How to beef up my ifs
Discussion in 'Suspension' started by Sprink21, Jan 9, 2011.
  1. Jan 9, 2011 at 12:36 PM
    Sprink21
    Sprink21 [OP] Well-Known Member
    Jon
    Vancouver, WA
    2010 dbl cab 4x4
    K&N Intake, AirAid Throttle Body Spacer, Banks CatBack Exhaust
    Im gonna buy the ToyTech ultimate lift kit for my 2010 Taco. All I hear from my friends is how weak my stock ifs is. So I was wondering if anyone could tell me what should be on my priority list for beefing up my ifs. The last thing i want is to be stranded on a trail in the middle of now where. Sorry if a similar thread had already been posted, I couldn't find it.
  2. Jan 9, 2011 at 12:46 PM
    toyo freak
    toyo freak Another Toyota Enthusiast
    David
    Mobile, Alabama
    2010 V6 D-Cab 4x4
    5100s at 2.5, Wheeler 3 leaf progressive AAL, Weathertech liners, yellow wire mod, toyota OEM bed mat, cup holder mod, afe pro dry s air filter, UWS low pro toolbox, Escort radar detector
    Welcome! Yea the ifs isnt very reliable, thats why many reccomend doing a sas ( solid axle swap). its expensive, but by beefing up stock ifs, you a really sugar coating a turd. Research SAS
  3. Jan 9, 2011 at 12:48 PM
    ToucanV13
    ToucanV13 You think I was rollin out here naked?
    San Diego and Colorado
    Infideled out TRD Sport 4X4
    285/70 Hankook AT-M, Window vents, TRD CAI, TRD Cat-back exhaust with WickedFlow can, AFE Throttle Body Spacer, Billy 5100 @ 2.5 and 1" block rear, RBP nerf bars, Halo HIDs, 20% tint up front
    There are plenty of threads in the suspension section. It starts to boil down to your intended use then preference.
    You could go all out bat shit crazy out the gate and instead get Icon/Fox resis all around instead of TULK. 5100s are usually fine for most. UCAs are good to upgrade for clearance/alignment/strength issues. You can get on Total Chaos for those as well as spindle gussets. Sounds like a decent start to me :D and Welcome :wave:
  4. Jan 9, 2011 at 12:50 PM
    toyo freak
    David
    Mobile, Alabama
    2010 V6 D-Cab 4x4
    ??? Are you reffering to how weak the IFS in general (mechanically-cv axles etc) or just shocks/struts and similar
  5. Jan 9, 2011 at 12:53 PM
    PWhite13
    PWhite13 Well-Known Member
    Prescott
    Southern California
    06 Silverado Crew Cab 5.3
    They are probably exaggerating on how weak it is. If you get aftermarket UCA's along with the lift, it will be pretty damn tough. As long as you know the truck's limits, you can do some crazy stuff with the ifs. But like another poster said, a solid axle would be way stronger, but also way overkill if your just doing trails and stuff.
  6. Jan 9, 2011 at 12:53 PM
    ktmrider
    ktmrider Senior Member
    07 DCLB 4x4 Sport S/C
    Junk
    I wouldnt spend cash to beef it up if you dont plan to use it and break it in the first place.
  7. Jan 9, 2011 at 12:59 PM
    jjew18
    jjew18 the Nightman cometh!
    Alliance Airport
    05 PreRunner SR5
    Added extra awesomeness to its original awesomeness.
    Johndeere40 likes this.
  8. Jan 9, 2011 at 1:02 PM
    rab89
    rab89 Well-Known Member
    Ross
    Kelowna b.c canada
    2017 DCLB TRD Sport
    ughhh, it's completely reliable, unless your stressing the cv axles a lot.
    I've had a lift on my ifs for a while now, and not had a single issue.
    OP, I don't thin you need to beef up the front end too much, new coilovers and uca's will be more than enough!
  9. Jan 9, 2011 at 1:06 PM
    Sprink21
    Jon
    Vancouver, WA
    2010 dbl cab 4x4
    Im asking about both mechanically and shocks and struts.
  10. Jan 9, 2011 at 1:14 PM
    Sprink21
    Jon
    Vancouver, WA
    2010 dbl cab 4x4
    Sorry about double posting this. I didnt see the first post come up so I posted it again.
  11. Jan 9, 2011 at 3:06 PM
    ETaco23
    ETaco23 Marshall offroad Fabrication
    Evan
    PNW
    13' Pyrite Mica TRD Offroad DCSB 4x4
    Color Match Grille, Bed mat, Kings with JBA UCA's, Dakars and 34" BFG KM3, Snugtop Canopy, and my "Marshall Fabrication" Rock Sliders.
    Hey there neighbor! :)
    The IFS is more then enough for the Trails in our area, and is plenty tough. SAS is just over kill and way too spendy to do.
    If you plan to do offroading regularly then I would just do a mid travel set-up in the front.
    Icon ext. travel coilovers and TC UCA's. and maybe also remove the sway bar for some more travel.
    Thats the route I want to go, bc these RadFlo's arent that great travel wise.....
    Hope that helps ya!
  12. Jan 9, 2011 at 3:25 PM
    DevL
    DevL Well-Known Member
    Mechanically, nothing.
    Shocks? High-end,extended travel coil overs, designed to be used with new upper control arms that use uniballs instead of ball joints.
    For example Total Chaos upper arms and King extended travel coilovers.
    Thats it. You will get 0-2.5" of lift, anything more will cause you to tear a CV boot and then destroy your front suspension.
    Nothing else to be done short of a $10,000+ long travel suspension set up.
  13. Jan 9, 2011 at 3:32 PM
    92LandCruiser
    92LandCruiser Well-Known Member
    Nevada
    80 series Land Cruiser
    Cummins, tons, 40s
    You could always add the spindle gussets, LCA skids, "Lower Control Arm Cam Tab Gussets", and carry a spare cv assembly and tools to swap it out. There are guys on here running 315s and wheel hard on the stock IFS, you'll be fine. I'd focus more on armor and recovery.
