How To: 2001 1st Gen Aftermarket CD Player Install
Discussion in 'Audio & Video' started by zacharypaul89, Nov 21, 2013.
  1. Jun 15, 2015 at 5:58 PM
    zacharypaul89
    zacharypaul89 [OP] Eat right, be fit, die anyway
    Zach
    Georgia
    2019 Quicksand Trd Offroad
    It only choked out once and that was when I gave it gas. After that, it just idled at around 500 RPMs and sputtered. I drove about 5-6 miles and it seemed to be fine. After reading your post, I went and double checked and my resting RPMs were about 700-800, so I think everything is fine. I guess it just took a while for the ECU to reset
  2. Jun 15, 2015 at 6:54 PM
    frizzman
    frizzman Well-Known Member
    Pittsburgh, PA
    04 XCab 4x4 TRD/OR
    OME 2.5,Tundra 17s,Falken Wildpeak AT3W hitch w/ 7-pin, ARE cap, JVC HU w/BT, HID/LED lights
    nice, glad it's working. I'm still trying to figure mine out :p
    been trying to get my uncle to scan it with his Snap-On scanner to see if I messed with the TPS when I manually moved the plate :(
  3. Jun 16, 2015 at 5:43 AM
    zacharypaul89
    Zach
    Georgia
    What plate did you move? If you go to Advanced Auto, they'll scan it for free.
  4. Jun 16, 2015 at 10:04 AM
    frizzman
    Pittsburgh, PA
    04 XCab 4x4 TRD/OR
    the butterfly plate. since I have the ECTS 03+ TB it's more sensitive I'm guessing.
    I've used their scanner before and it's ok for trouble codes but more in depth with voltages and detailed reports.
  5. Jun 16, 2015 at 10:20 AM
    zacharypaul89
    Zach
    Georgia
    What's a butterfly plate? Also, what is the ECTS 03+ TB? :notsure:
  6. Jun 16, 2015 at 10:29 AM
    frizzman
    Pittsburgh, PA
    04 XCab 4x4 TRD/OR
    03+ had an electronic throttle assist instead of the IAC piece. and i mixed two letters, ETCS (Electronic Throttle Control System). The butterfly plate is the round disc inside the TB, aka flap, and w/e else people call it. It's connected to a motor/gear at the rear of the TB housing that is our cruise control (no 3 cables over the TB, just one) I'm at work otherwise I would spend time looking up my old posts on it
  7. Jun 16, 2015 at 11:26 AM
    zacharypaul89
    Zach
    Georgia
    No need...I was just curious. You had to deal with all that for a cd player install?
  8. Jun 16, 2015 at 9:07 PM
    frizzman
    Pittsburgh, PA
    04 XCab 4x4 TRD/OR
    uh, no. I was just referring to the ECU reset and now yours works ok.....off topic
  9. Jun 17, 2015 at 4:05 AM
    zacharypaul89
    Zach
    Georgia
    Oh, okay
  10. Oct 30, 2018 at 12:38 PM
    Thedude423
    Thedude423 New Member
    Matthew
    2003 Tacoma TRD
    Great write up!!! Thanks for taking the time to make it
