How To: Black Head Light mod
Discussion in 'Lighting' started by Viet2100, Dec 14, 2009.
  1. Dec 14, 2009 at 6:42 PM
    Viet2100
    Viet2100 [OP] Well-Known Member
    Viet
    South Florida
    2016 Prius 4T
    Edit by mjp2: This tutorial was awesome but the photos disappeared from Photobucket. 478DblSport was kind enough to save and restore the information, so I'm including that post here for reference. Enjoy!
    Shamal, dzking, tkarjala and 5 others like this.
  2. Dec 14, 2009 at 6:47 PM
    G-Sak
    G-Sak Well-Known Member
    PNW
    2005 TRD Offroad SR5 DC 6 speed
    FX-R Projector Retrofit with Apollo Shrouds, Digital HID 55 watt ballasts, D2S Philips 85122+ bulbs in the Winter and Digital HID 55w 5k bulbs in the summer, Bakflip G2, Pop N Lock, Tint, Grillcraft with PIAAs behind it, ScanguageII and a few audio/video upgrades.
    Thanks Viet! Those gen 3s look good in there as well! ;) This should be a sticky since it has pics. +1 for you.
  3. Dec 14, 2009 at 6:50 PM
    AriZonaD54
    AriZonaD54 BANNED in 49 states...
    Andrew
    Valley of the Sun
    Good write-up.
  4. Jan 16, 2010 at 11:48 PM
    G-Sak
    PNW
    Viet, How is the 3M Window Weld rubber butyl stuff holding up in the elements? I am trying to decide how to seal up my housings as I am close to finishing my retrofit. I live in the Pacific Northwest so I am concerned about fogging issues as it gets cold and wet here. Thanks!
  5. Jan 17, 2010 at 4:03 PM
    outlawtacoma
    outlawtacoma Well-Known Member
    W. TN
    2018 T4RTRDOR
    Looks awesome!! Great job!!
  6. Jan 17, 2010 at 4:26 PM
    johnny12345
    johnny12345 Well-Known Member
    vancouver island, canada
    09 tacoma SR5
    Looks like the window weld should keep moisture out better than anything I can think of. Definatley better than than trying to salvage the original adhesive as I've seen some guys do.
  7. Jan 17, 2010 at 4:33 PM
    G-Sak
    PNW
    Thanks Johnny, I just went ahead and picked some up today. I figure it will be better than the stock glue. I might put some silicone sealant around the edge of the lights after the window weld is cured for more protection.
  8. Jan 17, 2010 at 4:37 PM
    deadphish28
    deadphish28 Well-Known Member
    Tim
    Milford ct
    08 trd offroad
    kn cold air intake Borla cat back 285 Toyo open country a/t Pro comp 17" rims Led dome/map lights Ddm hid 55w headlights 5,000k
    wow great write up- thanks for putting the time into this!
  9. Jan 22, 2010 at 12:51 PM
    LEX
    LEX --- --- --- - ----
    Houston, Texas
    100 Series LC
    I'm currently in the process of doing mine. So far so good. It's actually pretty easy, but I don't want to jinx myself. Wish me luck.
    RockinTaco17 and amora9912 like this.
  10. Jan 22, 2010 at 12:55 PM
    ColtsTRD
    ColtsTRD Well-Known Member
    Scott
    AZ
    Nice write up man...good details too :thumbsup:
    +1
  11. Jan 22, 2010 at 3:26 PM
    Viet2100
    Viet
    South Florida
    2016 Prius 4T
    Sorry guys I haven't seen this thread. The rubber butyl is awesome to work with! The only bitchy part was removing the stock stuff. I added some clear liquid nails on the outside for extra measures. BUT, also make sure you preburn everything before sealing it up.
  12. Jan 22, 2010 at 6:56 PM
    MrZoggs
    MrZoggs Ainokea
    Zach
    Alaska
    13' DCLB Sport
    Some Stuff...
    Anybody know what the melting point is for the stock adhesive that holds the housing together?
    Think you could get away with using a blow dryer to peel the remaining adhesive off after separating the housing?
    :confused:
  13. Jan 22, 2010 at 7:11 PM
    Viet2100
    Viet
    South Florida
    2016 Prius 4T
    you can, but expect to be there all day.
  14. Jan 22, 2010 at 9:16 PM
    yosh2000
    yosh2000 Well-Known Member
    CO
    '17 Tundra CM 5.7
    as long as you put the lense back on the same way you took it off, you'll be fine. i've done over a handfull of these and have nevery used any extra glue, and none have fogged or leaked on me.
    but i too am interested in how adding this stuff will affect the lights? i like the OEM stuff because it becomes harder and more sticky than the 3M stuff. the 3m stuff seems really good though, so....what do you say viet?!
  15. Jan 22, 2010 at 9:19 PM
    Rucas
    Rucas 1st gen
    Lucas
    1st gen. 4x4
    Custom Aluminum Camper
    I used the 3M and its working fine. Make sure you clean that grove out really good so its all new 3M weld in there.
  16. Jan 22, 2010 at 9:22 PM
    yosh2000
    CO
    '17 Tundra CM 5.7
    what did you use to clean out the OEM stuff? i think that that stuff would be great to reseal IF you can get all the OEM stuff out first...
  17. Jan 22, 2010 at 9:26 PM
    Rucas
    Rucas 1st gen
    Lucas
    1st gen. 4x4
    just heat it up in the over and scrape it out with something disposible. Dont use a screw driver because you wont get it off the screw driver later. I heated and Cleaned the groove 3 times i think on each. then you can do a little on the lenses too.
  18. Jan 22, 2010 at 9:34 PM
    yosh2000
    CO
    '17 Tundra CM 5.7
    ^ dont mean to be a pain, but did you do the following...
    preheat to 300, turn off
    stick gray housing in oven for 5 min, scrape
    reheat oven, turn off, insert gray housing, scrap...etc?
    or did you keep the oven on when you reheated it?
    again, dont mean to nit pick, but you have a great idea and would like to know our process so i can do it too!
  19. Jan 22, 2010 at 9:53 PM
    Rucas
    Rucas 1st gen
    Lucas
    1st gen. 4x4
    To take the old stuff off I just set the over to 275-ish and didnt bother turning it off. left the grey half in for 5 or 6 minutes pulled out and cleaned a portion of the groove untill the sealer sterted to harden. Then I just put it back in and repeated the process till it was as clean as it was going to get.
  20. Jan 22, 2010 at 10:02 PM
    yosh2000
    CO
    '17 Tundra CM 5.7
    ^ cool, thanks for all the info!
