How to access lower dash fuse area
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Li0nel1234, Mar 14, 2014.
  1. Mar 14, 2014 at 2:13 PM
    Li0nel1234
    Li0nel1234 [OP] Well-Known Member
    Lionel
    Denver
    14 TRD OR DCSB SSM
    Does anyone have a pictorial on how to access the lower dash fuses?
    I took off the kick plate by the door sill but can't figure out how to remove the black foot rest and thus can't remove the lower side kick plastic in order to get to the bolts that keep the lower dash in place.
  2. Mar 14, 2014 at 2:17 PM
    Li0nel1234
    Lionel
    Denver
    14 TRD OR DCSB SSM
    Nevermind!
    I just used a few flat heads and pulled straight out on the foot rest. Then there was a little twisty rubber stop keeping the side kick plate in place and the side plate pulse out from two tabs.
    I'll take and post some pics for others in case they reach this minor problem. I couldn't find anything in the search.
  3. Mar 14, 2014 at 2:36 PM
    JdevTac
    JdevTac Well-Known Member
    Josh
    MD/GA
    2nd gen
    You mean the fuses above the pedals right? Just pop out the little door pocket on the left of the steering column and you have quick access...no unbolting or removal of panels or anything like that.
    unless im mistaken and there is another fuse panel I am unaware of near the dead pedal?
    fuse location 101: http://www.carcarekiosk.com/video/2009_Toyota_Tacoma_Pre_Runner_4.0L_V6_Crew_Cab_Pickup_(4_Door)/fuse_interior/replace
  4. Mar 14, 2014 at 6:57 PM
    Li0nel1234
    Lionel
    Denver
    14 TRD OR DCSB SSM
    I had to get to the flasher box and remove the lower dash to get to it. I got there. Thanks!
