How to best stop tire rub?
Discussion in '1st Gen. Tacomas (1995-2004)' started by Reddy, Jan 25, 2015.
  1. Jan 25, 2015 at 3:36 PM
    Reddy
    Reddy [OP] Well-Known Member
    Scott
    Ohio
    '11 TRD OR AC
    OME 885's/Dakars/265's/belly skid
    So my '04 SR5 Tacoma has been running on 4runner wheels for a while now. The wheels came with Michelin radials in 265/75r16 in really good shape, so (even though I prefer all-terrains) I decided to keep them for now. However, at full lock they rub on the frame.
    So, I'm wondering what the easiest and cheapest way to keep that from happening is. Now, bear in mind, I've been a Jeep guy for years and this is my first Toyota. So, I'm a little ignorant as to mods on Taco, but I'm learning, just a little confused on this issue.
    I'm undecided on whether or not I'm going to lift the truck. I know on a Jeep, one could do a budget boost for a couple hundred bucks with no real repercussions on rest of the works (linkage, brake lines, drop brackets, etc). Is there something similar I could do to my Tacoma?
    Or would it be better to go with wheel spacers? I'm pretty averse to these since I think they put strain on other parts, but I wouldn't need much...
    On my last Jeep, I also had a little rub at full lock so I simply backed out the steering stops, put a couple washers on the bolt and screwed it back in. It made the turning radius slightly wider, but worked. I don't suppose the steering stops on a Toyota are anywhere near that simple, huh?
    When I go to replace tires, maybe I should just go with a narrower tire. What would a good choice be? 265/70r26? 31x10.5x16? (I think that's right, not used to metric tires yet).
    Or should I just live with the rub and occasionally hit the spot rubbed to metal with some Krylon?
  2. Jan 25, 2015 at 3:46 PM
    Codyj8
    Codyj8 Shit'll buff out!
    Cody
    Hardin, MT
    01 Silver Tacoma 6'' lift on 35's
    Uniden CB, 5" Firestick, Allpro tube bumper, homemade rear tube bumper, Fuse pannel, Zeus 20in lightbar, zeus led pods, 9500lb Superwinch, LED turn signals, LED tail lights, Husky toolbox with LED break lights, Rhino lined bed/bottom pannels of truck, tinted windows, Grey wire mod, Undead Offroad rock sliders, 35in Goodyear Kevlars, 15in steelies (black)
    I'd just get some spider trax wheel spacers, or if you wanna spend a lil more get different offset wheels:/
  3. Jan 25, 2015 at 3:47 PM
    Reddy
    Scott
    Ohio
    '11 TRD OR AC
    Nice avatar, dude. ;-)
  4. Jan 25, 2015 at 3:52 PM
    Codyj8
    Cody
    Hardin, MT
    Haha appreciate it man!
  5. Jan 27, 2015 at 5:27 AM
    Reddy
    Scott
    Ohio
    '11 TRD OR AC
    After doing a TON of searching here on the forum, I'm seriously considering this route.
    It seems like my best option would be new shocks all around and an AAL. I'm confused a little about whether or not I would need any sort of drop brackets or have trouble with vibrations. Thoughts?
  6. Jan 27, 2015 at 8:01 AM
    drr
    drr Primary Prognosticator
    Dan
    Seattle-ish
    02 4WD Tacoma
    You won't need a drop bracket of any sort, you can get up to about 3" of lift with stock control arms without binding anything too bad. You may get some slight driveline vibrations when you lift the back end, there are several remedies for that such as rear axle shims and a carrier bearing drop, depending on how much the vibes annoy you.
  7. Jan 27, 2015 at 8:03 AM
    tan4x4
    tan4x4 Well-Known Member
    Rick
    Folsom, CA
    99 Tacoma EC 4x4 2.7L Auto
    Bilsteins, OME 881's, 3-leaf AAL, Detroit TruTrac, Tundra brake swap, Michelin LTX AT2, Tranny skidplate, TC skidplate, CBI rear bumper, TG sliders, UltraGauge, PowerTank, Reverse Camera
    I'm running 265/70r16 Michelins and 16" stock rims from a 2002 Tacoma, and they don't rub at all. This is the stock size tire for my truck. Replacing those 4runner rims might also solve the rubbing issue (the backspacing might be different, not sure)
  8. Jan 27, 2015 at 8:28 AM
    Reddy
    Scott
    Ohio
    '11 TRD OR AC
    Funny you mention the backspacing. I think of that until today. I really like the looks of the wheel (and way better than the factory steelies) so I don't really want to replace them.
    I know the TRD's came with that size tire, so I just assumed my suspension has sagged a bit (and that could well the case) letting them rub.
    I'm kinda stuck on the idea of a lift now. :D
  9. Jan 27, 2015 at 9:17 AM
    Voyager
    Voyager Well-Known Member
    Bob
    Virginia
    04 Tacoma DC 4X4 TRD V6
    OME Suspension kit Magnaflow SS catback, ARE cap, Yakima kayak & bike racks, Deck Lid, Westin Safari Light Bar.
    not sagged. 265/75r16 is about an inch taller than 265/70r16.
  10. Jan 27, 2015 at 9:24 AM
    Gearheadesw
    Gearheadesw must modify
    Davenport Fl
    1 truck 1 car 1 motorcycle
    This. It's all in the right backspacing.
  11. Jan 27, 2015 at 9:27 AM
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    ...too much shit to list.
    A lift will only help with rubbing at ride height.
    Any amount of suspension bump travel and turning, and you'll still be hitting the frame. Just get the smallest hubcentric wheel spacers you can get away with that push the wheels out. Otherwise wheels with less backspacing.
  12. Jan 27, 2015 at 10:21 AM
    Reddy
    Scott
    Ohio
    '11 TRD OR AC
    Excellent point.
    Dang. Now what's my lift excuse...
  13. Jan 27, 2015 at 10:24 AM
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    Why would you need an excuse. ;)
  14. Jan 27, 2015 at 10:33 AM
    Reddy
    Scott
    Ohio
    '11 TRD OR AC
    Yes another excellent point.
    Nah, I'm just thinking about the money. (Trying to finish home renovations, you know. But yeah, A little lift would be cool regardless.)
    With my luck, I'd space 'em and the tires would rub on something else. So... both, amirite? :cool:
  15. Jan 27, 2015 at 10:36 AM
    muddog67
    muddog67 Well-Known Member
    hope he is using a condom , Dont need a birth defect from a Tacoma doing a Jeep
  16. Jan 27, 2015 at 10:42 AM
    Reddy
    Scott
    Ohio
    '11 TRD OR AC
    A cross between a Tacoma and Jeep sounds pretty BA actually, haha.
    Hey, just did a quick google search on my break. I was hoping to find something like a 1/2" spacer, but everything I see is 1.12" or 2". Anyone know of anything slimmer? I don't need much here.
  17. Jan 27, 2015 at 10:45 AM
    muddog67
    :facepalm:
  18. Jan 27, 2015 at 11:11 AM
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    Bora sells 3/4" hubcentric spacers.
  19. Jan 28, 2015 at 2:00 PM
    JasonLee
    JasonLee Hello? I'm a truck.
    Q322+3C Denver, Colorado
    15 TRD OffRoad
    TRD Supercharger and more.
  20. Jan 28, 2015 at 2:03 PM
    Boone
    Boone Vaginas are rad.
    Boone, NC
    Airbags deployed
