^^ How To: AEM F/IC-6 Install, Tuning, and Help Thread
Discussion in '1st Gen. Tacomas (1995-2004)' started by mudthedoor, Jul 16, 2015.
  1. May 14, 2019 at 12:52 PM
    #201
    austinmtb
    austinmtb Well-Known Member
    Austin
    Southern Oregon
    2004 Toyota Tacoma DC TRD 4x4
    ADS Coilovers & Shocks, All Pro Standard Leafs, TRD Supercharger, Haltech Standalone, URD 2.2'' pulley, Method NV wheels, Copper Discoverer STT Pro tires, ECGS 4:56 gears, custom steel tube bumper, custom steel skid plate,
    To anyone that has switched over from the 7th injector setup to the AEM F/IC-6, did you wire your 7th injector into the AEM unit and ditch the URD controller, or did you just go to bigger injectors? I like that the 7th injector cools the supercharger, it would be a bummer to lose that with the AEM and bigger injectors.
  2. May 14, 2019 at 1:06 PM
    #202
    1997tacomav6
    Denver
    The cooling effect from the 7th injection would be very minimal,
    It’s NOTHING like a methonal kit that lowers temperature by 100 degrees when spraying.
    elnip likes this.
  3. May 14, 2019 at 1:29 PM
    #203
    austinmtb
    Austin
    Southern Oregon
    Although I love the idea of making more power and cooling from a methonal kit, I’m not sure I want that on my daily. Having to refill it all the time seems like it could be a pain. Hence why I’m looking at either keeping the 7th or going to larger injectors.
  4. May 14, 2019 at 1:32 PM
    #204
    elnip
    elnip Well-Known Member
    LC,NM
    '98 Tacoma TRD S/C'd / /'16 T4R Trail
    Taco SC'd, fuel mods, Supra TT MAF, TRD Headers, Water Meth Injection, Tundra Brake upgrade Trail w/URD EL Headers. JFR EL Y-pipe, URD Hi Clearance cat back, KDMAX Tune, 4.56's
    Don't let that hold you back, I put a 2.5 gal tank in the bed and I don't have to refill it often. Meth/water is more than worth it for the power boost, even with bigger injectors which I have.
    austinmtb and 1997tacomav6 like this.
  5. May 14, 2019 at 1:33 PM
    #205
    1997tacomav6
    Denver
    Yes, the methonal is definitely more maintenance, but ALOT of benefits you can’t get otherwise.
    105 octane
    Eliminate pinging
    Drop intake temperature by 100 degrees
    More timing = More power
    Eliminating heat soaked supercharger
    Creates denser air
    Eliminates carbon in the throttle body
    Eliminates carbon in the intake valve section
    Essentially it steam cleans the carbon out of the Piston areas too
    Check out how clean my intake is because of the methanol compared to a non methanol setup.
    And my throttle body is AWAYS squeaky clean with zero build up too, never needs cleaning anymore.
    austinmtb[QUOTED] and elnip like this.
  6. May 14, 2019 at 9:52 PM
    #206
    austinmtb
    Austin
    Southern Oregon
    Might have to seriously consider going this route. I like the idea of putting a 2-3 gallon tank under the bed and running a fill port up to the gas fill door. How much methanol do you typically go through per tank?
  7. May 15, 2019 at 5:54 AM
    #207
    1997tacomav6
    Denver
    It all depends on your engines needs and if it’s supercharged and the amount of extra fuel( methonal) it needs for your application.
    I use my windshield tank, so A gallon will go=
    If you need or use a #1 nozzle probably 1500 miles,
    if you need a #2 nozzle 900 miles,
    a 3 nozzle 500 -600 miles.
    I run a #4 nozzle and need refilling about 400-500. Depending on how heavy your foot is.
    It only is in use for my needs when I hit 4 pounds of boost up. Otherwise it’s not spraying.
    Each engine is different for its needs.
    But I have a 2” pulley, ported supercharger, ported throttle body, 10 pounds of boost, so typically a #4 nozzle would not be used.
    If I keep my boost under 4 pounds I use zero methonal.
    So there are factors to consider
    If your not supercharged a #1 nozzle would probably work,
    I have around 40,000 miles on my methonal kit,
    I can’t say enough good stuff about my experiences with it.
    Wish I had know about it earlier but there was little to zero info
    here about methonal injection and I took a gamble.
    Now there are plenty of members adding the system with all the positive feedbacks.
    This is an excellent fix, but again some motors have issues.
    but unfortunately doesn't deal with tuning the ECU
    There are ping happy motors, no one is sure why,
    But it could be caused by
    Carbon issues in the valves intake and pistons,like the photo posted
    a bad or poor fuel pump pressure issues,
    A bad or poor fuel regulator,
    A dirty fuel filter in the tank,
    A dirty inline fuel filter,
    Dirty fuel injectors,
  8. May 15, 2019 at 8:33 AM
    #208
    1997tacomav6
    Denver
    Add a photo where you put that tank under the frame and supply line for filling
  9. May 15, 2019 at 11:48 AM
    #209
    veggiedog
    veggiedog Member
    Bob
    2001 S-Runner
    SC, TrueTrac, BBK (eclipse rotors, CTS-V calipers), 275/50R17 NT555-G2
    Big smiles after getting my fic-6 wired in an running with a basic setup, most of my SC issues on the stock ECU are gone, only a tiny struggle near redline but I have not done any tuning yet. Truck runs much better: just the automatic maps provide enough tweaks during boost to correct many issues with the stock setup.
    Be aware that the documentation in this thread is out of date, and that the parallel thread on toyota-4runner is more up to date (e.g. cam sensor resistor diagrams in this thread are wrong (didn't work for me on the output side, needed resistor on the input side as documented over there and everywhere else).
    FWIW, the cam sensor modification also needs a capacitor on the output side, IMHO, and I have a 1uF bipolar coming. I stacked up a bunch of ceramics (non-polar) to make 1.2uF, wired across CAM1 MAGO+ and CAM1 MAGO-, and the output signal much more closely matched the input signal in waveform shape (verified on oscilloscope) and amplitude (no more spikes tapering off to visible infinity, instead a signal slightly more erratic than stock but still 'vaguely similar' to stock rather than 'completely different' without the capacitor). I ordered a nice Nichicon non-polar capacitor for permanent installation. I think that is a fundamentally better path but may only affect things like longevity, or nothing at all. Although I am not throwing a code either with just the 2.2k bias resistor installed or both the resistor and makeshift capacitor stack, the stock signal with that resistor installed is a much prettier waveform than the spiked FIC-6 output signal without a capacitor, and the capacitor makes the output signal night-and-day closer to the input signal. Capacitors are a standard way to control exactly that type of spike, I am not sure why they have not been included in the basic AEM design or suggested here (or over there...) with so many references to the youtube video with oscilloscope display of the input/output signals.
    -Bob
    tinkerer
  10. May 15, 2019 at 12:19 PM
    #210
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    I've been keeping up with the t4r guys when it's time to install mine - is there a specific thread that's got the info in it or is it just the sc page?
    1997tacomav6 likes this.
  11. May 16, 2019 at 10:36 AM
    #211
    veggiedog
    veggiedog Member
    Bob
    2001 S-Runner
    From post #8 in this thread:
  12. Jun 18, 2019 at 7:31 AM
    #212
    Trim taco
    Trim taco Just one more stupid question
    Bourbon capital of the world
    Was: 96 SR5 5MT Is: 19 OR 6MT
    Bunch 'o random stuff
    Is anyone running an F/IC on a 95-97 ECM? I'm loosing my frickin mind with this thing ! ! I've triple checked my wiring, everything is wired correctly (as far as I can tell) but the truck will not start with the F/IC plugged in. Does anyone have any suggestions?
  13. Jun 18, 2019 at 7:36 AM
    #213
    1997tacomav6
    Denver
    97 ECU is different than the 95-96 ECU.
    FYI
  14. Jun 18, 2019 at 9:00 AM
    #214
    Trim taco
    Exact same pin-outs, that's what matters here. I'd like to be able to check my wiring against a successful install on a 95-97.
    1997tacomav6[QUOTED] likes this.
  15. Jun 18, 2019 at 9:23 AM
    #215
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    Why won't it start - I mean what is it not doing, cranking, getting spark, fuel, etc?
  16. Jun 18, 2019 at 9:44 AM
    #216
    Trim taco
    It just cranks and cranks. Pull the F/IC and she fires right up. I've had the unit bench tested by AEM, they say it's good to go, which only leaves my splice job. My eyes have crossed from staring at pin-outs.
  17. Jun 18, 2019 at 10:43 AM
    #217
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    You should test to see if it's getting spark and fuel. Basic crank no start analysis can tell you what's not happening to give a better idea of the issue.
    Trim taco[QUOTED] likes this.
  18. Dec 2, 2019 at 9:06 AM
    #218
    00_5VZ
    00_5VZ Dumbest smart guy you’ll ever meet
    Rob
    Thornton, CO
    2004 DC TRD, S/C, Impulse Red Pearl
    TRD S/C, URD 7th injector, Deck plate mod, gray wire mod, 2 low mod, magnaflow cat back exhaust
    So I’ve been going over this thread repeatedly, and I’ve got some questions... more or less want opinions. My last truck was a 2000 3.4 5 speed xtra cab. Had a gray TRD supercharger with a URD 7th, 2.2 pulley, headers, and a magnaflow cat back. I had no complaints with the 7th injector kit, truck always ran great, and I never tuned it, just ran the base map. It would occasionally give me a single ping on a quick downshift followed by WOT, but that was it. I now have an 04 double cab 3.4 auto. It has a black supercharger with a magnaflow cat back. My only noticeable issue is an occasional hard ping after coaxing a downshift, usually after WOT. I’m very interested in the AEM FIC6, but I’m leaning toward the URD 7th mainly because it’s what I’m familiar with. How happy has everyone been with it? Is tuning necessary? Can it run on a base map with little to no issues? I live in Colorado if that helps at all, and I’m not very familiar with the tuning aspect of something like the URD 7th or the AEM FIC6
  19. Dec 6, 2019 at 6:13 AM
    #219
    1997tacomav6
    Denver
    Did you run the base map? For Colorado
    Or did you have to do a bunch of programming?
  20. Dec 6, 2019 at 6:26 AM
    #220
    TMFF
    TMFF Well-Known Member
    Tim
    Thornton, CO
    01/02 DCLB
    Stuff and junk and things...
    FYI There is no "base" map for the FIC6, you build it your self.
    The 7th is more of a install and forget it kind of unit VS building a map and for the most part constantly making small adjustments to the AEM.
