How-To: 6-Speed Manual Transmission Oil Change
Discussion in '2nd Gen. Tacomas (2005-2015)' started by tamer, Jul 22, 2013.
  1. Oct 18, 2016 at 9:51 PM
    #81
    Norton
    Norton Senior Member
    Colorado Springs, CO
    2013 Access Cab 4x4 V6 6MT, TRD OR & Tow Packages
    Magnuson S/C w/12TRDTacoma's Qwikchange Hub & 2.5" RIP-Modded Pulley, Roostfactor's Pulley Wrap Mod; FPR Mod; JustDSM Tune via HPT MPVI2; mightytacoman Intercooler Tank; aFe POWER Magnum FLOW Pro DRY S Air Filter; OME Suspension Lift (885 Coils, Dakar Leafs, NitroCharger Sports); TRD Quickshifter w/TRD 6-Spd Knob; TRD Exhaust; NSB-AGM27F Battery w/HKB Adjustable Voltage Booster & Coupe's TRD Battery Hold Down; Goodridge SS Brake Lines; Trident904's MT ADM; BFG All-Terrain T/A KO2s on FJ SE Anthracite Rims; N-Fab 6-Step Nerf Bars; BPF TRD Skid, Tow Hook, & Cooling Panel; jsi's Locker Anytime, Up2NoGood's 2Lo Module; ramonortiz55's Always on Power Outlet Relay, ND4's Fog Light Anytime, & Crom's Speed Bleeder Mods; crashnburn80's Ultimate Headlight & Fog Light Upgrades; ThreatLevelMidnight's Wireless Charger; 4Runner 4X4 & FJ Fog Light Switches; redtaco2007-inspired LED License Plate Lights; AudioControl LC2i LOC, JL Audio XD200/2v2 Amp, Focal PS165V1 Spkrs, Sound Ordnance B-8PTD Sub, Hushmat & Noico Sound Insulation; loginfailed-inspired Speedhut Boost & AFR Gauges in a Lotek Pillar Pod; Ltd Auto-Dim/Compass/Temp/Backup Camera/Homelink mirror on ImMrYo's Mirror Lift Bracket; TacomaBeast Glove Box & Console Organizers; Husky Floor Liners; UltraGauge EM; mesojdm's Ultimate LED Dome & Map Lights & GASSHOLE; Redline Tuning QuickLIFT Elite; Mobtown Offroad Locking Bed Storage Doors; Toyota Bed Mat; Cali Raised Led Bed Stiffeners; Pop & Lock Power Tailgate Lock w/TacomaTruckParts Support Bracket; ARE Z-Series Cap, SolarGard Tint; BlendMounted & MirrorTapped Uniden R3; CravenSpeed Stubby Antenna; Amsoil Lubricants; Adam's Detailing Supplies
    Like @VolcomTacoma, I proactively change mine. I swapped it over to Amsoil, which is designed for an extended drain interval. Like @Truck Yeah!, doing so improved shifting for me as well.
    I don't think I've seen a MT with a dipstick. They're drained by pulling the bottom plug and filled by pumping new oil into the top one until it begins to seep out. Once "sealed," they're good until the next drain interval or a problem arises. For peace of mind, I'd change dino oil every 30K miles and synthetic every 60K miles.
    RedTaco68 likes this.
  2. Oct 18, 2016 at 10:07 PM
    #82
    VolcomTacoma
    VolcomTacoma Well-Known Member
    Jeff
    NorCal
    2015 TRD Sport 4x4 6 Speed Supercharged
    Front- Camburg 4x4 Long Travel 2.5" King Coilovers 2.5" King Triple Bypasses Wheelers Superbumps Rear- DMZ SUA 16" 3.0 King Triple Bypasses 3" 2.0 Fox bumps Wheels and Tires- 295/75/16 Toyo ATII XTREME SCS SR8 Dark Matte Bronze 16" Lighting- (2) 30" Combo light bars (4) Iggycorp diffused pods Tepui Ayer TRD Supercharger URD Mark III 3" Exhaust URD 4x4 Y Pipe URD CAI URD 2.85 Stealth Pulley Hurst Core Shifter with Hurst T URD Stage 3 clutch URD Lightweight flywheel URD Throw out bearing upgrade AEM Wideband AFR Gauge Speedhut Boost Gauge Craven Speed Flex Pod mount Weathertech Floor Liners BAMF Sliders Ultragauge sPod SE ARB CKMTA12 Hella Supertone horns Relentless Tailgate Reinforcement
    I'm changing mine at about 15k miles just to see how bad the new clutch is getting burned up. If I find a bunch of sparkly stuff I know I need to change my driving habits and learn how to use a clutch alot better lol
    BassAckwards likes this.
  3. Oct 18, 2016 at 10:28 PM
    #83
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    I recall seeing an actual dipstick in a Manual Transmission before, I think it might have been in some strange Subaru.
    Norton[QUOTED] likes this.
  4. Dec 4, 2016 at 5:24 PM
    #84
    Stickerice85
    Stickerice85 Well-Known Member
    South Eastern, PA
    2015 Tacoma DCSB TRD Pro
    Anyone know the part #'s for the fill and drain plug crush washers?
  5. Dec 4, 2016 at 6:40 PM
    #85
    Norton
    Transmission drain plug washer (aluminum) = part #90430-18008 / 90430-A0003, 27 ft lbs, ($1.51/ea)
    Transmission fill plug washer (aluminum) = part #90430-18008 / 90430-A0003, 27 ft lbs, ($1.51/ea)
  6. Dec 4, 2016 at 7:06 PM
    #86
    winkel
    winkel Well-Known Member
    Corydon, IN
    2014 Spruce Mica, TRD Off-Road, 6 Spd Manual
    Sliders, Tailgate Liner
    Time to revive. I changed manual transmission fluid at 34,000 miles. The shifting was a little notchy before the change. I couldn't find Red Line locally so I bought Lucas and it listed specifically on the bottle that it was for use in transmissions with synchronizers.
    I immediately noticed that it now shifts smoother. My wife even noticed it. This is one instance where I don't think the placebo effect applies.
    I've done my diffs but still need to do my transfer case. I'll probably do it over Christmas break.
    lo2hi likes this.
  7. Dec 31, 2016 at 1:02 AM
    #87
    99SuperTaco4x4
    99SuperTaco4x4 Well-Known Member
    1999 3.4L V6 Tacoma, 4x4, TRD Supercharger
    I've been driving standards for more than 15 years. My Tacoma had a noticeable grind going into second. I bought the truck with 135,000 miles and unknown maintenance on the transmission. After replacing the transfer case and transmission oil with RL MT-90, there is a very noticeable improvement- no more grind and it is smooth through all gears. I highly recommend it and believe it to be worth the premium.
    BassAckwards, scottalot and lo2hi like this.
  8. Dec 31, 2016 at 5:15 AM
    #88
    badger
    badger Well-Known Member
    07 SR5
    this^^ Buy it from JEGs
  9. Jan 10, 2017 at 2:53 PM
    #89
    BrennMan
    BrennMan Well-Known Member
    01 TRD Access Cab (current) 07 PreRunner TRD (sold)
    5100s, Weather Tech, Wet Okole, 1.25" spidertrax, pop-lock, Bestopper
    I made a little video as changed my transmission fluid today.
    Moderater: if this isn't allowed in someone else's thread please delete. Just assumed it may help someone (not likely, ha!).
    https://youtu.be/j_ZEQcS0pg0
  10. Jan 10, 2017 at 2:57 PM
    #90
    99SuperTaco4x4
    Hey BrennMan, the other reason besides splashing that you want to remove the fill plug FIRST is to ensure you can refill after draining. Otherwise, you are SOL if you drain and cannot get the fill plug off for whatever reason.
    How are you liking the redline?
    lo2hi and Norton like this.
  11. Jan 11, 2017 at 7:24 AM
    #91
    BrennMan
    I didn't show that very well in the video. I read someone suggesting that and I had loosened it I was nervous about dirty/debris falling in while I had it off. I should have mentioned that, you're right. Surprisingly the bolts weren't very tight at all.
    I'm liking it so far. I didn't have any huge problems before but I'm noticing the most improvement in performance when the transmission is still cold. In the past I would have to be much more precise with my shifting the first couple of minutes during a drive. This seems to be gone now. The first couple of minutes are just as smooth as when the temps are up to normal.
    Overall I'm plenty happy with it. I would absolutely spend the extra few bucks on the redline, if no other reason than just peace of mind.
  12. Jan 12, 2017 at 7:53 AM
    #92
    thinkingman
    thinkingman Well-Known Member
    redmond WA
    2006 dbl cab 4wd 6sp
    Foglights are for fog, not oncoming traffic!
    I just went out this morning, 21 degrees, to see how much differently it shifts....Amazing.
    It's so much smoother, my linkage feels sloppy now.
    99SuperTaco4x4 likes this.
  13. Jan 13, 2017 at 8:54 PM
    #93
    1320Fastback
    1320Fastback Active Member
    05 4.0L 6spd
    Can always pull the shifter out and dump 2qts in thru there. Might actually be faster than hand pumping in.
    darkyota33 and scottalot like this.
  14. Jan 13, 2017 at 8:58 PM
    #94
    VolcomTacoma
    Jeff
    NorCal
    Solid pass. This would be me inside my truck trying to pour something in to the dash
    scottalot likes this.
  15. Mar 15, 2017 at 3:32 AM
    #95
    tamer
    tamer [OP] hamerworx.com
    NorCal
    2015 TRD OR AC, MGM, 4x4, 6spd MT
    Bump. I'll be changing my fluids again soon. I will update the first post with my findings.
  16. Jul 9, 2017 at 12:25 AM
    #96
    Kasbien
    Kasbien Well-Known Member
    Kellen
    BC, Canada
    07 DCSB 6MT 4X4
    Pop rivets and JB Weld.
    I commented a few years back having used Royal Purple Syncromax and a shitty pumping method to transfer the oil into the transmission. Fast forward to now, and this time round I bought a nozzle pump that simply attaches to the oil bottle like a soap dispenser (used for pumping gear oil into boat engines) and Redline MT-90. The new pump made the process so much cleaner and easier -- however it did not attach to the Redline bottle properly so I simply transfered its contents into another and I was laughing. I can also attest that Redline > RP Syncromax. 1st and 2nd are much less notchy and shifting in general just feels that much smoother. :thumbsup:
  17. Nov 14, 2017 at 9:37 PM
    #97
    JasonY
    JasonY Active Member
    Austin, Texas
    09 Access Cab, Prerunner, SR5, Alloys,
    Yikes, I'm at 100,000 miles and I've never changed the MT fluid. 2009 2.7l 4 cyl 5 speed. Doesn't seem to be shifting rough (though sometimes getting it into reverse while stopped takes a few tries). Hope I haven't hurt anything.
  18. Nov 14, 2017 at 10:27 PM
    #98
    michael roberts
    michael roberts Well-Known Member
    san diego
    07,4x4, white, AC.
    powder coated hood support.
    Good information here, I'll add to it. I drive it first, all gears, including reverse and 4wd, get everything warm. Pull into the driveway, with four oil drain pans, change the whole drive train. Pain in the a$$, but I'm done with it in one shot.
  19. May 21, 2018 at 10:17 PM
    #99
    tamer
    NorCal
    Bump. at 150k Miles on my 2009. Going to change soon. Going with MT-90 for the tranny, haven't decided if I want to go redline or Mobil1 in the diffs. Not sure if it's worth the extra money for the redline at this point.
  20. May 22, 2018 at 6:18 AM
    #100
    badger
    07 SR5
    absolutely nothing beats MT-90 in the transmission
