How To: Black Head Light mod
Discussion in 'Lighting' started by Viet2100, Dec 14, 2009.
  1. Jan 12, 2013 at 7:17 PM
    #381
    Rhody76
    Rhody76 Well-Known Member
    Rhode Island
    2011 SR5 DCLB 4x4
    Rear leaf TSB, Bilstein 5100s set at 1.75",1" blocks, UWS low profile toolbox in black, husky liners, tint, LED interior and reverse lights, yellow fogs
    I'm getting ready to do this and Ive been reading some other threads on the subject that talk about sanding the chrome off the before painting.
    Is this necessary?
  2. Jan 12, 2013 at 7:21 PM
    #382
    ImpulseRed008
    Susan
    SC
    08 PreRunner SR5 V6 w/tow pkg
    Maybe not sand all the chrome off, but most definitely need to scuff it up real well. Otherwise the paint will have nothing to stick to.
  3. Jan 12, 2013 at 10:06 PM
    #383
    bjmoose
    bjmoose Bullwinkle J. Moose
    San Jose CA
    '11 Std Cab 4x4 5sp
    I did it. I can't guarantee it's necessary. But I can tell you it's much easier to sand the chrome off the plastic than to sand equivalent chrome off of metal - which is a serious pain in the patootie.
  4. Jan 12, 2013 at 11:36 PM
    #384
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    I didn't bother, but I used RustOleum's version of Krylon Fusion.
  5. Jan 13, 2013 at 4:47 AM
    #385
    CookieMonster
    CookieMonster Well-Known Member
    Wil
    Norfolk, VA
    '12 DCSB TRD Sport
    I didn't bother with it, just used the paint designed for plastic and was good to go.
  6. Jan 13, 2013 at 9:33 AM
    #386
    87twentytwor
    87twentytwor Well-Known Member
    Jake
    Hawaii
    Sport
    none
    Is it mandatory to stick in oven?
  7. Jan 13, 2013 at 11:19 AM
    #387
    bjmoose
    San Jose CA
    '11 Std Cab 4x4 5sp
    Only if you don't want to break them when you try and separate them :rolleyes:
    Seriously - the'yre glued together and the only way to soften the glue is with the heat of the oven. You wouldn't get good results with a heat gun - you'd get parts too hot and other parts not hot enough.
  8. Jan 13, 2013 at 11:23 AM
    #388
    Rich91710
    Rich
    Los Angeles
    08 Base
    Good luck getting it apart without breaking it without heating the glue.
    I didn't use the oven to reassemble or cook the paint, but I literally waited a week before closing them up, and months before installing the lamps and installing, so the paint had plenty of time to off-gas.
    I got creative with clamps and shims and over the course of a week, the lens pulled in flush.
  9. Jan 13, 2013 at 1:40 PM
    #389
    YFZ450MOE
    YFZ450MOE When you blow off steam you get an eyepatch
    Moe
    Auburn, WA / Roseburg, OR
    09 white DCSB TRD (it's getting there)
    Icon Extended Travel 2.5" Coil Overs All-Pro U-Bolt Flip Kit Bilstien Rear Shocks Fabtech Add-a-Leaf Icon Upper Control Arms All-Pro Rear Bumper w/ Wrap Arounds & Hitch with custom LED plate light BHLM and Morimoto III D2S retrofit Satoshi Grill 2 Hella Black Magics behind Grill Bestop Supertop BAMF sliders
    Do not use window weld. It's not the same as the butyl type stuff. It's more like plastic and doesn't seal very good. And it's harder to pull apart if you ever need to.
  10. Jan 13, 2013 at 2:23 PM
    #390
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    Advanced Auto or Autozone should have it. I'd use the roll.
    3M Window Weld is perfect to use to seal up the headlights... They come apart with the same effort if you ever need to do it again. I don't know if you're talking about the tube stuff but the window weld roll is good stuff.
  11. Jan 13, 2013 at 4:10 PM
    #391
    Rhody76
    Rhode Island
    2011 SR5 DCLB 4x4
    For those that have used the Krylon fusion paint, did you use the flat black or gloss?
    Any recommendations and experiences with one or the other would be appreciated.
  12. Jan 13, 2013 at 4:14 PM
    #392
    Rich91710
    Rich
    Los Angeles
    08 Base
    RustOleum "All Surfaces" (self-priming) in Satin Black.
  13. Jan 13, 2013 at 4:44 PM
    #393
    Pugga
    Massachusetts
    I painted mine white but I used Krylon Fusion. Pretty sure it was satin.
  14. Jan 13, 2013 at 4:48 PM
    #394
    ajohnson
    ajohnson Glamour Shot
    Andy
    Charlotte, NC
    07 DCLB TRD Sport Prerunner 4x4
    Things and stuff and such
    I used adhesion promoter with Krylon Fusion sation black.
  15. Jan 13, 2013 at 6:51 PM
    #395
    Rhody76
    Rhode Island
    2011 SR5 DCLB 4x4
    Is adhesion promoter a primer that you apply first?
  16. Jan 13, 2013 at 10:24 PM
    #396
    Darth_Yota
    Darth_Yota I intend to live forever, or die trying.
    Cam-moron
    Somewhere USA
    Dented, broken-down ‘08 hoopty
    Ain’t good’nuff for insta
    Yeah it helps with adhesion of topcoats to whatever surface you're painting.
  17. Jan 14, 2013 at 2:50 AM
    #397
    ajohnson
    Andy
    Charlotte, NC
    Yes it creates a good base for the paint to stick to. Krylon fusion still looks great on my badges after 3.5 years, I dont think i have used a better paint.
  18. Jan 14, 2013 at 4:42 AM
    #398
    SpruceTaco
    SpruceTaco トヨタ
    Clearwater, FL
    2012 Spruce Mica TRD Sport
    Tinted windows 5%, sill protectors, TRD stubby antenna, weathertech in channel rain guards, wheathertech floor mats, BHLM, Truxedo low pro qt, DTRL deleted, anytime backup camera, bed storage locks, fog lights on anytime, tailgate theft deterrent, painted engine cover, relocated horns, l.e.d bed lights, l.e.d engine bay lights, l.e.d lights above cup holders, in glove box, rear cup holder, in console storage & cubby next to steering wheel, Grillcraft grill, 17x8.5 SCS Ray10's, 35x12.50 Nitto Ridge Grapplers, Borla cat back exhaust, map & dome l.e.d's, TEQ badge on grill, Redline tuning hood struts, Maxtrac spindles, SPC Light Racing UCA's, Bilstein 5100's front set at 0 with OME 885's & extended length Bilstein 5100's in the rear, All Pro expedition leaf springs & 2" blocks, extended brake lines front & rear, 1.5" 4crawler drive shaft spacer, Beefed Taco carrier bearing drop, 1.25" spidertrax wheel spacers on rear, Kenwood DNX570 touchscreen with navigation, 30" led light bar in lower bumper opening, 1/4" top plate spacer drivers side, Bullet Proof Fabricating skid plate, Cali Raised ditch lights & Rago f Fabrication brackets, Amp Research power steps, smoked l.e.d 3rd brake light, Wet Okole seat covers, under cab LED'S tied to dome circuit
    Krylon fusion in satin black, not too shiny not too flat.
  19. Jan 14, 2013 at 5:09 AM
    #399
    Pugga
    Massachusetts
    You're a poet and don't know it :laugh:
  20. Jan 20, 2013 at 5:51 AM
    #400
    Badgtho
    Badgtho Well-Known Member
    Ben
    CT
    '13 TRD sport 6spd
    TRD exhaust, TRD beadlock wheels, moto xtender
    67FF375B-C4CF-49AE-81EC-62E2CE0CFEC7-513_d8e0a415dad2f321f56283c7686ed7c08656c38b.jpg
    42305001-AEEA-44A2-93A3-337FD1BEFBD0-513_78c017e473adca430adacff0e26873fd65db26c6.jpg
    Just did this mod. Really not bad. I had a buddy lend a second set of hands.
    200 degrees for 8 min was what I used.
    Adhesion promoter and rust oleum satin black.
