How to align your steering wheel (fix crooked steering wheel)
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Mxpatriot, Jul 4, 2010.
  1. Jul 4, 2010 at 8:55 PM
    Mxpatriot
    Mxpatriot [OP] Well-Known Member
    '06 4x4 AP LT and Locked
    I don't know about you guys, but it seems that every time I go offroading I knock my truck out of alignment. Most of the time it's just the alignment of the steering wheel with the wheels - meaning the truck tracks straight and handles well, but the steering wheel is not sitting straight when the truck is traveling straight. I've even taken it in to get alignments before and had it returned aligned, but with the steering wheel out of alignment with the wheels.
    Well, I decided that I wanted to find out if I could just pop the steering wheel off and rotate it on it's spine to correct those sorts of issues. And I did, and here's how:
    Disclaimer: This may or may not be a good idea in the long run, but it worked as a temporary fix for me. Do it at your own risk. Some of the downsides have been pointed out below.
    1. Disconnect negative wire from battery, wait at least 90 seconds (to disable air bag).
    2. Turn steering wheel to reveal two screws, one on the upper right, and one on the upper left, corner of the plastic pieces behind the steering wheel.
    3. Remove the screws, and pull the lower plastic cover down off the steering column.
    4. Observe two plastic covers on the side of the steering wheel. Remove them carefully, use a flat blade screw driver to pry them out.
    5. Unscrew the two Torx screws inside.
    6. CAREFULLY remove the airbag. Do not set it face down. The Toyota repair manual says to hold it from the bottom.
    7. Remove the nut holding the steering wheel in place - it is the large nut dead in the center. It's a 17mm if I remember correctly.
    8. Remove steering wheel, rotate to desired position, and push it back on the spine.
    9. Replace and tighten the large nut holding the steering wheel in place.
    10. Replace air bag. Tighten Torx screws.
    11. Replace plastic covers.
    12. Replace steering column covers.
    13. Replace screws.
    14. Test drive and re-adjust if needed.
  2. Jul 4, 2010 at 9:06 PM
    skytower
    skytower Well-Known Member
    Dave
    virginia
    08 Tacoma 4x4
    Hitch and wiring, aux back-up light, rear strobe lights, radio and underseat sub.
    If they did a proper alignment, and not just a toe-and-go, your wheel would have been straight.
  3. Jul 4, 2010 at 9:20 PM
    Mxpatriot
    Of course. I also turned right around and had them correct it.
    I'm pulling the steering wheel to correct it for when I knock it out of place offroad.
  4. Jul 4, 2010 at 9:24 PM
    blackhawke88
    blackhawke88 wo ai ni bao bei ^_^
    SGV, CA
    07 TRD Offroad
    i do my own toe alignment after offroading, just loosen tie rod nut, adjust, tighten, test drive and repeat until you have a slight toe-in
  5. Jul 4, 2010 at 11:04 PM
    JKD
    JKD Well-Known Member
    Are you sure that your clockspring (spiral wire assembly) is not being thrown out of adjustment when you do that? They only have limited travel each direction, and they are extremely expensive to replace.
    If you center the wheel the normal way (adjusting the tie rods) you can be reasonably sure that the clockspring is always returned to the natural center adjustment when the wheel is pointed straight ahead.
  6. Jul 5, 2010 at 12:08 AM
    rzimm001
    rzimm001 Tearmytaco
    Bobby
    Wildomar
    08 PreRunner SR5 Long-Travel
    King 10" coilovers w/ resi. 3.5" over long travel kit. Factory spindles w/ ALLPRO gussets. Total Chaos tower gussets. Energy Poly cab mounts and steering rack mounts. Glassworks fenders and bedsides. Home fabbed bed cage. King 2.5x16 bypass shocks in the rear. DMZ long travel rear end. Race radio (2meter). Removed secondary carbon air filter. Exhaust dumped before the axle / no muffler. Phram fresh air cabin filter. K&N replacement filter, After market stereo, Grillcraft grill, custom fabled roof rack with 7" HID's, PRP race seats.
    I wouldn't take the steering wheel off. I know what you are talking about though. My steering wheel used to do the same thing after offroading. Even with it cocked to the side the truck drives true. This is because your steering will always find its center. Generally the steering only pulls if the caster or camber or both have been affected. If only the toe has changed the result will be that your wheel is off center.
    I have rectified all of this by first off, airing down significantly before all offroading. The tires on your truck account for a great deal of the suspension. I never offroad with more than 20psi max. Secondly, get yourself a good quality alignment and make sure the numbers look right on the sheet. If everything looks good, get under your truck and mark on the frame with something sharp, where the caster/camber lobes are positioned. Now you'll know if they move and where to move them back to. Whenever the wheel goes off center on you, check the toe alignment yourself. Each tire should be toe in by 1/16th of an inch.
  7. Jul 5, 2010 at 12:16 AM
    rzimm001
    rzimm001 Tearmytaco
    Bobby
    Wildomar
    Here is the link to a great video on how to do your own alignment. It's very in depth and probably not for the faint of heart. I only check my toe in using his method because its actually relatively easy and only require a ruler, string, and some jack stands. There are I believe three parts to this video FYI. http://www.youtube.com/watch?v=sZoL1gaWedA
  8. Jul 5, 2010 at 8:07 AM
    Mxpatriot
    I'm not too worried about the spiral cable - I only moves the steering wheel a very small amount. Plus, mine is already shot (horn works but airbag light is on)
  9. Jul 5, 2010 at 3:45 PM
    Asgard
    Asgard Well-Known Member
    06 PreRunner DC SR5 w/LSD
    Good point, I think that's how mine broke.
  10. Jul 5, 2010 at 3:57 PM
    David Tarantino
    David Tarantino Well-Known Member
    N.J.
    08 tacoma
    this is going to be good :popcorn:
  11. Jul 5, 2010 at 4:11 PM
    toku58
    toku58 Well-Known Member
    On a Rock in the middle of the Pacific
    Mall Crawler!
    21' TRD OffRoad 2" 887 OME on Bilstein 5100's. 285/70R17 General Grabbers G3 17x8.5" Icon TRD wheels (Gun metal gray) 4.75" BS
    Well it might not be a good idea to do it this way. The steering wheel is normally set in the neutral point of the Rack-n-pinion. (Mid point)
    That's why they do all the adjustments from the tie rod.
    But it might not be so bad if it's only a very small adjustment. But IMHO, you're better off doing it the right way, and have the alignment shop adjust the tie rods.
    Good Luck with that!
  12. Nov 9, 2010 at 6:45 PM
    tt07
    tt07 Well-Known Member
    north carolina
    01 4wd
    none yet
    why dont you just do the same thing at the knuckle down at the fire wall inside the cab?? it would take like 2 min. Just makes more sense to me!!! or if your that anal about how straight you steering is then dont wheel your truck!!
  13. Nov 9, 2010 at 6:53 PM
    NelsonTacoma
    NelsonTacoma This is my derpawayinator!!!!!
    Tucson, AZ
    06 PreRunner TRD Sport 03 4Runner Limited 4wd
    Bilstein 5100's , 6000k HID Hi/Low Kit, Magnaflow Muffler, 1.5 inch AP Wheel Spacers, Mudflap Delete
    Moving your steering wheel on the column is the simplest way to do this, but not the correct way. I personally like to adjust it at the tie rod ends, just make sure you make the same adjustment to each tie rod end. 1/2 turn at a time. This is how it is done in a shop with an alignment machine.
  14. Nov 9, 2010 at 8:06 PM
    rzimm001
    rzimm001 Tearmytaco
    Bobby
    Wildomar
    Doing your alignment by repositioning the steering wheel is the most ridiculous thing I've ever heard. How is that going to fix an excessive toe in or toe out condition? Not to mention your steering rack is out of calibration by doing that. If your wheel is cocked over to one side it's most likely because one tire has toed itself in or out. If you than move your wheel only, the other tire will be out of alignment. The alignment must be done from the tie rods.
