How to adjust Icon coilovers?
Discussion in 'Suspension' started by MEMO CAMPOS, Mar 25, 2014.
  1. Mar 25, 2014 at 7:52 PM
    MEMO CAMPOS
    MEMO CAMPOS [OP] Well-Known Member
    Westminster, Ca.
    05 PRERUNNER
    TC Upper Arms, ICON coilovers, Camburg spindles, AP standard leaf packs, ICON Resi.'s, AFE intake, Magnaflow Magnapack, Defiant Light Bar with PIAA 580's, 6K HID's top and bottom
    Whats the best way to adjust my Icon coilovers? I'm sure its easy but what steps should I take and any useful tips?
  2. Mar 25, 2014 at 7:58 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Loosen the allen set screw, then twist to adjust. 1 turn is about 1/8" (IIRC). You can adjust them with the truck on the ground. Drive it around after a few turns, to get the adjustments to settle in.
  3. Mar 25, 2014 at 8:23 PM
    MEMO CAMPOS
    Westminster, Ca.
    05 PRERUNNER
    Right on thank you sir, is there a way to do it if I don't have a spanner wrench? Still don't understand why Icon doesn't provide one!....blows!
  4. Mar 25, 2014 at 8:35 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    They sell them, but being as most folks have a shop do the install, they don't include one, as most shops keep it even if they include it. Best is to use a 3/8" diameter long drill bit (concrete), punch, allen wrench, etc. or, you can get the spanner from Icon.
  5. Mar 27, 2014 at 4:10 AM
    PMK
    PMK Well-Known Member
    Florida
    10 DCLB TRD Sport
    White, debadged, Mudflaps removed, ICON 2.5 in front, 2.0 in rear, all 4 corners have reservoirs, Spidertrax wheel spacers all around, BAMF bolt on sliders, Avid lightbar, oem transmission cooler converted to power steering cooler, aftermarket transmission cooler eliminating all oem transmission cooler stuff, remote mounted spin on transmission fluid filter TrueTrac rear differential, rear diff housing vented and filtered into left side bed box, URD MAF calibrator, Volant intake scoop into oem airbox, second filter removed, airbox internals smoothed, blended and polished throttle body, NST intake manifold spacer, Wet Okolee set covers, WeatherTech Digital Fit mats, inexpensive JVC single DIN, Scangage, AVS Stepshield door sill protectors, Doug Thorley Long Tube Headers, URD Y pipe with O2 sims.
    You should also consider on the lower spring seat, to position the slot towards the rear. It may or may not have any effect, but does protect the lower end of the shafts more.
    PK
  6. Mar 27, 2014 at 7:11 AM
    Rezo Rock
    Rezo Rock Active Member
    Anaheim, California
    07 PRE RUNNER
    afe cold air intake magnaflow exhaust procomp lift icon coilovers
    Hey guys, I was able to crank up my icon coils, found it a little easier as the front end was jacked up. I want to lower the coils about an inch now, would it be easier lowering these coils as it stands? or jack it up as well? thanks in advance.
  7. Mar 27, 2014 at 8:40 AM
    Gabex35
    Gabex35 Well-Known Member
    Gabe
    San Diego
    2020 Tundra Limited 4x4 Crewmax
    always take the weight off.
  8. Mar 28, 2014 at 7:24 AM
    Rezo Rock
    Anaheim, California
    07 PRE RUNNER
    Thanks Gabe! I thought so.
  9. Mar 28, 2014 at 3:46 PM
    GotExhaust
    GotExhaust Well-Known Member Vendor
    Nick
    Soak the threads with WD-40 or silicone lube too, makes it a lot easier. And yes, the wheels must be off the ground don't try to do it with the truck on the ground.
  10. Mar 28, 2014 at 4:02 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    All you guys suggesting to adjust them with the vehicle off the ground are making me feel stupid now :eek:
  11. Mar 29, 2014 at 8:48 PM
    MEMO CAMPOS
    Westminster, Ca.
    05 PRERUNNER
    Well I did it! Not to kick a man while he's down but drooping out the suspension is def. a must. Lol
    I must say it only took 2 turns on the passenger side to achieve my desired setting compared to 5 turns on the driver side! All this to correct the infamous "taco lean". I wish my kings on my 2014 4runner were this easy, what a pain they are having to remove from the truck to adjust.
