How to adjust rear bumper?
Discussion in '1st Gen. Tacomas (1995-2004)' started by snopyro, Sep 15, 2023.
  1. Sep 15, 2023 at 5:54 PM
    snopyro
    snopyro [OP] Well-Known Member
    California
    '03 Limited 4x4 - Black n Tan
    Snugtop shell
    Looks like the driver side bumper edge is closer (less gap) that the passenger side bumper edge. Also, it looks like the black plastic to top does not look to be level on each side as I am seeing rubbing/scratch marks at the very bottom of my tailgate due to opening. I wasn't sure if there was an easy way to push/pull the bumper and possibly adjust the tilt of it as well to lower it to prevent future bottom tailgate contact. TIA!
  2. Sep 15, 2023 at 6:00 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    llRC, the OEM bumper is held on by either four or six bolts. Its brackets are attached to the ends of the frame rails. There should be a tiny amount of adjustment to get it level if you loosen all the bolts a little bit to move it into the position you want.
  3. Sep 15, 2023 at 6:11 PM
    MadJacks
    MadJacks Well-Known Member
    Justin
    Edmonton, Alberta
    2020 TRD Sport MT
    I will also mention that you can loosen all bolts and the bumper won't fall. There is a notch that prevents this. So go nuts by yourself with no PPE, alone in a closed garage :thumbsup:
    Bivouac likes this.
  4. Sep 18, 2023 at 10:58 AM
    snopyro
    California
    Snugtop shell
    lol... thanks! I'll undo the rear bumper bolts and see if I can line up my rear bumper gaps a little better.
  5. Sep 18, 2023 at 11:09 AM
    Bivouac
    Bivouac Well-Known Member
    Northern Lehigh Valley Pa
    2000 Tacoma 5 speed 3.4
    Remains to be seen I bought the tires and wheels the rest came along
    Depending on how perfect it needs to be you might need to grind out the holes to get the final adjustment you need.
  6. Sep 18, 2023 at 1:59 PM
    snopyro
    California
    Snugtop shell
    Makes sense... thanks for that tip, Bivouac!
    Bivouac likes this.
