how to air condition my shop
Discussion in 'Off-Topic Discussion' started by KPT, May 19, 2012.
  1. May 19, 2012 at 8:35 PM
    KPT
    KPT [OP] sees what you did there.
    09 Prerunner
    Hello, it was recently brought to my attention that some plans of mine may viloate building code and I wanted to get some more clarification.
    I have a 3 garages, a two car non-insulated garage, and a one car insulated one. I am turning the one car garage into a shop/man cave.
    I would like the shop to be climate controlled. I was planning on running a duct t'ed off of my living space to the shop. A couple of folks on here mentioned that that may be against code because CO would now have a direct route into the living space.
    However I know that garages are converted into rooms all of the time. So my question is: who decides if it's a room or not?
    The shop will never have a car in it while I'm living here. As I noted, I have two other garages. It has hand tools, an air compressor, tv, fridge, etc. no vehicles, no harsh chemicals. So while I'm living here, for all intents are purposes, it is a room, not a garage.
    When I move out, could I just disconnect the duct work, and put a plate over the hole in the ceiling of the shop, so that it meets code if the next owner wishes to use it as a garage? That way it would not be endangering them should they store a vehicle in it.
    Any comments or suggestions are appreciated.
    EDIT:
    So in summary of all the posts, I cannot hook it up to the central AC of my home without jumping through alot of hoops it seems.
    So now the question of this thread becomes: i want to cool the shop. I want to do it as inexpensively, and with modifying or cutting/drilling as little as possible, and without violating any code. What method should I use?
    The alternatives proposed have been:
    1. window units - I do not have a window, and I am not willing to cut a large hole in an exterior wall.
    2. portable AC unit - I've heard they perform questionably, but I'd like to hear input from someone who has one. Also wondering if I can run the exhaust into the attic rather than cutting a hole in the wall or door.
    similar to this one:http://www.google.com/products/cata...=X&ei=KSG5T7aZGpP4sQL9ppmLDA&ved=0COEBEPMCMAE
    3. ductless AC units - the most intriguing so far. Wondering if I can do this myself or if it would need professional installation.
    any others?
  2. May 19, 2012 at 8:37 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    IIRC, If its connected to the main HVAC of the house, its considered a "Living Area", and must be permitted before being built. The up side, is that the square feet are added to the house and can increase proppertiy value.
  3. May 19, 2012 at 8:38 PM
    KPT
    09 Prerunner
    Well it's obviously already built....the square footage increase is also a pro I was going for.
  4. May 19, 2012 at 8:40 PM
    KPT
    09 Prerunner
    Also if anyone has any suggestions on alternative methods of cooling, I'm all ears.
    The problem is that I don't have a window to run any sort of drain for a portable unit out.
  5. May 19, 2012 at 8:41 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Can you install a roof mount unit?
  6. May 19, 2012 at 8:41 PM
    Deercantseeme
    Deercantseeme Well-Known Member
    Colorado
    afe intake, jvc kw-r5000, Bhlm, true btlm, Ipcw black third brake light, avs slim in channel window visors, wade floor mats, ome 884s, dakars, tinted windows, black wet okole seat covers, debadged, grillecraft insert, matte black SCS F5 wheels, 285 duratracs
    Talk to local code enforcement without being specific as to who you are or where you live. Every state is different. That would be what I would do in your situation.
  7. May 19, 2012 at 8:43 PM
    KPT
    09 Prerunner
    I dont know anything about them. How do they work?
    I take it that would cost more than the $200 I had budgeted for the duct work project? :(
    I do have a large attic above the shop, is there some way I could mount something up there?
    True true.
  8. May 19, 2012 at 8:45 PM
    DEEVON911
    DEEVON911 Semi-Pro
    Dave
    Bethel Park, PA. Burb of da Burgh.
    2010 MGM Mostly Stock Off-Road 4x4
    TRD Cat-back Exhaust. Semi-Debadged. Trimmed down stock Antenna. Weathertech vent visors. TRD FJ Cruiser Center Cap Wheel Mod. 265/75/16 Firestone Destination A/T,s . Inverter tapped into for outlet in cab. Tacomaworld sticker which adds 5 hp.
    Ya Keith, like I and someone else said, probably not a bad idea to call local code enforcement, or even insurance co to see what they say. But there are cooling options, I know they make a/c units for just your type of situation. I don't know what they are called, but I have seen them. Like a mini system of sorts.
  9. May 19, 2012 at 8:52 PM
    KPT
    09 Prerunner
    Thanks Dave.
    Sounds expensive :(
  10. May 19, 2012 at 8:57 PM
    DEEVON911
    DEEVON911 Semi-Pro
    Dave
    Ya I don't think cheap. My parents checked into it last year cause they have hot water heat. So instead my dad took out a window and permanently installed a window a/c. Which if you want to put a hole in a wall, that could be an option.
  11. May 19, 2012 at 8:58 PM
    rwhite188
    rwhite188 Well-Known Member
    Ray
    Texarkana, Ar
    2011 PreRunner TX Pro TRD
  12. May 19, 2012 at 9:02 PM
    KPT
    09 Prerunner
    My HOA will not allow window units.
    Hmm, that's interesting, thanks for the link. The house is brick so I'm not real keen on drilling into the outside myself. But a quick google search shows that the systems aren't that expensive.
  13. May 19, 2012 at 9:07 PM
    DEEVON911
    DEEVON911 Semi-Pro
    Dave
    Ya, that's it! That's what I was thinking of.
  14. May 19, 2012 at 9:09 PM
    jgwheeler17
    jgwheeler17 I'm a zit. Get it?
    NC
    07 Double Cab TRD Off-Road 4x4
    tint, dents, scratches, two blown speakers and trying to pay her off...
    sub'd just out of interest.
    :popcorn:
  15. May 19, 2012 at 9:11 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Un subbed....Im pretty much too drunk to add anything of importance right now.
  16. May 19, 2012 at 9:13 PM
    berg2065
    berg2065 Well-Known Member
    Phoenix
    11 reg cab 4x4
    5100's set at .85,eibachs, LR uca's, toytec 1.5" aal, ride rite bags, receiver hitch, ARE cap with bedrug, Thule rack, wet-okole cover, ultragauge, kenwood dnx5180 navi/receiver, ss rubi404 running factory doors and JL8
    Maybe contact a local HVAC contractor in your area that does free estimates and have them come out and see how they would go about heating/cooling the area. You could have a couple of different companies out to get a feel of the direction that you need to go to get the results and still comply with local codes.
  17. May 19, 2012 at 9:16 PM
    rwhite188
    Ray
    Texarkana, Ar
    Your welcome... Just be sure to check your HOA.. Some HOA's seem to think these are window units too. I love not having a HOA now.. I live on a small circle and there are only 4 houses on it and all of us owners seem to think alike and do not want our yards to look trashy. anytime anyone wants to do something new we just have a little get together and discuss it.. It works out great..
  18. May 19, 2012 at 9:33 PM
    KPT
    09 Prerunner
    Stupid question: why couldn't I put the "outside" part of the unit thats in the video up in the attic, and run a drain hose through one of the many attic vets I have under the eaves of the roof?
  19. May 19, 2012 at 9:39 PM
    jjew18
    jjew18 the Nightman cometh!
    Alliance Airport
    05 PreRunner SR5
    Added extra awesomeness to its original awesomeness.
    Window unit possible?
  20. May 19, 2012 at 9:52 PM
    KPT
    09 Prerunner
    1. No window
    2. HOA won't allow it
