How To: Black Head Light mod
Discussion in 'Lighting' started by Viet2100, Dec 14, 2009.
  1. May 14, 2013 at 1:38 AM
    #461
    trdagule
    trdagule Well-Known Member
    David
    naples FL
    07 tacoma 4x4 speedway blue
    And this on black my old set ImageUploadedByTapatalk1368520596.472539.jpgImageUploadedByTapatalk1368520656.288366.jpgImageUploadedByTapatalk1368520696.203846.jpg
  2. May 14, 2013 at 2:40 PM
    #462
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    What are those things for?!?! I used Nitrile gloves :notsure:
  3. May 14, 2013 at 7:15 PM
    #463
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    To take the hot housings out of the oven.
  4. May 15, 2013 at 1:23 PM
    #464
    Pugga
    Massachusetts
    Nitrile gloves worked for me... you guys must just have delicate hands :D
  5. May 15, 2013 at 6:22 PM
    #465
    whonoez
    whonoez Well-Known Member
    Jay
    Bay Area
    2013 Tacoma TRD Sport DCSB
    3"lift, Monster XD w/ 285/65/18 Nitto Trail Grapplers, Blacked out emblems, tinted front windows, BHLM
    Did mine yesterday! Surprised at how it turned out and it was super easy! Waiting to dry I even had lunch with my wife!
  6. May 18, 2013 at 5:10 PM
    #466
    99TacoDriver
    99TacoDriver Well-Known Member
    South Louisiana
    OME 885x/5100s/LR UCA/3 leaf AAL/275/70/17 Terra Trac X-Venture
    so i tried this today and couldnt pry the light open...i tried baking it twice and still no luck...i tried to pry it open where it is circled in the picture and it just bent the plastic and probably messed it up...i preheated to 300 and turned it off like the directions say and let it sit in the oven for ten minutes and then i tried it a second time. i am thinking about trying again tomorrow what should i do differently? should i go with a lower temp for a longer time to melt the sealant better or....? any advice is helpful thanks in advance
  7. May 18, 2013 at 5:24 PM
    #467
    Rich91710
    Rich
    Los Angeles
    08 Base
    Did you remove the 3 screws from the back?
    With those out, I was able to separate mine with no tools.
  8. May 18, 2013 at 5:25 PM
    #468
    PinkTaco24
    PinkTaco24 Well-Known Member
    NC
    06 prerunner
    5100s all around -- 1.75 fronts, 1.5 aal, spidertraxs, grillcraft mx, derped scoop & badges, AVID step bars....need.more.money.
    Take the screws out as well? If yes, then I'm not sure what to tell you. Did this a while back with no problem.
  9. May 18, 2013 at 5:31 PM
    #469
    99TacoDriver
    South Louisiana
    yeap took out all the screws
  10. Jun 12, 2013 at 6:04 PM
    #470
    ckeene9
    ckeene9 Well-Known Member
    Chesterfield, VA
    '12 DCSB Supercharged 4x4 TRD Sport
    See Build Thread
    Completed one headlight tonight, doing the other tomorrow night. What methods can I use to remove excess 'glue'? I got some on the trim when I was putting the halves back together. It's coming apart again in a few weeks for my retrofit and would like to make it perfect then.
  11. Jun 13, 2013 at 8:46 PM
    #471
    Stripertwink
    Stripertwink Member
    Christain
    Glendora
    2021 Tacoma off-road
    does anybody offer this service in socal????
  12. Jun 14, 2013 at 4:25 AM
    #472
    Justus
    Justus fucks not given
    Nabisco the kid
    In ur toolbox
    stockish
  13. Jun 14, 2013 at 4:26 AM
    #473
    Justus
    Nabisco the kid
    In ur toolbox
    stockish
    try a "powerball mini" attached to ur drill with generous amounts of mequires "plastx" polish
  14. Jun 14, 2013 at 5:35 AM
    #474
    ckeene9
    Chesterfield, VA
    See Build Thread
    On the part I just painted black?
  15. Jun 14, 2013 at 5:39 AM
    #475
    Justus
    Nabisco the kid
    In ur toolbox
    stockish
    no way............srry, thought u got it on the outside of the lens, my fault.
  16. Jun 14, 2013 at 8:19 AM
    #476
    ckeene9
    Chesterfield, VA
    See Build Thread
    Yeah, I use Plasticx on my lenses every couple of months to keep them looking good.
  17. Jun 21, 2013 at 6:42 PM
    #477
    Beaniam
    Beaniam Well-Known Member
    NJ
    1996 4x4, 2007 2wd, 2014 tundra
    Just finished mine. Also tinted the reflector. I had originally tried tinting the headlight but it came out like garbage. Luckily a rag and some carb cleaner cleaned all the rattle can tint off fairly easy.
    There's so much glue in there I figured I'd try leaving it all in the groove instead of cleaning it out. When I was done I placed the halves back together and back in the oven. Put all the screws in while it was still hot, pretty sure it's all sealed as good as factory. It's seated all the way, screws are bottomed out tight, and the glue is oozing out the seem. I'll post how well it works.
  18. Jun 25, 2013 at 10:17 AM
    #478
    ryantaco
    ryantaco Well-Known Member
    SoCal
    06 DC Long Bed TRD Sport
    Is there any decrease in the lights effectiveness with this mod?
  19. Jun 25, 2013 at 10:22 AM
    #479
    Agent Smith
    Agent Smith Always outnumbered, never outgunned
    05 TRD Offroad Ivan Stewart Edition
    Toytec lift,FJ Anthracite wheels wrapped in BFG A/T 265/75/16's,WAAG Brush Guard, IPF 868's,sleeved fog lights
    No, if you don't modify the reflector at all (the bowl behind and around your bulb).
    You are taking a risk of moisture getting in, all it takes is a little void in the factory glue to let in vapor, then you have a problem. I would have gone the extra mile while the headlights were out and put clear silicone caulk around the seam, just for insurance.
  20. Jun 30, 2013 at 5:53 PM
    #480
    wheelerkr2
    wheelerkr2 Well-Known Member
    Kevin
    Richmond, VA
    08 TRD Rugged Trail
    I'm doing this finally, and i got the headlights off and im trying to take everything off of them, how do i get the small black plastic parts off? they are the small lights i guess, i dont want to just pull them and break them.
    Thanks
