How to build a shell hoist in the garage
Discussion in 'Tonneau Covers, Caps and Shells' started by nighthawk87, Jul 20, 2011.
  1. Jul 20, 2011 at 7:40 PM
    nighthawk87
    nighthawk87 [OP] Well-Known Member
    Anyone have any how to's? I'd like one that can be operated by one person.
  2. Jul 21, 2011 at 5:54 AM
    PSJ
    PSJ Prerunners Work
    Sebastian Inlet
    09 Access Cab Prerunner
    Rear Leaf spring TSB, Bilstein 5100's all around w/ front set at 1.75", 265/75R/16 Mickey Thompson Baja STZ's, Trailer hitch w/custom wiring, AFE drop in dry filter, Rear Diff breather mod, Debadged truck, customized stock TRD wheel center caps, added factory fog lights, bed mat, door sills, tinted windows
  3. Jul 21, 2011 at 6:07 AM
    macgyver
    macgyver Well-Known Member
    Brad
    Canton, GA
    '13 Tundra double cab SR5 4x4
  4. Jul 21, 2011 at 3:15 PM
    harleyg
    harleyg Landscape Photographer
    Harley
    2011 PreRunner AC 2.7 Leer 180
    That is a great idea. Cheap, easy and appears very functional.
  5. Jul 21, 2011 at 5:21 PM
    Mxpatriot
    Mxpatriot Well-Known Member
    '06 4x4 AP LT and Locked
    I built one for the Jeep. Put a 2x6 across the roof, lag bolted it into 3 studs for a total of 6 bolts. Put a big ole' eye bolt in the center of it. Used a hand crank, side handle winch bolted to the wall with a pull hooked to the eye bolt.
    Welded up a "T" frame with a hook on the bottom of the "T" and tie strap ends tied into the ends of the "T". The hook would go hook under the bottom of the top (window open) and the tie strap ends hooked onto the side edges.
    It worked fine, and one person could easily take the top off and on. We have since moved and I'm not going to put it up again because we're finally going to sell the Heep in a bit.
