^^ How To: AEM F/IC-6 Install, Tuning, and Help Thread
Discussion in '1st Gen. Tacomas (1995-2004)' started by mudthedoor, Jul 16, 2015.
  1. Aug 7, 2015 at 7:38 AM
    kigmob
    kigmob Well-Known Member
    James
    New Orleans
    97 TRD S/C 4x4 V6 5spd
    ICON/TC TRD Supercharger URD 2.2 and 7th
    I am curious about this resistor deal. If I don't get any codes, does that mean the signal to my piggyback is probably ok? Or would a resistor help smooth things out? I do not have the AEM unit but I'm thinking maybe a resistor would help smooth the signal to my URD unit and help make the timing tune more effective? Or does this not make sense? lol
    mudthedoor[OP] likes this.
  2. Aug 7, 2015 at 8:48 AM
    StAndrew
    StAndrew Wait for it...
    Hampton Roads, Va
    SR5 4x4TRD
    Intake, exhaust, lift. Typical stuff.
    Resister just cleans up the signal for the ECU. If you run the AME FIC without one, you may through an engine code. Gadget is right in saying the MAP ECU plays better than the AEM FIC but a simple resistor fixes that so not really an issue IMO.
  3. Aug 9, 2015 at 3:26 PM
    mudthedoor
    mudthedoor [OP] Sconnie
    Alex
    Forestville, WI
    00 4Runner
    Yes but I haven't posted them here if you go over to T4R.org you can check them out
  4. Aug 24, 2015 at 9:26 AM
    mudthedoor
    Alex
    Forestville, WI
    00 4Runner
    Just updated the install instructions my previous Pinout chart was Fubar for the cam/crk signals. All fixed!
  5. Aug 24, 2015 at 9:28 AM
    StAndrew
    Hampton Roads, Va
    SR5 4x4TRD
    How are you tuning? I have an OBDII connecter but haven't found a decent/affordable software to monitor and map engine parameters. Im still not sure if Im going to try to tune myself or get someone to dyno tune.
  6. Apr 6, 2016 at 8:36 AM
    TMFF
    TMFF Well-Known Member
    Tim
    Thornton, CO
    01/02 DCLB
    Stuff and junk and things...
    Bump!
    I ordered the AEM FIC, hope to install and tune this spring before wheeling season gets going.
  7. Apr 6, 2016 at 8:38 AM
    mudthedoor
    Alex
    Forestville, WI
    00 4Runner
    Let me get this updated then! I havent been updating Tacoma world thread
  8. Jun 9, 2016 at 1:39 PM
    TMFF
    Tim
    Thornton, CO
    01/02 DCLB
    BUMP!
    I got mine installed and running with no issues. I just need to find some time to start road tuning.
    boostedka likes this.
  9. Jul 30, 2016 at 8:46 AM
    mtnkid85
    mtnkid85 Well-Known Member
    MT
    1999 TRD Taco
    35s, Locked, blown
    How is the AEM fic working for you guys? Im contemplating ordering this to setup a S/C on my 99 manual Tacoma.
    Tim, how has the tuning been coming?
  10. Jul 30, 2016 at 9:30 AM
    TMFF
    Tim
    Thornton, CO
    01/02 DCLB
    It's coming along. I just need to fine tune my O2 map to screw it when I'm at higher elevation as the absolute psi the FIC sees is lower than the psi I see on the Guage. So when I'm pulling hills at 65 it's a little leaner than I like to see.
    Definitely way better than the split second unit.
  11. Jul 30, 2016 at 1:28 PM
    Sicyota04
    Sicyota04 Slowly but surely.
    Morgan
    California
    04 DC 4x4
    I didn't see anything in the list for an 04 Tacoma 3.4 like mine. It only went to a 2002.
  12. Jul 30, 2016 at 6:24 PM
    x2468
    x2468 Well-Known Member
    '02 TRD 4wd V6 Xcab Sr5
    Would this unit work on a turbo?
    Is there any tuning unit that I could use to make the stock engine quicker? Maybe with different timing?
  13. Jul 31, 2016 at 5:50 AM
    TMFF
    Tim
    Thornton, CO
    01/02 DCLB
    It's will work just fine, you might have to wire it in instead of a boomslang harness.
    Turbo yes
    Stock probably not much. The FIC only takes out timing.
  14. Aug 2, 2016 at 3:11 PM
    BlackSportD
    BlackSportD Well-Known Member
    Los Angeles
    Icon/TC Mid travel, TRD S/C, PNP Greddy EMU, 625cc injectors, 2.2 pulley, Hayden tranny cooler, AEM wideband, TRD boost gauge.
    Been rocking mine for years, just went off-roading with the T4R guys (see wheeler anonymous thread) in big bear. I don't go into boost much at all at sea level and wheeling, but up in the thin air, I notice it wanting to boost to move out of it's own way.
    I'm actually sitting on the parts to move over to an EMU setup, I just like the EMU more so finally broke down and get a split second part to handle the closed loop o2 signal. IMO the EMU will fix the cam/crank signal issues the FIC has, and I get ping when my auto tranny shifts (OEM ECU advances timing when shifting). The FIC has timing retard just in mapping like for fuel, but the EMU has an additional tranny shifting timing retard feature I hope will dial this away.
  15. Sep 22, 2016 at 7:57 PM
    #35
    Clay_916
    Clay_916 Well-Known Member
    Fort Collins, CO
    2000 x-cab 4x4
    5100's, All Pro 3" Standard leafs, 32" KM 2's
    Anyone still around from this topic? I'm looking at the diagram for the 2.2k resistor and it does not match the description which says to put the resistor between the CAM MAGO - and the CAM MAGI +.
    The diagram shows the resistor between cam magi -, crk magi - and the cam mago + which seems kind of ludicrous to me. I'm assuming the description above is accurate? Also, has anyone actually done the described method and can report it actually works? Seems strange to have the resistor in parallel with the fic. A bit rusty on circuits but isn't that sending both the modified and un-altered signals to the pcm? Would it not be better to use a much smaller resistor in series with the fic and pcm?
  16. Sep 22, 2016 at 8:07 PM
    #36
    TMFF
    Tim
    Thornton, CO
    01/02 DCLB
    I did as you described, - to + on the mag circuit. I too thought it was wrong but have had zero issues since installing the fic.
  17. Sep 22, 2016 at 8:14 PM
    #37
    Clay_916
    Fort Collins, CO
    2000 x-cab 4x4
    Thanks for the quick response! I also noticed the typical scheme of using "I" or in wires to recieve the signal at the FIC and "O" or out wires to send the altered signal to the pcm but with the injector wires its backwards from that in the AEM directions. Did you follow their directions of this step and did it work ok?
  18. Sep 22, 2016 at 10:30 PM
    #38
    TMFF
    Tim
    Thornton, CO
    01/02 DCLB
    I did, I got the first couple of injector wires wrong but looked at the wiring diagram and corrected my mistakes. Take your time and it will all work out. What year truck do you have? My 01 didn't need the O2 resistor just some time in road tuning.
  19. Sep 23, 2016 at 9:43 AM
    #39
    Clay_916
    Fort Collins, CO
    2000 x-cab 4x4
    2000. Is yours narrow or wideband? I have 2 narrow band sensors and I'm a bit hung up on how to wire them. I'm assuming the second needs to read something different than the first or it will throw a code so I can't feed the fic's altered signal to both pcm inputs but if I just leave the second sensor alone it's readings will be wildly off from the altered first sensors and may throw a code as well.
  20. Sep 23, 2016 at 2:19 PM
    #40
    TMFF
    Tim
    Thornton, CO
    01/02 DCLB
    my 01 is a wideband so i didn't need the resistor on the O2. You are only working with the front O2 to tune the truck, the rear is just a tattle tale that your cats are working properly. You will need an aftermarket wideband O2 to tune your truck properly.
    Clay_916 likes this.
