How the iForce MAX system works (Toyota video)
Discussion in '4th Gen. Tacomas (2024+)' started by stevesnj, Aug 1, 2023.
  1. Aug 1, 2023 at 4:25 PM
    stevesnj
    stevesnj [OP] Well-Known Member
    South Jersey/Philly Area
    1996 Land Cruiser 80 Series
  2. Aug 2, 2023 at 11:16 AM
    johnnyquad
    johnnyquad Well-Known Member
    4.7 4runner
    Thanks for posting this!
    stevesnj[OP] likes this.
  3. Aug 2, 2023 at 11:23 AM
    tmac5809
    tmac5809 Well-Known Member
    Hoping someone can do a more technical explanation, ie when the electric motor engages, how long can the motor sustain the rated power output, etc.
    JDKred and 805 Tacoma Tuning like this.
  4. Aug 2, 2023 at 12:10 PM
    stevesnj
    There was another Toyota video explaining that if I remember correctly. You can run the battery low but the computer will use the engine that runs the generator to recharge (keep charged) the battery. So in effect the battery is always being charged.
    tmac5809[QUOTED] likes this.
  5. Aug 2, 2023 at 6:54 PM
    805 Tacoma Tuning
    805 Tacoma Tuning YotaWerx Authorized Tuner | Ventura County, Ca.
    Tom
    Ventura County
    2020 TRD OFF ROAD DCLB
    That was a well laid out video to help better understand that system. Thank you for sharing.
    stevesnj[QUOTED][OP] likes this.
  6. Aug 16, 2023 at 7:28 PM
    DukeofArmchair
    DukeofArmchair Member
    Josh
    This has been a question I have also, so based on this effectively the truck should have full hybrid power available 100% of the time?
  7. Aug 17, 2023 at 3:01 PM
    OpeCity
    OpeCity Well-Known Member
    Long Beach, CA
    Even if it isn’t, I can’t think of a time you’d use max rated power output for an extended period. Even towing my boat up the actual hill the cooling systems are rated on (highway 68 in AZ), I can’t ever recall just not downshifting and using part throttle.
    That said, based on the battery size (1.87kwh), a 48hp motor would run at full output for about 3 mins to deplete it.
  8. Aug 17, 2023 at 3:13 PM
    DukeofArmchair
    Josh
    Living in Colorado I can see pulling a trailer even a smaller trailer over some of the 10000' passes would take all the power of the 4cyl plus some. I am not very familiar with these Hybrids and how they fully work. From the reading I have done the Wrangler 4Xe even when the battery shows depleted (not Sure if it actually goes to 0% I believe it goes to 1%) it seems to have full power.
    ItalynStylion likes this.
  9. Aug 17, 2023 at 3:24 PM
    OpeCity
    Long Beach, CA
    Does this happen with all the power of the v6 now? Do people pull trailers at 6000rpm for extended periods?
    even without the hybrid system, the 4cyl makes the same horsepower as the current v6 if so. And at 10000ft, it will make VASTLY more.
  10. Aug 17, 2023 at 4:54 PM
    stevesnj
    There is always charge in the battery for the motor assist from what I understand. It's always being charged since it's an electric motor/generator.
  11. Aug 17, 2023 at 4:59 PM
    OpeCity
    Long Beach, CA
    If the electric motor is capable of constantly producing the 48hp, it’s also taking 48hp to run from the ICE side.
    So theoretically, if you’re foot to the floor open asking for every ounce of power, eventually the electric motor won’t give you anything it doesn’t take away from the ICE. But that almost never happens
  12. Aug 17, 2023 at 5:03 PM
    stevesnj
    Well it works. That's all that matters :)
  13. Aug 17, 2023 at 5:06 PM
    OpeCity
    Long Beach, CA
    Yeah I think extremely few people are going to seriously ask for 326hp constantly for 3+ mins at a time
  14. Aug 21, 2023 at 7:33 AM
    snudley
    snudley Well-Known Member
    Timothy
    Austin, TX
    2018 TRDORDCLB
    Will it give better mileage while towing? My Gen 3 V6 takes a big hit when pulling my 2000 lb camper.
  15. Aug 21, 2023 at 7:38 AM
    stevesnj
    Dunno, the Tundra guys should know since it's been a few years in that truck.
    shakerhood likes this.
  16. Aug 21, 2023 at 8:20 AM
    OpeCity
    Long Beach, CA
    Most likely will, especially in areas with hills and lots of throttle changes
  17. Aug 21, 2023 at 11:39 AM
    Kamille.bidan
    Kamille.bidan Well-Known Member
    2017 Blue TRD OR MT
    I’m not a physicist for sure, but what would be the point of a hybrid system then?
    I thought electric motors are more efficient?
    If what you’re saying is true, then hybrids would t produce more efficiency?
    honestly, I don’t get it either way.
  18. Aug 21, 2023 at 11:41 AM
    ItalynStylion
    ItalynStylion Sounds Gooooood
    Steven
    DFW, Tx.
    09 Double Cab TRD Sport 4x4
    I think the reality is the hybrid setup (and turbo motor) are a huge step forward in a lot of ways. It will cover a the overwhelming majority of use cases. That being said, there is no "perfect" drive train that meets ALL needs.
    However, the use case presented above in @DukeofArmchair 's post (towing a 6k trailer up over a mountain pass, like Monarch) is a very real use case. Already, I can tell you my NA 4.0 V6 absolutely suuuuuuuucks up there. I say up there because in addition to the grade of the slope making it difficult, the altitude absolutely neuters the power created by an NA engine. Output is close to being cut in half. If you've driven high elevation mountain passes you know what I'm talking about. And yes, it takes more than 3 minutes to get up some of these. Hell, you might have the engine pegged at 5000rpm for 15 or more minutes if you're pulling something, loaded down, big tires, or all three.
    But the turbo engines don't lose nearly as much power at altitude as an NA engine would. So even just having the turbo 4 cylinder without the hybrid tech will be an improvement for altitude. The hybrid stuff will just help everywhere else. :)
  19. Aug 21, 2023 at 12:33 PM
    OpeCity
    Long Beach, CA
    The hybrid is more efficient because it can recharge when the ICE engine is making power more efficiently, and deliver it during times of less efficiency. Think low RPM from a dead stop.
    that said, this hybrid system is designed for performance, not efficiency.
  20. Aug 21, 2023 at 12:35 PM
    Kamille.bidan
    2017 Blue TRD OR MT
    got it.
    I wonder if the 27 MPG was just a typo on Toyotas part. I know they removed that now for the Land Cruiser.
