How to 2WD in winter?!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by phayes, Feb 4, 2021.
  1. Feb 4, 2021 at 5:29 PM
    EricL
    EricL Tomahawk Chopper
    Greenwood, SC
    2015 Slowmobile
    SOS Offroad Concepts Armor
    Take it out of 4WD. You will be in 2WD. Problem solved. :thumbsup:
    Err, just saw you have a Prerunner, so NM.
    suaveflooder likes this.
  2. Feb 4, 2021 at 5:35 PM
    tacotacoburrito190
    tacotacoburrito190 Member
    Jacob
    Denver
    This ^ have driven my crown vic (v8 rwd) with no issues for many years with sand in the trunk and winter tires. Have driven through 12 inches of snow.
    I also notice most vehicles that end up in ditches in the snow are awd/4x4 since they get cocky, while rwd are forced to be humble or they slide easily.
    suaveflooder and phayes[OP] like this.
  3. Feb 4, 2021 at 5:38 PM
    avi8or_co
    avi8or_co Well-Known Member
    2022 Lunar Rock TRD Sport
    Move down here to FL... same tires work fine all year, put it in drive, and....well.... just drive.
    DavesTaco68 and suaveflooder like this.
  4. Feb 4, 2021 at 5:43 PM
    Sprig
    Sprig Well-Known Member
    Ken
    N. Calif. The Twilight Zone
    Tacoma TRD double cab 4x4, Barcelona Red
    The ultimate answer is to get a 4x4. Over the last 40 years all my many trucks have been 4x4. Prior I had a 2wd Ford. I got stuck in mud, snow, gravel, everywhere. Since I actually use 4wd and have a need for it I never bought another 2WD truck again. Tires will help you, weight in the back and chains will help but the ultimate solution is a 4wd. You may still get stuck but less likely.
  5. Feb 4, 2021 at 5:53 PM
    $yoda$
    $yoda$ Well-Known Member
    Tom
    2007 Tacoma 4.0
    2.5 inch lift, 285/75r16s, upgraded stereo system, Magnuson mp90 supercharger system.
    I respectfully disagree. Chains are great for deep stuff but not for daily driving on plowed roads. They make studded snow tires for a reason. This is the reason.
    xxTacocaTxx, ABNFDC and suaveflooder like this.
  6. Feb 4, 2021 at 6:09 PM
    suaveflooder
    suaveflooder Well-Known Member
    2021 4Runner Venture
    for what you mentioned, I agree 100%
    there are a ton of two wheel drive trucks and cars that do just fine in the snow. Mud/Sand is a different animal.
    Can it be done?? Absolutely, but a 4WD is very convenient then (and tires obviously)
  7. Feb 4, 2021 at 6:26 PM
    Sprig
    Ken
    Studded snow tires on a 4x4 will get you much better traction than a 2WD with stud tires. Same applies to chains. You can greatly improve traction on 2WD with proper equipment but it just won’t match 4wd with proper tires, chains or whatever. And if your 4wd has front and rear limited slip you’ve way more traction than 2WD. I’m not sure if the pi has auto limited slip which means open differential and one wheel drive unless you lock the rear end. In California going over the Sierras when chains are required, 2WD must chain up. 4WD as long as you have m/s tires , no chains, you are good to go.
    MattCowsmasher and ABNFDC like this.
  8. Feb 4, 2021 at 6:29 PM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    Maybe the shocks are toast
  9. Feb 4, 2021 at 6:31 PM
    kss86
    kss86 Well-Known Member
    Downingtown PA
    2021 Tacoma SR5 DblCab Long Bed, Cement
    Def should have went with 4wd if you planned on going in snow frequently. I got 4wd and just drove through ~7inch of snow no issues at all....
    but, other than that, winter tires and weigh in the bed.... like 500lbs of sandbags are pretty cheap from home depot... but otherwise, yea sell that thing and get 4wd
    ABNFDC likes this.
  10. Feb 4, 2021 at 6:39 PM
    ABNFDC
    ABNFDC Well-Known Member
    Granite State
    2008 4WD Access Cab TRD OR "Rugged Trail"
    265/75/16 Wildpeaks, Dakar rear, HS 2.5" front coils
    Weight in bed, good tires, less skinny pedal, that's about it for 2WD. I drove 2WD as a kid in high school as that was all I could afford-never again.
    That whole "pre runner" shit needs to stay in the south west.
    Sprig and suaveflooder like this.
  11. Feb 4, 2021 at 6:47 PM
    Bishop84
    Bishop84 Well-Known Member
    Better tires, 25psi, more weight in rear, always make sure tank is 1/2 or higher.
    TnShooter likes this.
  12. Feb 4, 2021 at 8:02 PM
    $yoda$
    Tom
    2007 Tacoma 4.0
    I agree but a 2wd is what he’s got to work with. I mean tracks will work better then a 4x4 but he doesn’t have those either so it’s kinda pointless. With the right set up and a bit of common sense a 2wd can do pretty good in most conditions.
    xxTacocaTxx and Sprig[QUOTED] like this.
  13. Feb 4, 2021 at 8:09 PM
    ABA180
    ABA180 It burns when I pee....
    East Bridgewater MA
    Pioneer CD, Megaloud/JBL amps, Rockford/Polk speakers.
    Perhaps that's part of it, I have a 10 so mine has the Auto LSD
  14. Feb 5, 2021 at 7:10 AM
    coopcooper
    coopcooper certified youtube mechanic
    alberta canada
    black on black on black 05 trd off road
    stickers and sticker accessory's
    open diffs are quite literally useless. My lexus was better than my truck in the winter just for the fact that it had an lsd. If i didn't have 4wd ide be taking the bus to work.
  15. Feb 5, 2021 at 8:03 AM
    #35
    ABNFDC
    Granite State
    eh, maybe not useless, but then I have never driven a vehicle with LSD. They do leave a lot to be desired though. I live down a dirt road, and if it wasn't for 4WD, I wouldn't be able to make it to the house easily in the winter.
  16. Feb 5, 2021 at 10:00 AM
    #36
    tak1313
    tak1313 Well-Known Member
    2013 Base 2WD
    For about 15 years now I've had 3 pickups here in NH, and they've all been 2WD (I have never owned a 4wd/awd vehicle in my life - never needed them in my prior life in Hawaii). I've even had 2 rwd bmws in the past too. The only thing I've ever done is put weight as needed until about 6 years ago when I also started also using winter tires.
    For my pickups, I make a simple bracket out of treated lumber that keeps the weight centered over the rear axle. I used to use sand, but for the last 4 years have switched to 4x8x16 concrete blocks from the big box store. They're about 30 lbs each, MUCH easier to handle (because they're not floppy), and can be arranged neatly in the bed.
    I am able to arrange 7 blocks nicely in one layer (about 210 lbs), and for occasions when I feel the need for more weight, I throw an all season tire/wheel in there too.
    Weight is absolutely necessary because pickups have no weight over the axle otherwise. Winter tires (along with the weight) makes a huge difference and is an absolute necessity to me now that I've used them.
    Larzzzz, davidstacoma and EdgemanVA like this.
  17. Feb 5, 2021 at 10:07 AM
    #37
    Rick's 2012
    Rick's 2012 Well-Known Member
    Rick
    Costa Rica
    2012 Double Cab 4x4 Grey with leather
    Stock
    I had dedicated winter tires on cheap rims. Made all the difference in the world.
    vtown and EdgemanVA like this.
  18. Feb 5, 2021 at 10:14 AM
    #38
    Knute
    Knute Well-Known Member
    '06 4.0L Tacoma TRD Sport
    Stock, 4WD, Access Cab, White,
    FWIW, 2WD is not crippled in the winter.
    Many people live in the prairie states with bad road conditions from Nov-March as a normal circumstance. Everyone does not have a 4WD or AWD vehicle.
    Studded tires and chains will be subject to your state laws. Many states do not allow studded tires or chains on the roads. So, check your state laws before you open your wallet for these aids.
    Take your truck to a snow covered, snow pack, iced over empty parking lot. Learn how to start, stop, corner, slide, recover, power slide ........ do donuts...play with the truck. You will be learning how to handle the truck in less than ideal conditions without placing others in jeopardy.
    IMHO, 4wd is a help in snow. Not so good on snow pack. No better than 2wd on ice. Frankly, I prefer 2wd on snow pack and ice. I have better control. When in 4wd, the truck will tend to crab sideways, not really going where its pointed.
    davidstacoma and kss86 like this.
  19. Feb 5, 2021 at 6:22 PM
    #39
    JSB10
    JSB10 Well-Known Member
    2005 Tacoma
    I moved to an area years back that got lots of snow. I had seen bad roads before but not the hilly ups and downs. I started working with a guy that drove a chevy suburban work truck with only weight in the back and studded tires. That thing would go anywhere. Needless to say I never shut my eyes on the way to work. We never had a problem though. If i had a 2wd tacoma i would try studded tires and weight in the bed.
  20. Feb 5, 2021 at 6:38 PM
    #40
    avw4x4
    avw4x4 Well-Hung Member
    (M)Andrew
    Rochester, NY
    2003 Yota
    ...loading....
    Any chance it has a unicorn sticker on the tailgate?
