How To: Black Head Light mod
Discussion in 'Lighting' started by Viet2100, Dec 14, 2009.
  1. Sep 18, 2016 at 6:02 PM
    #721
    Cdharris89
    Cdharris89 Slave for the Money
    Gonzales, LA
    Black '14 Tacoma 4x4
    CB Radio :p, Tinted Taillights, Custom hybrid front bumper SR8 Matte Gunmetal
    wish i saw this last week! :frusty: anybody know where i can buy new lenses for my headlights?
  2. Oct 29, 2016 at 2:03 PM
    #722
    Newf709
    Newf709 Member
    2006 Black Tacoma SR5
    Would it be ok to use the 3m window weld caulking? Auto parts stores in the area dont carry ribbon sealer just the caulking.
  3. Oct 29, 2016 at 2:30 PM
    #723
    Thyces
    Thyces 2 seater taco
    Ontario
    2009 DCLB TRD Sport
    Custom painted 6112's Fox 2.0 12" in the rear Allpro expedition leafs (garbage) Pelfreybilt aluminum single hoop front Full size pickup bedslide modded to fit Satoshi grill Ubolt flip kit Archive garage shackle flip 5" Sumo supersprings 1500lbs SPC uca's Full set RCI skid plates Weld on sliders ABS killswitch Pop'n'lock power tailgate lock Falken Wildpeak mt on FJ rims Plastidipped emblems Ebay projector headlights Smoked aftermarket tail lights High output led reverse lights Hella horns 330w 5d led bumper bar 18w spots on track facing rear (fuck you lights) B&m trans cooler Bussmann fuse box ECGS bushing Big 4 (0 gauge ofc wire) upgrade Mechman 240 amp alternator Jl 10w7 in a 1 1/2" thick wall custom box Alpine 1000w rms mono amp Group 31 AGM battery installed next to sub Yaesu 2800 Bearcat 980 in dash with wireless mic and stainless whip Diff breather mod Hilux snorkel Turbine pre filter Baja Rack low profile cab rack Rifle case on rack Shovel and axe on quick fists in bed Flat and spade shovel mounted in bed Highlift mount in bed Tech deck with magnetic ram mount Tab s7 on ram mount
    NOOOOOO! ! !
    I used that shit and it remains viscous...in warmer weather it'll start to flow. I ended up having to had to take apart the headlights, clean all that shit off with paint thinner and then reseal with actual butyl rubber ribbon. Point of the story DON'T USE THAT SHIT !
  4. Oct 30, 2016 at 1:37 PM
    #724
    Newf709
    Newf709 Member
    Thanks man looks like its gonna be returned tomorrow lol
  5. Feb 26, 2017 at 12:20 PM
    #725
    4RunnerBen
    4RunnerBen Member
    Ben
    Tennessee
    Has anyone done Gloss Black on their BHLM?
    bigfoote13 likes this.
  6. Mar 21, 2017 at 11:24 AM
    #726
    Sub-Zero
    Sub-Zero NOOB
    Frederick, CO
    '06 DCSB
    None
    Mine is kinda glossy
  7. May 15, 2017 at 2:47 PM
    #727
    mreen428
    mreen428 Well-Known Member
    Shmatty
    Queens, NY
    11 DCSB TRD Spt
    Should it be really hard to separate the two parts after taking them out of the oven?
  8. May 15, 2017 at 3:13 PM
    #728
    StevoNB
    StevoNB Well-Known Member
    NB, Canada
    2020 DCSB TRD Sport 6MT
    It required a lot more force than I thought it would. Once you get it started it should just pull off, but if you take a bit too long the adhesive will start to harden. I had to reheat the first one I did, but after you get the first one done the other one will be a lot easier.
  9. May 15, 2017 at 3:17 PM
    #729
    mreen428
    Shmatty
    Queens, NY
    11 DCSB TRD Spt
    Yeah I put it back in the oven for 5 minutes and pried with my hands and that got he first one. Thanks
    StevoNB[QUOTED] likes this.
  10. May 16, 2017 at 9:31 AM
    #730
    mreen428
    Shmatty
    Queens, NY
    11 DCSB TRD Spt
    How long would you leave the clamps on the headlight to let it cure? Windoweld says 5 minutes. Stuff cures quick right. Just asking bc I'm using same clamps for both and I'm not very patient
  11. May 16, 2017 at 2:30 PM
    #731
    Itsaerokyo808
    Itsaerokyo808 Active Member
    Darin
    Oahu, Hawaii
    2015 BR Xrunner
    Djm 3/3 drop
    I'm looking to do this to my headlights but quick question
    Does removing the bowl adjustment screws pull the bowl to one side? For each screw?
    I just don't wanna mess up the alignment and have a hard time to fix in it aftwards
  12. May 16, 2017 at 3:48 PM
    #732
    StevoNB
    NB, Canada
    If you're just painting the bezel, you don't need to remove the reflector bowl. The bezel is attached to the lens with 2 small screws.
  13. May 16, 2017 at 5:57 PM
    #733
    Itsaerokyo808
    Darin
    Oahu, Hawaii
    2015 BR Xrunner
    Djm 3/3 drop
    I plan to paint the bowl black too. So I have to remove the 2 adjuster screws. Do you guys make some kind of mark on how far in or count how many turns to replace the screw afterwards?
  14. May 16, 2017 at 5:59 PM
    #734
    StevoNB
    NB, Canada
    You know you can't paint the reflector bowl and still use the factory headlight bulbs right?
  15. May 16, 2017 at 6:04 PM
    #735
    mreen428
    Shmatty
    Queens, NY
    11 DCSB TRD Spt
    Finished the mod today. Happy with results.
    Manfred, Sub-Zero and StevoNB like this.
  16. May 17, 2017 at 2:15 AM
    #736
    Itsaerokyo808
    Darin
    Oahu, Hawaii
    2015 BR Xrunner
    Djm 3/3 drop
    Forgot to mention I plan on doing an hid retrofit projector
  17. May 17, 2017 at 2:45 AM
    #737
    StevoNB
    NB, Canada
    Ok that makes sense then. Counting the threads on the adjustment screws will get you pretty close, but you'll have to do some fine tuning after reassembling and installing in the truck.
    Itsaerokyo808[QUOTED] likes this.
  18. May 24, 2017 at 11:22 AM
    #738
    Sub-Zero
    Sub-Zero NOOB
    Frederick, CO
    '06 DCSB
    None
    They are not difficult to adjust, park 20-30' from a garage or something and line them up how you want....or take a picture before you mess with them so you can put them back the same
  19. Jul 12, 2017 at 1:52 PM
    #739
    Vereor_Nox
    Vereor_Nox Fumblerooski
    North California
    2010 Tacoma TRD Sport
    Question, is the butyl rubber sealant the same stuff as sound deadener?
  20. Jul 12, 2017 at 9:08 PM
    #740
    outxider
    outxider Never stop exploring. Rest in Paradise Big Bro.
    Sang
    East Bay, CA
    06 DCSB 4x4
    A few mods here and there and counting....
    Negative. You can pick up Morimoto retro rubber in grey from Retrofitsource to reseal the headlights. I've used it and its very easy to work with once its warmed up.
    Bravisimo and Vereor_Nox[QUOTED] like this.
