how to bag
Discussion in 'Street Trucks' started by black09, Jan 3, 2014.
  1. Jun 10, 2023 at 4:51 PM
    BananaMan
    BananaMan Well-Known Member
    Bumfrick nowhere Maine
    06 2.7 RC 2wd manual "squattytruck"
    How much of a c-notch do you have in the rear? With a deep enough custom notch you should be able to run springs and be scraping frame virtually.
  2. Jun 10, 2023 at 6:05 PM
    GrampsTacoma23
    GrampsTacoma23 Just hit 100k Club
    Jeff
    N GA
    2010 Silver Tacoma Base 2.7
    DJM Lowering kit, All LED lights on entire truck and inside, wheels
    Well i scrape in the front but im about to go to an 8 inch universal step notch with bridge bars how low can i go becore its too low
    BananaMan[QUOTED] likes this.
  3. Jun 10, 2023 at 6:49 PM
    BananaMan
    About the same time the cops pull you over for the sparks flying out from under the truck. Your trans cross member will be dragging first, that's the low point for static
  4. Jun 10, 2023 at 6:54 PM
    GrampsTacoma23
    Jeff
    N GA
    Also my control arms ive went through a few, and yeah i mean i havent been stopped for it yet luckily
  5. Jun 10, 2023 at 6:56 PM
    BananaMan
    I mean you can go so far as to notch the back of your cab to clear the driveshaft. "Too low" is really subjective. What are you running for control arms?
  6. Jun 10, 2023 at 8:14 PM
    GrampsTacoma23
    Jeff
    N GA
    Currently stock control arms and thinking about djm 3 inch uppers and lowers, will that help my issue with scraping the rear of the lcas?
  7. Jun 11, 2023 at 2:42 AM
    BananaMan
    I would think so. I'm running the DJM's with Feal coilovers and I'm sitting about 4 1/2 inches lowered and the control arms aren't a problem for me. I'm also setup for autocrossing so I do have suspension travel still
  8. Jun 11, 2023 at 8:53 AM
    GrampsTacoma23
    Jeff
    N GA
    Well i mean my crossmember and lca bushings are my lowest point itting at 1 inch off the ground just wondered if the djms had smaller bushings so i could get some diamond plate welded under them as a place to scrape instead of my suspension
    nightcrawler likes this.
  9. Jun 12, 2023 at 5:35 PM
    nightcrawler
    nightcrawler Well-Known Member
    ‘17pro
  10. Jun 12, 2023 at 6:25 PM
    GrampsTacoma23
    Jeff
    N GA
    I literally did this the other day on a stick
    nightcrawler[QUOTED] likes this.
  11. Jun 13, 2023 at 1:25 AM
    nightcrawler
    ‘17pro
  12. Jul 17, 2023 at 8:38 PM
    wema780
    wema780 New Member
    wema
    2014 Black Tacoma TRD
    I helped a friend bag an S10 once, and he wanted it to lay flat on the frame....which required actually cutting and re-welding the control arms so that the ball joints moved right.
