How To: AirFlow Snorkel Install
Discussion in '2nd Gen. Tacomas (2005-2015)' started by lemons, Jul 27, 2016.
  1. Jul 27, 2016 at 5:17 PM
    lemons
    lemons [OP] LOCO 4X4
    Virginia
    07 TRD DC Offroad 4X4
    Icon coil overs W/King 14 inch 700lb springs and super bump bump stops, Allpro Expo leaf springs, Allpro Ubolt kit W/timbren Bump stops, Dif Drop Kit, Magnaflow Cat-Back Exhaust, Badges painted Rust-Oleum bed liner, Color Matched TRD Sport Grill W/Grille Craft Insert, TRD seat covers, Weather Tech Floor Mats, Flyzeye's , fog light anytime mod, ABS Off mod, ATO skid plates, ATO rear H/C bumper, BAMF sliders w/kick out, CBI front bumper, Engo 10000lb winch, Rigid D2 foglights, Piaa 510 fog lights, cobra CB w/firestix antenna, AFE snorkel
    I will start this the same way the Safari snorkel how to was started.
    First- get over the fact that you are about to drill a big ass hole in your fender.
    After you take a big breath and suck it up put painters tape on the fender and cut out the template. Line it up and tape it in place.
    I used a razor blade and cut the + marks (where to drill)so I can mark the spots with a pencil. I then double and triple checked.
    Then I center punched the big hole and drilled it out with a 105mm/4 1/8inch hole saw.
    DO NOT DRILL THE OTHER HOLES YET!!!
    Now put the studs in the snorkel. I put some grease on the ends of the studs and lined it up and put the snorkel in position marking the tape with the grease from the studs. I found that the marks were way off on all but one of the studs. I did this three times making sure it was right. Then I center punched the spots and drilled.
    I then cut the metal support that is behind the big hole to make room for the tubing behind the fender. I went in through the hole for the top of it and under the fender to get to the bottom of the bracket.
    Then I test fit everything. The elbow wouldn't fit in the stock intake hole so I used a heat gun on the elbow with the clamp around it. Heat a little, tighten, heat, tighten, etc. until it fits.
    I also cut off a piece of the stock filter tube
    I then took it back off and started installing it for real. I sealed the studs and installed the snorkel body on the fender then the washers and nuts on the studs. The top most stud nearest to the door sucks. I put tape on the washer to hold it in place then loosened the top bolts that hold the fender on to make a little more room. I then used a ratcheting wrench to get the nut started. After that I got all the elbows and tubes connected and sealed then tightened the clamps.
    For the A pillar I used military grade Velcro (there's no fuzzy side) to Secure the bracket to the A pillar
    Then put the scoop on and drink a beer.
    I hope this helps.
  2. Jul 27, 2016 at 5:25 PM
    Gearheadesw
    Gearheadesw must modify
    Davenport Fl
    1 truck 1 car 1 motorcycle
    Thanks for the time and the pics. Helpful.
    lemons[OP] likes this.
  3. Jul 27, 2016 at 5:46 PM
    la0d0g
    running for the hills
    For crawling not hauling
    No mention of cutting off the old intake curve. Did they change the design so its no longer required?
    Pirhett and lemons[OP] like this.
  4. Jul 27, 2016 at 6:10 PM
    lemons
    Virginia
    Forgot about that took a pic too.
    Edit- I added it to the thread
    la0d0g likes this.
  5. Jul 28, 2016 at 10:12 AM
    bski22
    bski22 Shaka Zulu \000/
    Rob
    Toyota
    Nice work
  6. Jul 28, 2016 at 10:14 AM
    taczilla
    taczilla I intend to live forever; so far.... so good!
    Marc
    PEC, Ontario, Canada
    2016 RAM Rebel
    2012 TRD Sport - STOLEN! / 2016 RAM Rebel
    Nice!
    Where did you get that Velcro?
  7. Jul 28, 2016 at 10:40 AM
    lemons
    Virginia
  8. Jul 28, 2016 at 10:41 AM
    taczilla
    Marc
    2016 RAM Rebel
    Thanks!
    Now I just need to hear about my snorkel... :frusty:
    lemons[QUOTED][OP] likes this.
  9. Jul 28, 2016 at 4:35 PM
    Garfish307
    Garfish307 Well-Known Member
    Katy, TX
    2014 Tacoma 4x4 Texas Edition
    Flux Capacitor
    I found this write up which was very informative...FYI yall
    https://www.itapestore.com/3M-Dual-Lock-Guide_ep_49-1.html
    also this tech data explains different densities and density combinations for maximum strength (250/400) appears to be the strongest:
    http://multimedia.3m.com/mws/media/564564O/dual-lock-reclosable-fasteners-sj3872-sj3870-sj3871.pdf
    Camel51 likes this.
  10. Jul 28, 2016 at 5:23 PM
    TYetti
    TYetti 4cylinders of awesomeness
    Mat
    Abbotsford, BC, Canada
    09 Tacoma AC 2.7L 5spd 4x4
    I never thought about velcro for the a pillar I just used some 1" self toppers and filled the holes full of silicone
  11. Jul 28, 2016 at 9:37 PM
    Sna
    Sna Well-Known Member
    Alberta
    ‘15 trd sport 6MT dcsb, mostly stock?
    Looks great....do you have any pictures of under the hood?
  12. Jul 29, 2016 at 4:58 AM
    lemons
    Virginia
    It look the same under the hood. No change other than I took off my AFE cold air intake and put back on the stock one.
    Sna[QUOTED] likes this.
  13. Jul 29, 2016 at 9:22 AM
    Sna
    Alberta
    Ok cool.
    How is the quality of this compared to the new Tacoma specific Safari snorkel?
  14. Jul 29, 2016 at 9:45 AM
    lemons
    Virginia
    I think it's great. The Safari is a little smaller than the AirFlow so in theory it provides more air. It's a quality product, if I were to do it again I would go with the AirFlow again. Well worth it and it's a little cheaper than Safari.
    YanE30M3 and bski22 like this.
  15. Aug 3, 2016 at 8:59 AM
    Sna
    Alberta
    Thanks for the reply but the Safari (new 05-15 Taco specific) is not smaller than the Airflow...
    I am just concerned, from things I have read, that the Airflow is not made as well as the Safari and that worries me. I think the Airflow looks MUCH better than the Safari though!
  16. Aug 3, 2016 at 11:47 AM
    TYetti
    Mat
    If run mine into some trees it's still there
  17. Aug 3, 2016 at 12:03 PM
    la0d0g
    Do you mean from the type of plastic used perspective?
  18. Aug 3, 2016 at 1:14 PM
    Sna
    Alberta
  19. Aug 3, 2016 at 6:55 PM
    Garfish307
    Katy, TX
    Flux Capacitor
    Installing now..question... 10mm drill holes seems kinda large...?? I know it will have some adjustments but... Did you drill with 3/8"?
  20. Aug 4, 2016 at 3:57 AM
    lemons
    Virginia
    I used a step up bit until the studs fit. Should be around 3/8 or so.
