How-To: 6-Speed Manual Transmission Oil Change
Discussion in '2nd Gen. Tacomas (2005-2015)' started by tamer, Jul 22, 2013.
  1. Jul 29, 2015 at 10:14 AM
    #41
    Manwithoutaplan
    ID
  2. Jul 29, 2015 at 10:14 AM
    #42
    VolcomTacoma
    VolcomTacoma Well-Known Member
    Jeff
    NorCal
    2015 TRD Sport 4x4 6 Speed Supercharged
    Front- Camburg 4x4 Long Travel 2.5" King Coilovers 2.5" King Triple Bypasses Wheelers Superbumps Rear- DMZ SUA 16" 3.0 King Triple Bypasses 3" 2.0 Fox bumps Wheels and Tires- 295/75/16 Toyo ATII XTREME SCS SR8 Dark Matte Bronze 16" Lighting- (2) 30" Combo light bars (4) Iggycorp diffused pods Tepui Ayer TRD Supercharger URD Mark III 3" Exhaust URD 4x4 Y Pipe URD CAI URD 2.85 Stealth Pulley Hurst Core Shifter with Hurst T URD Stage 3 clutch URD Lightweight flywheel URD Throw out bearing upgrade AEM Wideband AFR Gauge Speedhut Boost Gauge Craven Speed Flex Pod mount Weathertech Floor Liners BAMF Sliders Ultragauge sPod SE ARB CKMTA12 Hella Supertone horns Relentless Tailgate Reinforcement
    Ok well, i should be installing the core shifter next week, and then doing a good thousand miles road trip, so maybe ill change it when i get back.
  3. Jul 29, 2015 at 10:15 AM
    #43
    VolcomTacoma
    Jeff
    NorCal
    I dont mind gear whine, Sunday im installing something that will out whine the gears :D
    BassAckwards likes this.
  4. Jul 29, 2015 at 10:20 AM
    #44
    Manwithoutaplan
    ID
    you short bed or access cab^?
  5. Jul 29, 2015 at 10:34 AM
    #45
    deeezy
    deeezy Well-Known Member
    Dana
    Hawaii
    2013 4x4 DC, 6 spd, TRD Sport
    King ext travel coilovers, Icon tubular UCA's Rear-King "Tundra" 2.5's, Allpro Expos, TRD cat-back, Hurst/Core short shift kit, etc...
    :burnrubber:
  6. Jul 29, 2015 at 10:48 AM
    #46
    VolcomTacoma
    Jeff
    NorCal
    DCSBFTMFW
  7. Jul 29, 2015 at 10:48 AM
    #47
    VolcomTacoma
    Jeff
    NorCal
    Yes.
  8. Jul 29, 2015 at 10:48 AM
    #48
    Manwithoutaplan
    ID
  9. Jul 29, 2015 at 10:50 AM
    #49
    Manwithoutaplan
    ID
    Op another help full piece of equipment for doing this oil change is
    www.motiveproducts.com/
  10. Jul 29, 2015 at 10:51 AM
    #50
    VolcomTacoma
    Jeff
    NorCal
    Yep, i was looking at those
  11. Jul 29, 2015 at 10:51 AM
    #51
    VolcomTacoma
    Jeff
    NorCal
    Also, OP is long gone :)
  12. Jul 29, 2015 at 10:51 AM
    #52
    Manwithoutaplan
    ID
    Since this oil change is pretty damn easy i do my change more frequently than 100K.
  13. Jul 29, 2015 at 10:52 AM
    #53
    Manwithoutaplan
    ID
    Have one worth every penny. Makes this job so easy and not messy.
  14. Jul 29, 2015 at 10:52 AM
    #54
    VolcomTacoma
    Jeff
    NorCal
    Ill be doing mine every 25k or so
  15. Jul 29, 2015 at 10:53 AM
    #55
    Manwithoutaplan
    ID
    That is pretty much what i have done. When ever i change out the diffs/t case.
  16. Jul 29, 2015 at 11:36 AM
    #56
    just2wd
    just2wd Well-Known Member
    Dan
    California
    07 PreRunner TRD Off Road
    sub'd , mine is due ,130k :typing:
  17. Jul 29, 2015 at 11:37 AM
    #57
    Manwithoutaplan
    ID
    get on it Mang :D.
    just2wd likes this.
  18. Jul 29, 2015 at 11:39 AM
    #58
    just2wd
    Dan
    California
    :wave:. always getting it on with my this truck, but i'll bet it'll like this oil change
  19. Nov 5, 2015 at 2:53 PM
    #59
    ppfd
    ppfd Well-Known Member
    WV
    09 TRD ext. cab 6 spd
    Bringing this up from the depths because I changed me own 6 speed tranny fluid today!:D
    My truck was at 75515 today. I had the clutch/throw bearing replaced about 2 years ago and not sure if they have to drain the transmission to do that job?
    So overall it was easy though somewhat a pain in the ass. On your back trying to maneuver a socket wrench is kinda tough. My bolts came off easy, and being the first time I used a torque wrench, (I'm no mechanic) I think I set it right at 27, but it never clicked, so I left them "snug".
    Filling wasn't bad, I bought 3 different pumps all listed here. Ended up using the one that goes in the top and even though it wouldn't screw on I didn't spill any! I filled to it started running out, gave it just a little shot more, and let it drain for a few seconds.
    Still have a little RL MT 90 left.
    Cleaned up, and checked the truck after about 30 minutes, no leaks.
    Test drive, and I can tell a difference, no smells so I must have not over filled it. Check again it the morning for any leaks.
    Overall took my around 30-45 minutes. Most time spent trying to get the socket wrench in place on the fill port.
    scottalot likes this.
  20. Nov 5, 2015 at 3:46 PM
    #60
    VolcomTacoma
    Jeff
    NorCal
    Hows the MT90 run in the trans? I'm almost to 5k in the truck, thinking on switching everything over to synthetic soon
