^^ How To: AEM F/IC-6 Install, Tuning, and Help Thread
Discussion in '1st Gen. Tacomas (1995-2004)' started by mudthedoor, Jul 16, 2015.
  1. Mar 8, 2019 at 12:50 PM
    #181
    Brice
    Brice Turbo Member
    Brice
    Texas
    1999 Tacoma PreRunner V6 SR5
    Wastegate assisted turbo delete
    What was the issue?
  2. Mar 8, 2019 at 2:15 PM
    #182
    evlgsx
    evlgsx Well-Known Member
    2004 SR5 4x4 V6 TRD SC 5spd ExtraCab
    not the o2 issue, post #177
  3. Mar 10, 2019 at 11:21 PM
    #183
    evlgsx
    Going over this wiring and finding zero issues..........beginning to question if this FIC can actually manage this ECU the way we need it to. This has not been tuning.......this is nonsense. Im finding tons of complaining and dead ends everywhere I look when it comes to this AEM unit in the forums. Especially with later Toyota ECUs. Every complaint I find to AEM seems to be combated by their YOUTUBE video on how to setup the FIC on a factory wideband. Ive found several who say they've tried their steps and it does nothing.
    Im still going to spend some time on this thing before I move on to something else. Really hoping Im doing something wrong, but so far its not looking good
  4. Mar 11, 2019 at 10:45 AM
    #184
    TMFF
    TMFF Well-Known Member
    Tim
    Thornton, CO
    01/02 DCLB
    Stuff and junk and things...
    I think there was a option for the O2 skew that had a high drive function. It's been a while since I've been in the software. It made my 01 WB truck react to fuel and O2 changes and was able to do a decent road tune.
  5. Mar 11, 2019 at 10:59 AM
    #185
    BlackSportD
    BlackSportD Well-Known Member
    Los Angeles
    Icon/TC Mid travel, TRD S/C, PNP Greddy EMU, 625cc injectors, 2.2 pulley, Hayden tranny cooler, AEM wideband, TRD boost gauge.
    This. If I remember correctly there is a box you need to check in the O2 settings for these older Toyota widebands.
  6. Mar 11, 2019 at 11:05 AM
    #186
    evlgsx
    There are a few options in the O2 table setup...... You may choose:
    LOAD INPUT:
    -MAP
    -MAF
    -TPS
    -O2
    MODE:
    -Fixed
    -Percent
    -Voltage
    -Offset
    Load Input- I have it with load input based on the AEMs internal MAP sensor.
    Mode- I have tried all 4 modes and get zero results
  7. Mar 11, 2019 at 11:07 AM
    #187
    evlgsx
    There is a box that I have never checked- its labeled high level drive!
    Is this the answer? Sure hope so! Be back soon............
    Rldanie likes this.
  8. Mar 11, 2019 at 11:58 AM
    #188
    TMFF
    Tim
    Thornton, CO
    01/02 DCLB
    That's it, take luck...
  9. Mar 11, 2019 at 12:32 PM
    #189
    evlgsx
    Just checked the box-entered 1 into the o2 table globally as I held throttle at 2krpm and watched AFR jump from 14.7 to 12.5 as I did so.
    Cased closed. All about the check box!
    Thanks TMFF!!
    I will report back with how solid the control is once I have some time too spend on it
    TMFF likes this.
  10. Mar 11, 2019 at 9:07 PM
    #190
    evlgsx
    Seems to be working great now. O2 skewing is dictating afr........and Im using the fuel table to keep stft around zero so it doesnt tell ltft what Ive been up to and ruin everything.
    Hopefully these results hold up.....as long as stft is close to zero, cant see why they wouldnt.
    It was as simple as checking a box. Im really liking that fix.
  11. Mar 11, 2019 at 9:32 PM
    #191
    BlackSportD
    Los Angeles
    I got my FIC many years ago and had to wait for that feature update. Are you running z104 or z110 firmware? When you do a quick throttle blip excelerattion, close throttle then blip again (while rolling) is there a pickup?
  12. Mar 11, 2019 at 9:47 PM
    #192
    evlgsx
    That must have been rough waiting on the feature..........not sure what firmware Im on but I can check tommorow.
    I havent done a whole lot of driving since I was able to setup the AFR/voltage/stft table and really get things going but I was able to get it in the ballpark real quick. I did a few hard tugs 1st through 3rd and it was perfect, no hiccups. Also did a few full third gear pulls with no issues, no laboring pissed off engine.....just smooth boost.
  13. Apr 26, 2019 at 8:20 AM
    #193
    Trim taco
    Trim taco Just one more stupid question
    Bourbon capital of the world
    Was: 96 SR5 5MT Is: 19 OR 6MT
    Bunch 'o random stuff
    I need help with the wiring part pls. I have all the pins located except for this little fella:
    I downloaded the wiring diagram and have looked through the ECM pdf, but AF1+ is nowhere to be found:
    Is this because I have a '96 which is O2 vs the newer models that have wideband? Can someone please tell me which pin to tap for O2 sensor? Thx
  14. Apr 26, 2019 at 8:28 AM
    #194
    TacoBunny
    TacoBunny Well-Known Member
    AZ
    1997 5 Lug 5VZ
    Why not use the Boomslang harness? sorry not trying to be an asshole but im terrible with electrical things and see it as the easiest plug and play work around
  15. Apr 26, 2019 at 10:38 AM
    #195
    Trim taco
    I tried the boomslang. Long story short, it didn't work so I'm wiring it in myself.
  16. May 8, 2019 at 7:10 PM
    #196
    veggiedog
    veggiedog Member
    Bob
    2001 S-Runner
    SC, TrueTrac, BBK (eclipse rotors, CTS-V calipers), 275/50R17 NT555-G2
    No surprise the cam/crank configuration is the hardest set to keep straight...
    because this chart is WRONG!!!! CAM1 MAGI+ is on pin 9 of the FIC-6 24-pin connector, NOT PIN 5 as indicated on line 14. 'AEM Pin' column on line 14 should be 22/9 not 22/5
    Also, this chart is poorly organized as it does not maintain the in/out relationship across the sensors and injectors. For sensors, input from the sensor connects first to the FIC-6, and output then goes to the ECU, but the AEM Wire column is not consistent for sensor intercepts. If you use this table, I recommend changing the intercept specification in 'AEM Wire' column to show which side connects to the ECU (first) and which side connects to the device (last). If you follow the same pattern set by the injector lines (first spec is connected to the ECU), you should change line 9 and line 13. To accomplish that: for line 9, 'AEM Pin' and 'AEM Wire' are better written as '15/14' 'MAF OUT + / MAF IN +', and for line 13 they would be better written as '21/19', 'CRK MAGO + / CRK MAGI +'. Important to note that even if you disagree and would rather 'AEM Pin' and 'AEM Wire' columns instead be organized as first input then output (changing line 14 would follow), the sensor rows are still not consistent, and that makes following that unmodified table more error prone. As a guide, best if it adheres to a pattern...
    FWIW, I am in the middle of enabling the FIC-6 on my tacoma, so I have not tested any of this to ensure my suggestions work, but the table is still wrong. After I complete the install, I'll provide an updated table when I can verify it works.
    -Bob
    elnip and Trim taco like this.
  17. May 10, 2019 at 6:04 AM
    #197
    veggiedog
    veggiedog Member
    Bob
    2001 S-Runner
    My tacoma started right off (well, after I plugged in the ECU connectors when it didn't ;)) with my modified understanding of that table. Furthermore, I am able to start with the bypass harness in place. I am now working on tuning via the software so I will not be working on a corrected table until time and priorities permit.
    elnip likes this.
  18. May 14, 2019 at 12:25 PM
    #198
    austinmtb
    austinmtb Well-Known Member
    Austin
    Southern Oregon
    2004 Toyota Tacoma DC TRD 4x4
    ADS Coilovers & Shocks, All Pro Standard Leafs, TRD Supercharger, Haltech Standalone, URD 2.2'' pulley, Method NV wheels, Copper Discoverer STT Pro tires, ECGS 4:56 gears, custom steel tube bumper, custom steel skid plate,
    Does anybody have info on piggyback wiring harness capability for an 04 taco? In the chart on the first page it's missing info for 03-04.
  19. May 14, 2019 at 12:26 PM
    #199
    TacoBunny
    AZ
    1997 5 Lug 5VZ
    call up boomslang directly and youll know exactly what you need
    austinmtb[QUOTED] likes this.
  20. May 14, 2019 at 12:30 PM
    #200
    austinmtb
    Austin
    Southern Oregon
    Thanks, just checked their website and it looks like they make a plug and play harness.
    TacoBunny[QUOTED] likes this.
