver, WA
    OK, the bolt head is round, right ?
    You are attacking it with a Torx bit and probably (guessing) a battery impact driver, right ?
    It doesn't have enough balls to back the thing out, capiche ?
    So it was suggested that you take a die grinder (Dremel for example) or a peanut grinder (4" angle grinder) and grind (cut) two oppsing "flats" on the bolt head so that a wrench can bite on it and allow you to deliver more torque to the bolt.
    This bolt on the bottom side is probably exposed to road grit, salt, etc and when you try to back them out, they bind when the crap hits the threads in the captive nut.
    Hey, if this sh!t was easy we could get a hamburger flipper to do it ;)
    Now go earn yer money :p
  13. Dec 31, 2011 at 5:08 PM
    oneBIGroom
    oneBIGroom SSS
    SSS
    SSS
    SSS
    SSS
    What size impact did you use, 3/8" or 1/2"?
  14. Dec 31, 2011 at 5:09 PM
    jflan
    Vancouver, WA
    No, don't replace the nut unless unless a tap won't clean it up.
    If a new bolt hangs up in it, stop and "chase" the threads clean with a tap of the correct size.
    No, don't put and LokTite on these !
    Correct.
    You could also get a pipe wrench to bite on it without any grinding.
    Either way, and you will have to trash the bolt if the Torx bit and impact can't handle it.
  15. Dec 31, 2011 at 5:14 PM
    TacomaPrime
    Greg
    Illinois
    i tried it with the electric impact gun, and actually broke my impact gun. the bolt head and the torx bit I was using was actually smoking from getting so hot from trying to get it off for so long.
  16. Dec 31, 2011 at 5:16 PM
    TacomaPrime
    Greg
    Illinois
    i put anti seize on the 3 other bolts so that they are easier to get out in the future.
  17. Dec 31, 2011 at 5:16 PM
    TacomaPrime
    Greg
    Illinois
    1/2"
  18. Dec 31, 2011 at 5:19 PM
    TacomaPrime
    Greg
    Illinois
    I'm assuming that once I get the bolt out, it's ok to drive around without a bolt there till I can buy a new one at the dealer?
  19. Dec 31, 2011 at 5:24 PM
    jflan
    Vancouver, WA
    Bingo !
    A guy could even put a dab of grease on the exposed threads underneath.
    Old concrete form builder's trick....nothin' sticks to grease.
  20. Dec 31, 2011 at 5:25 PM
    joes06tacoma
    Joe
    Central Coast, CA
    Get a big ass breaker bar. Sometimes an impact won't move it, but a breaker bar will. It might snap off, it might come right out. At this point it does not look like you have a choice.
