How-To: 6-Speed Manual Transmission Oil Change
Discussion in '2nd Gen. Tacomas (2005-2015)' started by tamer, Jul 22, 2013.
  1. Jul 23, 2020 at 6:30 PM
    #161
    ijonahtacoma
    ijonahtacoma Well-Known Member
    Jonah
    2005 Black Tacoma with the turtle shell
    Seriously I'm just learning how to work on this thing.
    My fill plug won’t come off, so I had to go thru the shifter. haha. I measured how much came out, and put the same amount in. Works
  2. Jul 23, 2020 at 6:31 PM
    #162
    Sep1911
    Sep1911 Well-Known Member
    2016 Taco
    I just pour the 2 quarts and call it a day lol
    ijonahtacoma[QUOTED] likes this.
  3. Jul 24, 2020 at 7:16 AM
    #163
    EdgemanVA
    EdgemanVA Well-Known Member
    Virginia Beach
    2008 X-Runner
    Several
    Let me guess, your dealer did the last transmission fluid change. I know they over-torque the heck out of my engine oil drain plug. I needed a breaker bar to get the plug off the last time after the dealer changed my engine oil, and that's why they will never change my engine oil again. They've never changed my transmission or differential oil, and they never will...I've done every one of those changes.
  4. Jul 25, 2020 at 5:53 PM
    #164
    spencermarkd
    spencermarkd Well-Known Member
    Spencer
    07 Driftwood Pearl 4Runner
    I put in a URD short shifter today and decided to change my fluid at the same time. Went to fill through the shifter and it wouldn’t go into the transmission at first, started googling and eventually gave up and started to pump it in. Apparently after I cracked the fill bolt it started going in, because when I went in the cab for the second quart it had drained down. Who knew it was that tight of a seal on the shift shaft. Super easy way to fill, dump until it starts coming out the side :thumbsup:
  5. Jul 26, 2020 at 9:12 AM
    #165
    gnomesteel
    gnomesteel Active Member
    Texas
    05 PreRunner V6 SR5 6-Speed Manual
    Went to do this yesterday and couldn’t get the fill plug off. It started rounding pretty quickly so I backed off and will likely take it to a shop. Ordered a new fill plug from the stealership as well.
  6. Aug 1, 2020 at 1:11 PM
    #166
    tonyl13
    tonyl13 Well-Known Member
    tony
    Sonoita,Az.
    09PreRunner xcab
    badgeless
    Must be one heck of a big 6th
  7. Dec 6, 2020 at 12:00 PM
    #167
    Jacked Burton
    Jacked Burton Well-Known Member
    35s 4.30s 6speed TruTrac Fx Pros Bilstiens Dakars
    Tires: 35/11.5/17 Toyo AT3s Wheels: FN FX Pro Gunmetal 17s with TRD center caps Zinc Metallic lettering. Yukon 4.30 gears with TruTrac Front Suspension: OME 887 w/5100s, Freedom Offroad UCAs n Superbumps Rear: Archive Hammer Hangers,Dakar Mediums, Bilstien 5125s Ubolt flip n Superbumps, Headlights: Selfmade Retrofits URD shortshift kit Airaid CAI No name throttle controller
  8. Dec 6, 2020 at 1:09 PM
    #168
    DiscoYaker
    DiscoYaker Well-Known Member
    SE USA and Alaska
    2015 Tacoma 4WD SR5 AC MT, 1995 Tacoma 2wd ext. cab auto
    Stock for now.. maybe
    Have you ever used that additive before? I'm always a bit leary about additives like this. Their website says that it
    "protects and reverses wear in your drivetrain with nanoparticles,"
    The 'reverses wears is what gets me
    Just curious because I've never heard about tribotex
  9. Dec 11, 2020 at 1:19 PM
    #169
    SaratogaTaco
    SaratogaTaco Well-Known Member
    Skip the Walmart stuff and just use Red-line.
    mrbetelman and EdgemanVA like this.
  10. Dec 11, 2020 at 1:32 PM
    #170
    DiscoYaker
    SE USA and Alaska
    If you are referencing post #175 and 176 i was more curious about that additive they put in. Never heard of it. I got my Red-line ready to go already. Wasn't planning on using the additive either. On their website they actual say it'll help repair gears and such... sounds like a crazy money making thing
  11. Dec 13, 2020 at 4:28 PM
    #171
    Jeff Lange
    Jeff Lange Well-Known Member
    Calgary, Canada
    '86 AE86, '05 NCP13, '11 GSE21
    This is not always the case, in fact there are some similar manual transmissions (the RA62 and RA63 for instance), where Toyota says to ONLY use GL-5, do not use GL-4 or it will damage the transmission.
    If Toyota says use GL-4 or GL-5, and you'd more comfortable using GL-4 because that's what the later spec vehicles use, you're good to go, but the blanket statement that GL-5 should never be used in transmissions isn't true.
    Jeff
  12. Dec 14, 2020 at 9:28 AM
    #172
    tamer
    tamer [OP] hamerworx.com
    NorCal
    2015 TRD OR AC, MGM, 4x4, 6spd MT
    The RA62 & 63 are Lexus transmissions. What does that have to do with a thread about the 6-speed Tacoma transmission? My statements in this thread reference the Tacoma 6 speed, that's it.
  13. Dec 14, 2020 at 12:09 PM
    #173
    Jeff Lange
    Calgary, Canada
    Maybe I shouldn't have included your post in mine, but when you said "yup that's definitely the case. Use GL4", was I wrong to assume that was in response to "I was always under the impression GL5 with its additives can really mess up your gearbox synchro rings," which wasn't specific to the Tacoma's transmission, it seemed to be a statement about the use of GL-5 in synchronized transmissions in general. To improve the relevance, I can make my comments more specific to this thread I suppose.
    GL-5 is acceptable for use in the RA60 and RA60F used in the Tacoma, at least for 2005-2013 model years and will not damage the synchro rings because that is what it is designed for. In fact, the very similar transmissions that Toyota used in the IS200d, IS220d, IS250, and Mark X, all of which are Aisin AY6-type transmissions, require GL-5. In fact they use the exact same synchros that the Tacoma transmission uses for 2nd, 3rd, 4th, 5th, and 6th gear.
    If Toyota used the same synchros in the RA60, RA61, RA62, and RA63, and the RA62 and RA63 both require the use of GL-5, the same sychros would not be damaged by GL-5 when used in the Tacoma.
    Jeff
    spencermarkd likes this.
  14. Jan 30, 2021 at 3:52 PM
    #174
    RHHousehold
    RHHousehold Well-Known Member
    CA
    2008 Access Cab TRD Offroad 4x4 V6
    Just changed my transmission fluid with MT-90. Noticeably smoother shifting. Looks like my 2008 had been maintained (I'm the second owner), because the old oil wasn't terrible -- but it was golden. Small amount of black metallic dust on magnet. The process was really easy, since the 24 MM plugs are so easy to get lose. Replaced main drain plug washer.
  15. Jan 31, 2021 at 6:58 AM
    #175
    badger
    badger Well-Known Member
    07 SR5
    GL-5 was specifically formulated for use in hypoid gear systems like in differentials. One characteristic of GL-5 is that it is super slick. This prevents wear as the hypoid gears mesh. It might seem that super slick is always better, but most manual transmissions require a certain amount of drag to operate correctly. It could be that some transmissions are designed to use GL-5. I don't claim to know. I do know that putting GL-5 in a Tacoma 6-speed is the quickest way to F it up. I have personally tried 6 or 7 different oils, and MT-90 is the clear winner in my truck. I'm at 176,000 miles now, and I first started using it in 2010 at 38,000 miles.
    winkel, RHHousehold and specter208 like this.
  16. Jan 31, 2021 at 12:08 PM
    #176
    Jeff Lange
    Calgary, Canada
    Care to explain?
    Jeff
  17. Jan 31, 2021 at 12:19 PM
    #177
    badger
    07 SR5
    All the Gl-5s that I tried immediately resulted in rough shifting and hang ups between gears. You had to shift very slowly and deliberately. My guess is that it took the synchros longer to actually synchronize the gears because they were slipping. When I first discovered this issue, there was not a lot of info about it, and Toyota added to the confusion by suggesting that GL-5 was fine. I ended up filling and dumping many different top brands until I came upon a reference to GL-4 and specifically MT-90. I was one of the early voices trying to get this information out regarding the 6 speed.
    specter208 likes this.
  18. Feb 1, 2021 at 9:51 PM
    #178
    Xmplry808
    Xmplry808 Well-Known Member
    2015 BRM Tacoma xrunner
    Engine: -Doug thorely long tube headers -URD dual O2 simulator -Dual 2.5” QTP cut outs -RADS true dual piping -TRD supercharger MP90 -Custom air duct -K&N cold air intake -AFE tb adapter -AFE 76mm throttle body -URD 2.7 supercharger pulley -URD fuel pump/Aeromotive 340 upgrade -URD extension harness -URD maf calibrator w/map sensor -URD 170 thermostat -URD speed unlimiter -Cusco oil catch can -URD fuel rail tap -FPR mod -COUPE oil pan spacer w/baffle -NX wet nitrous kit 50 shot -NX 10 lb bottle -NX purge kit -ZEX rapid fire module -Greddy oil filter relocation adapter -Mishimoto oil cooler -HKS big 3 wire upgrade -Pulley wrap mod Electrical -130amp alternator -Voltage Booster Pro SPARK -Optima yellow top group 27 -1/0 wire upgrade Drivetrain: -B&M short shifter -Detroit tru trac LSD -Competition Clutch stage 4/6 puck clutch kit -Competition Clutch lighten flywheel -URD throw out bearing/sleeve kit -Sprint booster V3 -Remove clutch accumulator Suspension: -Djm front A arms -Djm welded in frame notch -DJM offset bushings -XII Performance front coilovers -XII Performance sway bars Fronts 1 3/8” Rear 1 1/16” -4" Custom Taco drop blocks -QA1 rear shocks -Air Lift air bags -Air compressor -Alignment Cam Gussets -UMI billet front sway bar mounts 1 3/8 Wheels/tires: -HRE wheels 540 step lip Front 20x10 255/35/20 Rear 20x11 305/30/20 Brakes: -Performance Brake Unlimited BBK -4 piston Tundra calipers -360mm ISF drilled brembo rotors -Stop tech stainless steel brake hoses -Brembo brake pads Exterior: -35% ceramic front window tint -Hood spacers 1" -Cut front grill -Cut hood scoop -Strictly Street RACE spec spoiler -Race front and rear tow hooks -Diode Dynamic SS3 yellow pro fogs -Race Louvers Front RSF fender trim Rear FL fender trim Interior: -Lotek dual gauge pillar pods -Ultra gauge Mx 1.3 -TRD shift knob -JunctionProduce pillow cushions (4) -Bellezza leather neck pads (2) -Innovation gauge dual wide band -Innovation boost gauge w/shift light -Air lift dual air pressure gauge -TRD racing pedals -LED lighting Sounds: -Sony XAV-AX8000 -JLaudio (2)13w6v2 subwoofer in isobaric ported box 33hz -JLaudio 1000/1 mono amp -JLaudio Evo C3 6.5 (4)co-axles -JLaudio 300/4 4 ch. amp
    I use torco gl5 in my Xrunner
  19. Apr 4, 2021 at 8:41 PM
    #179
    Inbred
    Inbred Well-Known Member
    Phinnius
    2nd generation euphoria
    Hardscrabble likes this.
  20. Aug 9, 2021 at 8:30 AM
    #180
    pittsnogled
    pittsnogled I like turtles
    kirk
    South Carolina
    2014TRDsport
    5100's all around with OME 884 at 0. Weathertechs, Carhartt seat covers. BFG KO2's 265/70/17. T4R SEMA wheels. 18% tint on front windows. General Springs HD 4 leaf pack, Leer 100 XR shell.
    lots of good info here. if Im doing redline MT90 for the transmission, what should i use for the transfer case? can i use the same?
