How-To: 6-Speed Manual Transmission Oil Change
Discussion in '2nd Gen. Tacomas (2005-2015)' started by tamer, Jul 22, 2013.
  1. Mar 11, 2014 at 11:07 AM
    Rupp1
    Rupp1 "If you can dodge a wrench, you can dodge a ball."
    NC
    2024 Nissan Titan Pro4X
    Last time I did mine, I made a pretty good mess, even using a pump that I bought with my MT-90. I wonder if you could drain, then take off the console and shifter boot and fill with a funnel and some poly tubing? Mine is due soon, I'll see if it can be done.
  2. Jun 11, 2014 at 5:57 AM
    F75gunslinger
    F75gunslinger Ka like a wheel
    Christian
    Rochester,NY
    SWB '10 Doublecab TRD Sport 4x4
    Cluster and Radio LED swap,Westin bull bar,2nd set of bed tie downs,URD SS,K&N filter,weathertechs
    This should be a sticky up top with the 2nd gen how to's
  3. Jul 7, 2014 at 1:36 PM
    gordi
    gordi Only had a wheel fall off once
    Josh
    North Idaho
    2011 DCSB trd sport
    Fox 2.5 extended travel, dakars, rear 5125 255/80/17 cooper maxx ST
    if i am changing my tranny oil and have a tranny cooler do i need mroe than 1.9 qts?
  4. Jul 7, 2014 at 2:51 PM
    02Duck
    02Duck manuals make it better
    2018 4WD TRD Off Road 6MT
    TRD Exhaust, Mobtown bolt on sliders and aluminum tailgate reinforcement, Reverse lights changed to yellow turn signals, LED pods added for reverse, ADD W1 oil catch can, Total Chaos bed reinforcement, rear diff breather to taillight mod, 12" combo led bars behind lower grill wired to high beams, Toyota led bed light kit, 400 watt anytime mod, SSO slimeline front bumper.
    Do you have an auto with cooler?
  5. Jul 7, 2014 at 2:54 PM
    Manwithoutaplan
    ID
    Pretty damn easy. I done mine almost like oil changes.
  6. Jul 7, 2014 at 2:55 PM
    Manwithoutaplan
    ID
    you have cooler for the MT. Do you have picture of this ?
  7. Jul 7, 2014 at 3:07 PM
    02Duck
    You're right its pretty easy. I've used a bunch of different methods / pumps to get the gear oil in before. The one I just used was by far the best I've tried. If you're looking for a pump try this one. I use some clear hose I had from a previous project and that also helped keep the spills down.
  8. Jul 7, 2014 at 3:12 PM
    Manwithoutaplan
    ID
    I have this
    http://motiveproducts.3dcartstores.com/1740-POWER-FILL-PRO-15-gallon_p_79.html
    Kinda pricey but well worth it.
  9. Aug 16, 2014 at 12:30 PM
    TACK
    TACK Well-Known Member
    Nevada
    10 PreRunner TRD Off-Road MGM
    Bilstein 5100s at 1.75", Level 8 Tracker wheels, white lithium grease mod for creaky clutch pedal
    I just did this today for the first time at 30,000 miles. I put in the Redline MT-90. I'm kind of baffled by all the people on here saying it improved their shifting so much. Mine feels exactly the same. I still randomly get light "grinds" going into the lower gears. I've driven this thing like a granny and most of my miles are on the highway.
    The old oil looked brownish and the magnet was full of sludge, so it's probably good that I did it.
    I HIGHLY recommend this oil suction gun. It worked flawlessly and the tube is the perfect diameter. It sucks up about half a quart per "gulp".
    http://www.amazon.com/OTC-2359-Oil-...=UTF8&qid=1408217054&sr=1-1&keywords=otc+2359
  10. Aug 16, 2014 at 1:45 PM
    george3
    george3 Well-Known Member
    New Jersey
    2008 2.7 Manual Trans Tacoma
    Seat belt beeper, Cabelas (Weathertech) floor liner gray, Covercraft Seat Savers in Taupe, Protecta Heavy Duty Rubber Truck Bed Mat, Pop n Lock PL5200, Pace Edwards Full Metal JackRabbit, Wolverine oil pan heater, Scangauge2, afe pro dry s filter, Remote Underbody 4 Piece LED Light Kit (White) used as Bed light, DIY Washable Cabin Air Filter, PA15-TOY, 4x4 Illuminated Switch, full synthetic, Redline Tuning Hood Support, Smittybilt Nerf Steps black powder-coated
    "improved their shifting" - it's the placebo effect but it's really maintenance - it's not to improve but to keep it working thus maintenance. I bought a gun that looked like that one but didn't work and someone bought one at work so I tried that - it sucked oil up but then the oil just ran out. Is there a technique involved like holding it in a certain position or something ? Thanks for any reply.
  11. Aug 16, 2014 at 1:51 PM
    TACK
    Nevada
    You're probably right about the placebo effect, lol.
    I just held the end of the hose upright so none would dribble out.
  12. Aug 16, 2014 at 2:18 PM
    vssman
    vssman Rocket Engineer
    Paul
    Naugatuck, CT
    2013 SR5 double cab
    I did mine this morning. I currently have 6,800 miles and after driving it for just a few miles definitely feel a difference. 3rd is much easier to engage. FWIW, if you don't have metric sockets that go up to the size of the plugs, a 15/16" six pointed socket fits just fine.
  13. Aug 16, 2014 at 2:39 PM
    george3
    New Jersey
    Thanks for the reply. I'm a little older and I find it helpful to hold the end of the hose upright so none will dribble out:rolleyes:
    bigdonniebrasco likes this.
  14. Aug 16, 2014 at 2:41 PM
    bcrufus
    bcrufus Member
    charlie
    Georgia
    would someone please help me i got a 89 toyota pickup i put new wires plugs, rotor button but i can; get it to fire what do i need to do.....bcrufus
  15. Aug 16, 2014 at 2:41 PM
    #35
    TACK
    Nevada
    Haha! Someone else might have experience with a good pump, but I thought that gun was great for the price.
  16. Sep 22, 2014 at 5:03 PM
    #36
    tacomavol87
    tacomavol87 Member
    Caleb
    Tennessee
    05 Speedway Blue Base TRD Off-Road
    What is the reasoning for this?
  17. Sep 28, 2014 at 8:57 PM
    #37
    Kasbien
    Kasbien Well-Known Member
    Kellen
    BC, Canada
    07 DCSB 6MT 4X4
    Pop rivets and JB Weld.
    I just changed out my tranny oil again (only ~8000km old, Penzoil or GM syncromesh oil I think) because it felt inexistent when shifting gears. Basically felt like straight metal on metal! I ended up putting in Royal Purple Syncromax because it was on sale for the same price as Redline MT ($15/quart, reg $45/quart). So far after driving around for a day, I can confirm that it's smooth and not grinding in any gears. Paired up with the TRD short-shifter kit I just put in and it feels pretty damn good. :yay:
    PRO TIP: I tried filling my tranny without a pump by attaching some clear tubing to the nozzle of the bottle and running the line as horizontal as possible into the transmission. HORRIBLE IDEA! Made a huge mess of both me and my driveway. I picked up a cheap hand pump for less than $10, poured the oil into a container, stuck one end of the pump in it and the other end in the transmission and was done in no time.
    TLDR; Don't attempt this without a pump.
  18. Jul 29, 2015 at 9:38 AM
    #38
    VolcomTacoma
    VolcomTacoma Well-Known Member
    Jeff
    NorCal
    2015 TRD Sport 4x4 6 Speed Supercharged
    Front- Camburg 4x4 Long Travel 2.5" King Coilovers 2.5" King Triple Bypasses Wheelers Superbumps Rear- DMZ SUA 16" 3.0 King Triple Bypasses 3" 2.0 Fox bumps Wheels and Tires- 295/75/16 Toyo ATII XTREME SCS SR8 Dark Matte Bronze 16" Lighting- (2) 30" Combo light bars (4) Iggycorp diffused pods Tepui Ayer TRD Supercharger URD Mark III 3" Exhaust URD 4x4 Y Pipe URD CAI URD 2.85 Stealth Pulley Hurst Core Shifter with Hurst T URD Stage 3 clutch URD Lightweight flywheel URD Throw out bearing upgrade AEM Wideband AFR Gauge Speedhut Boost Gauge Craven Speed Flex Pod mount Weathertech Floor Liners BAMF Sliders Ultragauge sPod SE ARB CKMTA12 Hella Supertone horns Relentless Tailgate Reinforcement
    Thread revival, whats the break in period for the 6 speeds? I really want to change to Mt-90, but want everything broken in first...i was thinking at least the first 5k miles before i start changing fluids
  19. Jul 29, 2015 at 10:12 AM
    #39
    pittsnogled
    pittsnogled I like turtles
    kirk
    South Carolina
    2014TRDsport
    5100's all around with OME 884 at 0. Weathertechs, Carhartt seat covers. BFG KO2's 265/70/17. T4R SEMA wheels. 18% tint on front windows. General Springs HD 4 leaf pack, Leer 100 XR shell.
  20. Jul 29, 2015 at 10:13 AM
    #40
    deeezy
    deeezy Well-Known Member
    Dana
    Hawaii
    2013 4x4 DC, 6 spd, TRD Sport
    King ext travel coilovers, Icon tubular UCA's Rear-King "Tundra" 2.5's, Allpro Expos, TRD cat-back, Hurst/Core short shift kit, etc...
    I honestly don't know if there is a break in period for the first fluid change but I changed mine at about 5-6000 miles. The Core shifter lets you hear gear noise that the stock shifter didn't. After the MT-90 most of the gear noise was gone. I still get gear "whine" but no rough sounds like when the stock fluid was in there.
