^^ How To: AEM F/IC-6 Install, Tuning, and Help Thread
Discussion in '1st Gen. Tacomas (1995-2004)' started by mudthedoor, Jul 16, 2015.
  1. Oct 11, 2017 at 9:44 PM
    #81
    Phessor
    Phessor Well-Known Member
    Bob
    1998 TRD XTra Cab
    Stuff
    I'm running 91 octane
  2. Oct 11, 2017 at 9:52 PM
    #82
    Brice
    Brice Turbo Member
    Brice
    Texas
    1999 Tacoma PreRunner V6 SR5
    Wastegate assisted turbo delete
    That's so strange. I'm running 10psi with no meth and I'm taking out .25 degrees of timing out per pound of boost and I have no pinging...
    Forgive me for my not knowing, but when does the SC start building boost?
  3. Oct 11, 2017 at 10:10 PM
    #83
    Phessor
    Bob
    1998 TRD XTra Cab
    Stuff
    1/4 to 1/3 throttle at any rpm
  4. Oct 11, 2017 at 11:27 PM
    #84
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
  5. Oct 12, 2017 at 12:13 AM
    #85
    1HItaco
    1HItaco Well-Known Member
    is the boomslang wire harness worth the price?
    will i need to wire anything else into the AEM FIC-6 controller? as far as the standalone AFR gauge goes for tuning purposes does that need to be connected to the aem FIC controller also?
    dont want to purchase the plug and play harness and need to splice "extra" things/components to the harness anyway afterwards?
    Rldanie and Dalandser like this.
  6. Oct 12, 2017 at 6:45 AM
    #86
    kigmob
    kigmob Well-Known Member
    James
    New Orleans
    97 TRD S/C 4x4 V6 5spd
    ICON/TC TRD Supercharger URD 2.2 and 7th
    Read my post on pg 4 regarding how the ecu controls timing. The meth may be why he could ping before boost.
    I actually have to pull 1-2 degrees from -4 inhg to 0 psi. If I'm crusing in 5th below 3000 rpms and slowly accelerate, I get a couple light pings in the vacuum region right before boost. I may just have one of the "ping happy" trucks but I don't think this is the case as I have generally no ping in boost. This I why I changed my driving habits to avoid "lugging" it. I downshift a bit more than I used to. I also try not to boost heavily until I am at 3000 rpms. I can avoid most of the ping this way.
    Phessor likes this.
  7. Oct 12, 2017 at 12:42 PM
    #87
    elnip
    elnip Well-Known Member
    LC,NM
    '98 Tacoma TRD S/C'd / /'16 T4R Trail
    Taco SC'd, fuel mods, Supra TT MAF, TRD Headers, Water Meth Injection, Tundra Brake upgrade Trail w/URD EL Headers. JFR EL Y-pipe, URD Hi Clearance cat back, KDMAX Tune, 4.56's
    Just for the record here, I do not have any retard set in my tune. Having said that, I am at 4000ft (which helps) and only run about 25-30% methanol in my WI system.
    Brice likes this.
  8. Oct 12, 2017 at 3:35 PM
    #88
    Brice
    Brice Turbo Member
    Brice
    Texas
    So just to give a baseline from us turbo guys, we don't have to subtract timing until boost, and even then most guys aren't subtracting it until mid boost. @vasinvictor ran 9psi and never retarded timing and some turbo guys even talk about adding timing with e85, so im not real sure whats going on with the SC'd 5vz's
  9. Oct 12, 2017 at 4:10 PM
    #89
    Clay_916
    Clay_916 Well-Known Member
    Fort Collins, CO
    2000 x-cab 4x4
    5100's, All Pro 3" Standard leafs, 32" KM 2's
    Read up on how roots super chargers work. We're talking about 10 psi at 1000 rpms. Ping-fucking-city.
    And for the record the stock ecu pulls quite a bit of timing even NA on those hotter days. I would say at around 12 psi on the stock timing map you would start to detonate in the worst external conditions. The 5vz has relatively high compression so you definitely need to pull more than the 1 degree per psi rule of thumb. The reason most people can get by without it is because the stock ecu can pull up to 30 degrees which is evidently sufficient for 10 psi, intercooled but not 10 psi from a roots SC.
    I have "zero'd" my timing map on e85 but the ecu is certainly pulling a lot of timing. I would say about 15 degrees at 13 psi, 85 F ambient.
  10. Oct 12, 2017 at 4:39 PM
    #90
    Brice
    Brice Turbo Member
    Brice
    Texas
    I was assuming they just made hot boost at low rpms.
    I mean a standalone will solve everyone's problems right? :D
    Well if there was a meth kit that was based off TPS that would work alot better for the SC guys. Also I believe I'm 24 degrees adv at 4.5psi which seems pretty good. (EDIT: it should be like 28.75 degrees advanced but I think the ECU pulls a little bit more for some reason)
  11. Oct 12, 2017 at 5:40 PM
    #91
    kigmob
    James
    New Orleans
    Exactly. The roots blower is essentially setting up the engine to ping. I generally follow the 1 degree per lb of boost rule or more, below 3000 rpms. But above 3000 rpms I'm probably closer to 1 psi or less per lb of boost. Once the knock sensors take over, they should be able to manage most of the knock.
    Dalandser likes this.
  12. Oct 12, 2017 at 5:45 PM
    #92
    kigmob
    James
    New Orleans
    Yea throttle position makes a big difference for us SC guys. That's essentially what controls boost. Holy crap, at 4.5 lbs of boost your timing advance is at 24 degrees? Is this just reading from an obd scan tool? I see 24 degrees at light acceleration. I just posted the other day in a T4R thread because I feel like my ecu pulls too much timing. In boost my scanguge says my timing is ~10 degrees. Then I have to factor in the timing I am pulling with my piggyback. So I'm probably in the single digits... was hoping to figure out if something Is wrong or if this is normal for SC 5vz
  13. Oct 12, 2017 at 5:54 PM
    #93
    Phessor
    Bob
    1998 TRD XTra Cab
    Stuff
    The only time I get a small ping is when I approach a hill that normally would not require down shifting and I leave it in 5th gear.
    If I depress the gas pedal and go into boost the ping goes away. Or if I down shift and raise the rpm's it goes away.
    But even a small amount of pinging will raise my cooling temp by 2° and once it has raised it by 4°. I have gotten to the point of being afraid to listen to music loud and missing the pinging.
    kigmob likes this.
  14. Oct 12, 2017 at 5:54 PM
    #94
    Brice
    Brice Turbo Member
    Brice
    Texas
    I'm honestly not sure if something is wrong or not...And you have to consider every year of ECU tends to handle things a bit differently, but most major function occur at the same time (open loop is an exception and seems to be based off of RPM for some and TPS for other year models) I know with the AEM I can read accurately the amount of timing I actually have, like if I pulled 10 degrees the scangauge would go from 30 degrees advanced to 20 degrees advanced. I could get some screen shots of my timing map if you want. Usually at light load (3000<) I'm around 34-26 degrees advanced.
  15. Oct 12, 2017 at 7:10 PM
    #95
    Clay_916
    Fort Collins, CO
    2000 x-cab 4x4
    You're looking at it wrong. If you pull timing in the FIC you will get timing back in the ecu. By how you're describing it it sounds like you are running at 5 degrees advance which is 25 retard which is pretty dangerous. When people are talking about timing it's generally at WOT and maximum load for the record.
  16. Oct 12, 2017 at 7:43 PM
    #96
    Brice
    Brice Turbo Member
    Brice
    Texas
    I'm not even sure how arrived at that first conclusion... When the scan gauge reads a positive number, say 25, that means 25 degrees advanced. When it reads a negative value that means retarded. Also what does "If you pull timing in the FIC you will get timing back in the ecu" mean? if I take that at what I think it means, it means that if I subtract a degree in the AEM I add a degree in the ECU, which isn't true since the AEM can only subtract timing.
    And why would people only talk about timing at WOT and full load? I was just describing to kigmob the timing behavior I see on my truck during cruising.
  17. Oct 12, 2017 at 7:56 PM
    #97
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    Y'all making me second guess buying a sc. Are the extra beans worth it to you guys - that's almost a redundant question since you all have them (minus the turbo guys so just @Phessor lol)
  18. Oct 12, 2017 at 7:59 PM
    #98
    Brice
    Brice Turbo Member
    Brice
    Texas
    I think second gens have some better tuning options through URD, but I would always want to turbo a first gen vs supercharging one. You just have so much more room to make power with a turbo :D
    elnip and Dalandser[QUOTED] like this.
  19. Oct 12, 2017 at 8:00 PM
    #99
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    My thing is I just want a small amount of power to overcome frictional forces in the drivetrain. I think the stock pulley should work for me.
  20. Oct 12, 2017 at 8:02 PM
    #100
    Brice
    Brice Turbo Member
    Brice
    Texas
    If you just want a little boost in power and don't have a power goal in mind, a SC is just fine, but personally I would never feel right about shoving that hot air into my motor :D
    Dalandser[QUOTED] likes this.
