^^ How To: AEM F/IC-6 Install, Tuning, and Help Thread
Discussion in '1st Gen. Tacomas (1995-2004)' started by mudthedoor, Jul 16, 2015.
  1. Apr 15, 2021 at 10:40 AM
    #301
    TacoBike
    TacoBike The Researcher
    Mason
    Shingle Springs, California
    2000 3.4 Ext Cab TRD 4x4 with original SC
    ARP head studs Supercharger FIC6 AFR gauge painted fenders audio install
    Can someone send in their Setup page for a narrowband O2? I am trying to help a friend get the aem working on their truck and I have not done a narrowband before. Also something to be useful would be a narrowband to afr conversion table. Thanks!
    @elnip @Shortman5 (dont know any others with pre 2000 trucks)
  2. Apr 15, 2021 at 11:18 AM
    #302
    Jon64l
    Jon64l Well-Known Member
    Jon
    2000 4runner, 1996 Tacoma
    Open your software and plug into your 6. Go to Setup. Look what I had in there
  3. Apr 15, 2021 at 12:28 PM
    #303
    TacoBike
    Mason
    I dont understand what you are saying here. I cant open it up right now because the friend I am helping is a couple of hours away from me and I am trying to double check the settings I had. I thought the only one that changed was the o2 max voltage is 1.01 instead of 4.95? Are you referring to a post you put up that I missed?
  4. Apr 15, 2021 at 1:30 PM
    #304
    Jon64l
    Jon
    Whoops, thought you were the guy I sold my 6 to. My bad.
    Yeah I think max is 1.01 and min is .1.
  5. Apr 15, 2021 at 5:46 PM
    #305
    TacoBike
    Mason
    Nope, and thanks btw. high level drive should be on for narrowband, yeah? I was getting a problem of it would start and run stock with the jumper, and it would start and run with no values but when i put in voltages, it would either go under 10.5 or super lean. There was like only one voltage that was close to 14.7 but I cant tune off of that. I'm hoping it was the wiring and not the ecu being a t100 stopping us.
  6. Apr 15, 2021 at 5:55 PM
    #306
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
  7. Apr 15, 2021 at 6:01 PM
    #307
    Jon64l
    Jon
    High level is for stock wide band O2. I do not use it on my narrow band truck.
    The T100 ecu might be culprit. My truck is a 96 and that ecu can't be boosted. I had to switch to a 97. No voltage adjustment the truck should run "stock". I use offset mode.
  8. Apr 15, 2021 at 8:09 PM
    #308
    TacoBike
    Mason
    Anything different about tuning in offset mode? My friend said that the 97-98 ecus are a lot easier to tune so I think it should work. Maybe with those settings changed it will work. Though we werent getting a continuity reading from before the resistor to the sensor... Might have been just resistance. He also had the rear o2 wired into the aem.
  9. Apr 15, 2021 at 8:16 PM
    #309
    Jon64l
    Jon
    No rear O2 here.
    Idk about the different modes, I watched a video that said offset mode so that's what I've been doing since. There is a test you can do to give a approx afr to voltage offset. Don't forget about the accelerator pump feature once you get some good steady state ratios in. Helps with tip in immensely.
  10. Apr 15, 2021 at 8:29 PM
    #310
    TacoBike
    Mason
    Cool thank you, I think ity might just work, update in a couple weeks when i see him next
  11. Apr 15, 2021 at 8:49 PM
    #311
    Jon64l
    Jon
    Are they SC or turbo? Other supporting mods?
  12. Apr 22, 2021 at 6:07 PM
    #312
    TacoBike
    Mason
    Sorry didnt see this. Mostly only pay attention to pings. He is SC with 320cc injectors and a larger fuel pump. It is 1 cat and we did wire in the 10k ohm resistor in series before the tap of the wire. I tried scaling the fuel map and putting in a conservative timing map (nothing touched near idle or really under boost). It did change afr but was extremely sensitive and only had one value where it was near 14.7. Any lower of a voltage and it was 10.5 or lower. (like .01 V lower) higher and it went super lean.
    He didnt go through any of our threads beforehand and only followed the aem manual so I am going to wire it with 0 extra wires into the aem and check the entire wiring on it. (hardwired into the truck.)
  13. Apr 23, 2021 at 7:01 PM
    #313
    Jon64l
    Jon
    @TacoBike
    O2 skew is pretty sensitive. Try moving the 3rd digit. -.402 to -.406 ect.
  14. Apr 23, 2021 at 8:47 PM
    #314
    TacoBike
    Mason
    Problem is that the AEM wont go any more specific, it only goes every .02V else I would and say it works. Maybe it was because of the high level drive that it wouldnt for me?
    If you have one for a narrowband, can i see your O2 to afr table? Not to copy but to figure out what I was thinking was right
  15. Apr 23, 2021 at 10:05 PM
    #315
    Jon64l
    Jon
    @TacoBike
    You must be in a different mode than me or have another issue to sort. I use Offset mode. Negative(-) must be applied to each cell you wish to modify. -.402 probably does close to nothing but I use it any way as the start of my ramp. -.406 starts visible closed loop o2 enrichment. As the number gets bigger (more Negative) the O2 keeps getting richer. The higher the boost is in closed loop mode, the higher (more Negative) number is used in those cells. It is very easy to over fuel here. One trip up a slight grade and you will be back in the maps asap. Once dialed it works very well and rewards you with lots of part throttle passing torque.
    Narrow band does not use high level drive.
    My values probably won't work well for you anyway. I'm running a turbo so it is not as instant as a SC. But this gives you a idea. This was a guess tune, I needed to build a map quickly and go from there with real data.. Also my 2nd o2 sensor is not hooked up to Fic, so ignore those values.
    TacoBike and Dalandser like this.
  16. Apr 25, 2021 at 3:03 PM
    #316
    TacoBike
    Mason
    Hes got it working but the resistor for the cam circuit and the diagram is not working for him now... Dont know if its because of wiring or something else. Thanks for the photos. They made it a ton easier to understand
  17. Apr 25, 2021 at 8:55 PM
    #317
    Jon64l
    Jon
    @TacoBike
    Weird, I'm not using the cam circuit.
  18. Apr 25, 2021 at 10:07 PM
    #318
    TacoBike
    Mason
    Like not at all to fix the code? Or not wired in in any way? Would that work?
  19. Apr 26, 2021 at 1:00 AM
    #319
    Jon64l
    Jon
    It's not wired in.
  20. Apr 26, 2021 at 8:47 AM
    #320
    TacoBike
    Mason
    So it only needs the crank sensor signal, not the crank?
