How to add DRL's???
Discussion in '1st Gen. Tacomas (1995-2004)' started by vantaco, Aug 18, 2010.
  1. Aug 18, 2010 at 8:41 AM
    vantaco
    vantaco [OP] Well-Known Member
    02 Taco Xtracab TRD Step Side
    i need to know if there is an OEM way to add DRL's to a 01-04 tacoma?
    i'm looking a buying a truck from the US and need day time running lights to pass inspection here in canada
    any help would be appreciated
    thanks
  2. Aug 18, 2010 at 10:04 AM
    Southern01Taco
    Southern01Taco Well-Known Member
    Sean
    Holden, La
    01 V6 4x4 Xtra Cab SR5
    They should already have it iirc. I know mine does and its an 01.
  3. Aug 18, 2010 at 10:45 AM
    vantaco
    i think you're thinking of something different
    DRL's are when your headlights come on at approx 80% at start up (this is with most cars)
    this is a requirement for canadian cars
  4. Aug 18, 2010 at 2:01 PM
    Southern01Taco
    Sean
    Holden, La
    Yea DRL means Daytime Running Lights. I'm pretty sure they all come stock with them unless they have been disabled. I just disabled mine the other day.
  5. Aug 19, 2010 at 9:01 AM
    vantaco
    uhmm, now did you disable them??? (thinking that i can possibly reverse it if needed)
    and do your headlights come on or just your signal/marker lights?
  6. Aug 19, 2010 at 9:22 AM
    sirsaechao
    sirsaechao Well-Known Member
    Tim
    Commifornia
    2002 Toyota Tacoma SR5 TRD 3.4L 4X4 V6
    To much to list...see sig for more...
    I have a 02 and I don't have DRL.
  7. Aug 19, 2010 at 10:03 AM
    Southern01Taco
    Sean
    Holden, La
    There is a drl relay box under the dash on the drivers side. I clipped one on the wires on the plug. Its an easy mod to do and just as easy to undo it. It is just my headlights that would come on and when I would turn the headlight switch on they would get a little brighter and my marker lights would then come on.
  8. Aug 19, 2010 at 10:31 AM
    Southern01Taco
    Sean
    Holden, La
    It might have been a factory option or something.
  9. Aug 19, 2010 at 12:41 PM
    zero4
    zero4 Metal Cutter
    Will
    Northridge, CA
    01' DCab 3.4L TRD
    Donahoe CO, Donahoe Rear Resi, Deaver J59, 16" Pro Comp, 33" BFG AT, Hayden Trans Oil Cooler, Oil Filter Relocator, FM 40, ES Bushings, Beefed CB Drop, Deckplate, K&N Drop-In, DO Bed Bar, Cobra 75 WXST, Firestik Firefly, Philips D1R, Clarion Remote Start, Husky Liners
    Mine's an 01 & came with DRLs, I also disabled them which was the first thing I did when I got it.
    And yes only the headlights come on with less output than the normal lows without the markers. I forget if mine did it but IIRC DRLs in general are supposed to turn when the parking brake is released with the key on. If you look right under the dash slightly off to the right you will see the DRL control module & it's clearly marked.
  10. Aug 19, 2010 at 1:41 PM
    cinch
    cinch Member Extraordinaire
    Al
    Boulder Creek Ca
    2010 Prerunner double cab
    The daytime running lights on my 2010 are just the marker lights. On myFJ Cruiser it was the headlights.
