How to adjust Morimoto headlights?
Discussion in 'Lighting' started by Bcjammerx, Nov 8, 2020.
  1. Nov 8, 2020 at 7:47 AM
    Bcjammerx
    Bcjammerx [OP] I'm not ALWAYS an a-hole, I swear
    North East Texas
    ‘17 TRD Off-road 4X4
    installed my morimoto led headlights and they are super low. parked beside a car with stock hids and my beams were like 3 feet lower than there’s at 6 feet from the wall. very noticeable while driving
    I can’t find adjustment instructions on their site but I found two 10mm bolts on the back of the housing and I assumed these were the adjustment screws but they didn’t move...stock ones were good height before I removed them
    any advice?
  2. Nov 8, 2020 at 7:55 AM
    GrundleJuice
    GrundleJuice Well-Known Member
    Michigan
    2016 TRD Bro
    [S]Un-Molested[/S] Lightly Molested
    right on their site, last picture of the uninstalled assembly.
  3. Nov 8, 2020 at 6:20 PM
    Bcjammerx
    North East Texas
    so it is! I was looking for it in the install manual
    I’ll give ‘em some more turns I guess
    ready6delta likes this.
  4. Jun 25, 2021 at 2:36 PM
    tclavell
    Troy
    Phoenix, AZ
    G70
    bumping an old thread! Super helpful! My lights were a mess
    Bcjammerx[OP] and FishnTx like this.
  5. Oct 11, 2021 at 3:51 PM
    calicoaran
    calicoaran Well-Known Member
    Daniel
    Albuquerque, NM
    2019 Voodoo Blue 6MT
    How did the adjusting go? I'm in the same boat, were you able to do it without pulling stuff apart?
  6. Oct 11, 2021 at 4:03 PM
    Bcjammerx
    North East Texas
    It was super easy once I found the screws, the pics really help.
    up, down, out, and in. Need to adjust my brights again actually, didn't get them quit right.
    I didn't have to remove the battery or anything, I don't think I removed the washer fluid container...don't recall honestly.
    Just don't adjust them too high...one super dangerous for others and won't actually help you...but also I almost couldn't get them to come back down 0_o I always have weird problems...so you don't have to |-)
  7. Oct 11, 2021 at 8:17 PM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    Read the warnings, likely hard to do once installed. Turning the adjuster more than 3x will break the adjuster. So count your rotations.
  8. Oct 13, 2021 at 5:04 AM
    calicoaran
    Daniel
    Albuquerque, NM
    You're right, it was pretty simple. I removed the bolts from the washer fluid reservoir to give myself a little more room, but I don't think I needed. Warnings on the back of the headlight stated "no more than 3 full rotations." I just kept rotating until they were where they should be (measured at 25ft, 2in below headlight centerpoint). They were wayyyy out of whack. Both beams were around a foot too low. Work great now though. I may go up another inch.
  9. Dec 19, 2021 at 3:16 PM
    MinesBroken
    MinesBroken Well-Known Member
    2016 BBP Tacoma Limited DCSB
    Thanks for this info been trying to figure out how to adjust them and never noticed the photo on the website. Figured it would have been in the installation manual, but it's not. Had a Question. I have my low beams verticaly level with each other now, but I am not sure about horizontally. High Beams are perfect as installed. My lows get this kind of pattern from 25+ feet away. The parking lot is not level thus the reason lows are unlevel on the wall. Middle of pattern looks odd to me - is my horizontal wacked out? Something else?
    GHammer likes this.
  10. Nov 25, 2023 at 5:17 PM
    Cornrower
    Cornrower Well-Known Member
    Mine only have 2 adjustment screws...?
  11. Nov 25, 2023 at 5:38 PM
    Toy_Runner
    Toy_Runner Well-Known Member
    99 4Runner SR5
    3" OME lift, heavy coils f/r 3/16" steel skids Modified Coastal Offroad diy bumper 5spd swap ('98 donor)
    Headlamps are not supposed to have horizontal beam adjustment, so morimoto is likely covering that foe the US market leaving the vertical adjustments for the low and high beams accessible.
    Cornrower likes this.
  12. Nov 25, 2023 at 5:46 PM
    Cornrower
    That makes sense, thanks. I was worried I was sent the wrong headlights on top of having been sent a light with a broken tab. I was able to plastic weld it. I emailed the company but they will probably say I did it, even though the tab was found in the box and I hadn't even began the instal. It's working just fine but kind of annoying.
