how to assembly struts by yourself..
Discussion in 'Suspension' started by 08pretaco, Dec 27, 2009.
  1. Dec 27, 2009 at 5:26 PM
    08pretaco
    08pretaco [OP] Well-Known Member
    az
    2014 Tundra 4x4 CM 5.7L SR5
    ok since i helped out that member a couple weeks ago i decided to just throw on here for you guys how to assemble some eibach springs with collars (these instructions may also help with the "stock" support just make sure you place the correct one on the correct side). Some of the pics will kind of be out of place.
    *i am not liable to a spring killing you or any other harm it may bring
    tools need:
    springs compressor (autozone)
    we used channel locks haha
    parts needed:
    2 shocks
    2 springs
    2 collars
    2 lower cushion retainers
    2 cushions
    2 upper cushion retainers
    (all part numbers available on the TSM)
    1. first you gotta make sure the c-clips is seated where you want it to be for what lift your looking to get, i chose the lowest setting. for those with collars (or stock support) just place it over.
    2. secondly i went to auto zone and rented some coil clamps, you put those on the coil. make sure when you put the on the put the coil on the shock so that when your putting the compressed coil on the shock the lower clamp doesnt interfere with putting in on securely. tighten the clamps until you can place the top plate on and fit the cushion and cushion retainers on.
    3. after the coil is compressed place the spring on the shock. put on the top plate. with these assembles there is a lower retainer, cushion and upper retainer. put each on in the order then place the nut on top.
    4. after placing all those on your going to need to tighten it. when you start tightening it you will notice the shock absorber rod will turn as well simple hold that in place while you tighten the nut. also at this time make sure the top plate studs line up accordingly, refer to the TSM for how they go.
    5. after tightening the top plate on (TSM says 20 ft/lbs, its hard to judge so do it till theres about 1/4-1/2" of thread showing from the rod) slowly remove the spring compressors, easing each side a little then going to the other.
    6. final product in less than 30 min. a shop was gonna charge me 100 bucks to do it, no way man much better places to spend my money.
  2. Dec 27, 2009 at 5:29 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Well done!
  3. Dec 27, 2009 at 5:35 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    damn good job man!!!
  4. Dec 27, 2009 at 5:35 PM
    08pretaco
    az
    Thank you sir! You have no idea how excited I am for tomorrow for taylor and myself to do both our trucks! Hope you can stop by and Pm'ing you right now
  5. Dec 27, 2009 at 5:37 PM
    rick
    rick `
    awesome
  6. Dec 27, 2009 at 5:37 PM
    Afwrestler1986
    Afwrestler1986 Well-Known Member
    Johnstown, NY
    01 trd 4X4 ex cab manual
    Gray wire, Some lights in the bed area, and some character marks throughout.
    Nice writeup!:D
  7. Dec 27, 2009 at 5:45 PM
    08pretaco
    az
    they held up great for me and i eye balled it for right now and left my collar adjustment all the way down and i can by hand (with a little force) move the top plate to the position i will need it for install then once on the truck use my spanner to crank them up a little bit. but your right its not perfect until your in there and see position the hole with the top plate studs
    hope no one got hurt when the springs compressor broke on you!
  8. Dec 27, 2009 at 5:45 PM
    ColtsTRD
    ColtsTRD Well-Known Member
    Scott
    AZ
  9. Dec 27, 2009 at 5:50 PM
    08pretaco
    az
    yes sir i did
    im glad that those didnt break on you!
  10. Dec 27, 2009 at 5:57 PM
    Fluffymonkey
    Fluffymonkey Token
    College Station, TX
    2013 Trd Sport DC, 07 DC sr5, 03 Prerunner
    2003: Stock 2007: Avid Offroad sliders, 30% front tint, bed mat, Truxedo low-pro qt tonneu cover, aero turbine 2525 muffler w/ 8'' tip, AR25 Resonator, 16x8 Dick Cepek DC-1 w/ 265/75 Goodyear Wrangler Duratracs, 2010 headlights, ome 884 coils with .5'' top plate spacer, OME sport front shocks, bilsten 5100s rear, 2'' aal, locking gas cap, LR ucas, Viper 2-way remote start, afe drop in filter, Rocky locking bike mounts, gear chest, scangauge, pop n lock tailgate lock 2013: most things transferred over from my 07, 5100s @ .85 + eibachs and Toytec tps for 3'' front lift, wheelers progressive aal w/ overload; compustar 2-way remote start; Antennex shorty antenna, pop n lock tailgate lock with programmable key, seat covers, Toyota's crappy all-weather floor mats (should have got Husky's or Weathertechs), TRD skid plate, led light pods mounted in front bumper valence w/ Eyourlife wireless harness and remote, led bed lights, light pods mounted in bed, Devil Horns emblem from Diaz Fabrications, rear facing pod lights in bed, under seat lights,
    Nice writeup!
  11. Dec 27, 2009 at 7:02 PM
    08pretaco
    az
    what made you move from out beautiful barren state?
  12. Dec 27, 2009 at 8:51 PM
    Stillfly199
    Stillfly199 ( . )( . )
    J.D.
    Bro Capital of the word
    2010 FJ Cruiser
    I think wheelers wants $225 to assemble them for you before shipment.
  13. Dec 28, 2009 at 5:12 AM
    Afwrestler1986
    Johnstown, NY
    Yeah. I saw that when I went to order stuff. A bit steep if you ask me, the DIY method is cheap, but make me kind of nervous, especially with some 882's. I don't want to die. :D
  14. Dec 28, 2009 at 8:40 AM
    Stillfly199
    J.D.
    2010 FJ Cruiser
    Exactly, my buddies dad has a shop so I can get him to help hopefully :eek:
  15. Dec 28, 2009 at 8:41 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Being as they use new stuff (OEM), $50.00 per top plate, $20.00 + per spring isolator, plus studs and nuts, its really not a bad deal.
  16. Dec 28, 2009 at 9:01 AM
    Brunes
    Brunes abides.
    Rotorhead
    Around
    What this joker said totally makes sense. 100 bones for just the top plates. I think I paid 30 apiece for the isolaters. I skipped the retainers for some grade 8 washers. So you are talking about 180 or so just in parts. And then 40 bones for the work is pretty fair.
  17. Dec 28, 2009 at 9:04 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    I no joker :(
  18. Dec 28, 2009 at 9:04 AM
    Stillfly199
    J.D.
    2010 FJ Cruiser
    So you cant use the stock stuff, you have to buy all new stuff?
  19. Dec 28, 2009 at 9:05 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    You can use the stock stuff just fine.
  20. Dec 28, 2009 at 9:06 AM
    Brunes
    Brunes abides.
    Rotorhead
    Around
    If you are going to pre-build them...Yes.
    The top plate holds the stock struts together...and the isolators can be reused depending on condition.
    So I bought top plates from someone here at reduced cost to build mine up...but bought the new isolators. If you have the time to take the stock parts out...take the struts apart....and build the new ones up....you can do that.
