How-To: 6-Speed Manual Transmission Oil Change
Discussion in '2nd Gen. Tacomas (2005-2015)' started by tamer, Jul 22, 2013.
  1. Nov 5, 2015 at 5:45 PM
    #61
    ppfd
    ppfd Well-Known Member
    WV
    09 TRD ext. cab 6 spd
    I drove it about 5 miles and I could notice a difference.
    Transmission felt more "fluid" pardon the pun. Defiantly smoother shifting. Then again it could be I had 75 grand on the old fluid.
    scottalot likes this.
  2. Nov 5, 2015 at 6:34 PM
    #62
    deeezy
    deeezy Well-Known Member
    Dana
    Hawaii
    2013 4x4 DC, 6 spd, TRD Sport
    King ext travel coilovers, Icon tubular UCA's Rear-King "Tundra" 2.5's, Allpro Expos, TRD cat-back, Hurst/Core short shift kit, etc...
    Since you have the Core/Hurst kit installed on your truck, you'll be able to tell a big difference than with a stock shifter. The Core shifter lets you hear all of the gear noise going on with the stock tranny fluid. Compare that noise and feeling with how it feels and sounds after you change to the MT90. My tranny went from very notchy and "crunchy" sounding to a nice subtle gear whine.
  3. Nov 5, 2015 at 8:57 PM
    #63
    VolcomTacoma
    VolcomTacoma Well-Known Member
    Jeff
    NorCal
    2015 TRD Sport 4x4 6 Speed Supercharged
    Front- Camburg 4x4 Long Travel 2.5" King Coilovers 2.5" King Triple Bypasses Wheelers Superbumps Rear- DMZ SUA 16" 3.0 King Triple Bypasses 3" 2.0 Fox bumps Wheels and Tires- 295/75/16 Toyo ATII XTREME SCS SR8 Dark Matte Bronze 16" Lighting- (2) 30" Combo light bars (4) Iggycorp diffused pods Tepui Ayer TRD Supercharger URD Mark III 3" Exhaust URD 4x4 Y Pipe URD CAI URD 2.85 Stealth Pulley Hurst Core Shifter with Hurst T URD Stage 3 clutch URD Lightweight flywheel URD Throw out bearing upgrade AEM Wideband AFR Gauge Speedhut Boost Gauge Craven Speed Flex Pod mount Weathertech Floor Liners BAMF Sliders Ultragauge sPod SE ARB CKMTA12 Hella Supertone horns Relentless Tailgate Reinforcement
    Sweet! Anyone have any suggestions on when to do that? Should I change ally fluods at 5k or give it a little more?
  4. Nov 5, 2015 at 9:14 PM
    #64
    deeezy
    Dana
    Hawaii
    I changed mine out around 5000 just for piece of mind that the original fluid got replaced. I can't remember how cllean or dirty it was though.
  5. Nov 5, 2015 at 9:16 PM
    #65
    VolcomTacoma
    Jeff
    NorCal
    Yea I'm thinking all Difs, transfer case, trans and motor oil at 5k. One more good trail run a couple weeks should put me over 5k, and then I'll do em all
    deeezy likes this.
  6. Nov 8, 2015 at 6:14 AM
    #66
    obscurotron
    obscurotron Well-Known Member
    N. Nevada
    '14 DCSB 4x4
    Too many to list, and I've probably forgotten a bunch.
    I just did the driveline fluids yesterday - FR+RR diffs, tcase and 6sp trans. I guess Toyota fired the ape that used to torque the FR diff drain plugs at the factory, because these came off easy (my previous 2004 took a breaker bar, torch, PB blaster, and words that would make a Marine blush). Diffs and tcase were easy, but the trans was a PITA.
    It took nowhere near the specified 1.9 qts - closer to 1.5 or 1.6 (about as much as the front diff takes, oddly enough). This was after I slapped a level on the hood and jacked up the driver's side to center the bubble. Still, the MT-90 is good stuff. Shifts feel a little better, and the whine when I'm coasting in 1st gear, clutch in, has subsided a bit.
    The 75w85 crap in the front and rear diffs came out black as night, lots of metallic powder, a couple little flakes, nothing big or unusual. Next time around the diffs are getting 75w90. Also going to do a UOA on the diffs - I suspect the viscosity breaks down quickly, meaning you're running a 75w most of the time.
    One handy tip - warm up your bottles of oil beforehand. The fluid pumps more easily and spills are easier to clean up. Also +1 for the Motive unit. I have their brake bleeder and it's tits.
  7. Nov 8, 2015 at 2:55 PM
    #67
    jpachard
    jpachard Well-Known Member
    2006 4WD 4.0L Tacoma 6spd TRD
    Another alternative technique to filling is fill through the shifter. I had to swap out my shifter bushing and it's super easy to get to and saves buying a pump/hose setup which can get messy. Just wanted to throw it out there in case someone is in a pinch though this is now my preferred method.
    Cheers, James
  8. Nov 12, 2015 at 4:44 AM
    #68
    KugelBlitz
    KugelBlitz Well-Known Member
    Warren
    Middle-GA
    2015 4WD, 6MT, TRD Sport Access Cab
    Bilstein 61112/5160, Dakar EL096R, 285/70-R17 C BFG K02, Level 8 Mk6 wheels, Bestop Softop US. OffRoad Hidden Winch Bumper, ComeUp DV-9s winch, SOS Concepts Sliders and IFS Skid plate, VIAIR 400P Auto compressor mounted in a Expedition Essentials bedside mount, TRD Quick Shifter, TRD Cat-Back exhaust, ,75WX ST CB, Pioneer AVH-X4800BS, and various other mods and things...
    I have a 2015 TRD Sport with 6MT <6K miles and TRD Quick Shifter. I wanted to change out the transmission oil to Redline MT-90 75W90 GL-4 and ordered some thru Amazon. What I received was MT-85, 75W85 GL-4.
    Should I return it for MT-90 or .... use it?
  9. Nov 28, 2015 at 11:07 PM
    #69
    tamer
    tamer [OP] hamerworx.com
    NorCal
    2015 TRD OR AC, MGM, 4x4, 6spd MT
    I sold my Tacoma about 2 years ago, instantly regretted it, but didn't end up replacing it for a while.
    Yesterday I picked up a one owner 2009 SR5,4x4 V6 MGM 6spd MT. Pretty fucking excited to be back. Expect more out of me soon.
  10. Nov 29, 2015 at 10:09 AM
    #70
    VolcomTacoma
    Jeff
    NorCal
    Oh nice!!!! Im at about 6k miles now, today im changing motor oil to Mobil 1 synthetic and trans fluid to Redline MT90. Didnt quite want to spend another $150 on Redline dif fluid just yet lol, gotta spend monies on Long Travel :D
  11. Nov 30, 2015 at 2:13 PM
    #71
    deeezy
    Dana
    Hawaii
    How did everything go?
  12. Nov 30, 2015 at 2:17 PM
    #72
    VolcomTacoma
    Jeff
    NorCal
    It did not lol. 6 month old took up my weekend, wasnt able to get to it yet. Maybe tonight or tomorrow if I can get him to sleep lol
  13. Nov 30, 2015 at 2:27 PM
    #73
    deeezy
    Dana
    Hawaii
    Good luck with that. I just started to get more time to myself and my kids are 6 and 8 lol. Funny thing is, I wish they would stop growing up so fast though.
  14. Nov 30, 2015 at 2:33 PM
    #74
    VolcomTacoma
    Jeff
    NorCal
    Haha yea, hes a handful, but i love every minute of it. Even when im pulling my hair out lol. If its not to freezing tonight ill tackle the oil change and maybe the trans tomorrow.
    deeezy likes this.
  15. Feb 7, 2016 at 10:35 AM
    #75
    toyotadan98
    toyotadan98 Well-Known Member
    wa
    2011 TRD OFFROAD 4X4 ACC
    So after reading all this do I use gl-4 or can I use gl-5 in my 6 sp tranny
  16. Oct 17, 2016 at 12:56 PM
    #76
    TucTaco520
    TucTaco520 Well-Known Member
    Phil
    It's a dry heat
    11 Hooptie
    OME 90000s+887s, LR UCAs. AllPro Expos + 5100. KM Fab hybrid sliders w/kickout. KM Fab bed rack. 48" hi-lift. 16" FJ Trail Team wheels. 285/75/16 Hankook Dynapro ATMs. Magnaflow cat-back. K&N filter. TRD short-throw shifter. Murdered out via plasti-derp front grille and rear bumper. LED interior. De-badged tailgate. Rock lights (7). G2V 3x2 ditch lights.
    Thread from the dead....I thought i read somewhere that you aren't supposed to change MT oil every 30K? Am I crazy?
  17. Oct 17, 2016 at 11:11 PM
    #77
    Norton
    Norton Senior Member
    Colorado Springs, CO
    2013 Access Cab 4x4 V6 6MT, TRD OR & Tow Packages
    Magnuson S/C w/12TRDTacoma's Qwikchange Hub & 2.5" RIP-Modded Pulley, Roostfactor's Pulley Wrap Mod; FPR Mod; JustDSM Tune via HPT MPVI2; mightytacoman Intercooler Tank; aFe POWER Magnum FLOW Pro DRY S Air Filter; OME Suspension Lift (885 Coils, Dakar Leafs, NitroCharger Sports); TRD Quickshifter w/TRD 6-Spd Knob; TRD Exhaust; NSB-AGM27F Battery w/HKB Adjustable Voltage Booster & Coupe's TRD Battery Hold Down; Goodridge SS Brake Lines; Trident904's MT ADM; BFG All-Terrain T/A KO2s on FJ SE Anthracite Rims; N-Fab 6-Step Nerf Bars; BPF TRD Skid, Tow Hook, & Cooling Panel; jsi's Locker Anytime, Up2NoGood's 2Lo Module; ramonortiz55's Always on Power Outlet Relay, ND4's Fog Light Anytime, & Crom's Speed Bleeder Mods; crashnburn80's Ultimate Headlight & Fog Light Upgrades; ThreatLevelMidnight's Wireless Charger; 4Runner 4X4 & FJ Fog Light Switches; redtaco2007-inspired LED License Plate Lights; AudioControl LC2i LOC, JL Audio XD200/2v2 Amp, Focal PS165V1 Spkrs, Sound Ordnance B-8PTD Sub, Hushmat & Noico Sound Insulation; loginfailed-inspired Speedhut Boost & AFR Gauges in a Lotek Pillar Pod; Ltd Auto-Dim/Compass/Temp/Backup Camera/Homelink mirror on ImMrYo's Mirror Lift Bracket; TacomaBeast Glove Box & Console Organizers; Husky Floor Liners; UltraGauge EM; mesojdm's Ultimate LED Dome & Map Lights & GASSHOLE; Redline Tuning QuickLIFT Elite; Mobtown Offroad Locking Bed Storage Doors; Toyota Bed Mat; Cali Raised Led Bed Stiffeners; Pop & Lock Power Tailgate Lock w/TacomaTruckParts Support Bracket; ARE Z-Series Cap, SolarGard Tint; BlendMounted & MirrorTapped Uniden R3; CravenSpeed Stubby Antenna; Amsoil Lubricants; Adam's Detailing Supplies
    You're not crazy. The Warranty & Maintenance Guide for my 2013 recommends "inspecting" the transmission oil every 30K miles, but never recommends changing it, under "normal" operating conditions. (Not a good plan.) The same guide recommends "changing" the transmission oil every 30K miles under "special" operating conditions (i.e., Driving while towing, using a car-top carrier, or heavy vehicle loading).
    TucTaco520[QUOTED] likes this.
  18. Oct 17, 2016 at 11:16 PM
    #78
    VolcomTacoma
    Jeff
    NorCal
    I was gonna do mine every 10-15k just to have fresh stuff in there. Only costs about $50 IIRC and takes all of half an hour maybe
  19. Oct 18, 2016 at 9:11 AM
    #79
    TucTaco520
    Phil
    It's a dry heat
    11 Hooptie
    Thanks. I guess it would be best to just keep tabs and make sure its still shifts smoothly then. I thought our trannys dont have dipsticks though...
  20. Oct 18, 2016 at 12:26 PM
    #80
    OneWheelPeel
    OneWheelPeel Well-Known Member
    Phoenix, AZ
