How to access igntion switch?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Raylo, May 29, 2009.
  1. May 29, 2009 at 11:00 AM
    Raylo
    Raylo [OP] Well-Known Member
    MD, USA
    2009 4x4 Access Cab, TRD Sport
    I'm in the middle of an alarm/remote start install on my 09 V6 Taco and I need to get at the harness and connector at the ignition switch that does the keysense and also has the wires I need to tap to connect my Fortin immobilizer bypass module. (I already have the main ignition switch connector off to get the starter and ignition wires, no problem). But there is a plastic cowl around the switch that makes it impossible to get at this second connector. Anyone know the trick for getting this thing off??
  2. May 29, 2009 at 11:09 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
  3. May 29, 2009 at 11:25 AM
    Raylo
    MD, USA
    Well..... YES! Black screws hidden behind the steering wheel. Many thanks.... I have been poring through all the electrical diagrams and I didn't think to go try to find this little gem.
  4. May 29, 2009 at 11:35 AM
    brian
    brian Another Traitor
    Elizabeth City, NC
    2017 F-250 Powerstroke
    Please let me know how your remote start install goes, I still haven't installed mine.
  5. Oct 11, 2010 at 8:44 PM
    justin144
    justin144 Well-Known Member
    justin
    Las Cruces, New Mexico
    2011 Taco 4X4 Dbl cab Long Bed
    I know this is an old thread, but I'm installing the 791 bypass which requires you to loop a wire around the ignition switch. Do you know if I need to take the ignition switch off to do this? and if so, how? I've included a picture to better explain the process. thanks
