How to buy an air compressor?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Gjr003, Jan 18, 2017.
  1. Jan 18, 2017 at 10:45 AM
    Gjr003
    Gjr003 [OP] Well-Known Member
    I read a ton on here an have not found what I was looking for.
    It seems to be mostly peoples preferences, and not really too much hard data. How do you buy an air compressor? I am a once a month off-roader and have always used a cheap compressor for $20 that takes 5 to 8 mins a tire depending on how much I air down.
    Looking to upgrade and reading a ton of threads and websites. Most said to go big like ARB, or cheap like an MV50. I have stock TRD Offroad tires, 265/70R16, is there any calculation you can do to figure out fill time or output of the equipment.
    Everyone seems to agree battery clamp 12V are the way to go, but for a $73 dollar MV50 vs a $300 ARB. I am gathering its 1 or 2 minutes a tire? Is that fair, its hard to spend that much money when its a nominal amount of time, I guess if you are doing it every day its a different story.
    Thanks!
    Spare Parts and monsterkx2fiddy like this.
  2. Jan 18, 2017 at 10:50 AM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    I would rather have a cylinder of air. CO2 is cheap.
    No moving parts and a can will last a long time. You can run air tools off it as well.
  3. Jan 18, 2017 at 10:54 AM
    c4lvinnn
    c4lvinnn Well-Known Member
    '17 TRD Off Road DCSB
    Depends on how you want to set it up. You'll need to look at duty cycle and tank size, line size, etc. When I had air-ride on one of my cars, I had dual Viair 400C compressors and a 5 gallon tank, as well as a quick disconnect for air tools.
  4. Jan 18, 2017 at 10:57 AM
    Gjr003
    That is what I am trying to get to, I just want to air up my stock tires in less than 4 minutes a tire. But I can't find a way to figure that out. I understand how it all works. Duty Cycles and what not, but I am not seeing the quantifying data to say. This $500 ARB is 1 minute, this $300 dollar is 2 minutes.
  5. Jan 18, 2017 at 11:00 AM
    c4lvinnn
    It doesn't work like that. That would be determined by if you have a big enough tank volume, then duty cycle of the compressor filling up said tank, then what your outlet pressure is set at, etc. If it was filled all the time and only kick on the compressors when it tripped the pressure switch, you can inflate a set of tires in a few minutes. I'm too lazy to figure out how much air volume is in a 265/70/16 tire then compare that to tank sizes, etc. But yeah, you'll need to do some math
  6. Jan 18, 2017 at 11:15 AM
    JoeCOVA
    JoeCOVA Well-Known Member
    Joe
    Colorado Springs
    Take a look at this, I think only the Kilby is incompatible.
    http://www.fourwheeler.com/how-to/154-1109-on-board-air-systems-compressor-confessor/
  7. Jan 18, 2017 at 11:18 AM
    jake72
    jake72 Well-Known Member
    Jake
    N.E. PA
    2019 trd off-road dcsb mt
    Viair 450p
    Diablo169, tacopromatt and musher like this.
  8. Jan 18, 2017 at 11:22 AM
    dumontrider
    dumontrider Well-Known Member
    La Habra, CA
    14 GX460
    I have a Viair 88p that Santa got me, used it for the 1st time this weekend. We had 3 rigs all air up from 20 to 34ish PSI, tire sizes were stock up to 33", nothing drastic. The 88p was less than 1 minute per tire, I was amazed at how this sub $100 pump was better than a commercial pump at the gas station! 15 minutes, 12 tires, 1 pump was impressive.
  9. Jan 18, 2017 at 11:33 AM
    jowybyo
    jowybyo Well-Known Member
    Joe
    Baltimore, MD
    '14 MGM DCSB Postrunner 4wd Conversion, Debadged
    Interesting. The data on Viair's website suggests it would take about 2-1/2 minutes to fill a 33" h tire from 15 - 30 psi with the 88P. Cool to know it probably outperforms that by quite a bit.
  10. Jan 18, 2017 at 11:42 AM
    T$$
    T$$ Well-Known Member
    2017 TRD OR MT
    I have this one as well. Can't beat it for the money. I heard it gets super hot but for one car, it's been fine for me.
    CusterFan likes this.
  11. Jan 18, 2017 at 11:43 AM
    Joe23
    Joe23 Canuckistikian
    The Great White North
    2017 TRD Off-road DCSB
    The ARB twin is a 100%duty cycle. Inflates a 33 in about 1 to 2 min depending how low you went.
    I'm biased as I have the ARB and love it. Came with my old TJ.
    For your limited use a viair clamp on would likely work fine.
    JoeCOVA likes this.
  12. Jan 18, 2017 at 11:53 AM
    dumontrider
    La Habra, CA
    14 GX460
    Lol yes it only took 1 session & I now know what/where not to touch :bananadead:
  13. Jan 18, 2017 at 11:55 AM
    moe2o4
    moe2o4 Well-Known Member
    Corey
    Pittsburgh PA
    2016 SR Silver 2.7L 5 Speed
    OME 3" Lift, 32" Tires, Lots of Mods!
    I'm running this under my hood! ARB CMKA12!
    Here is a little Video of it working:
    https://www.youtube.com/watch?v=_fwUFy9MOvc
    Final Mounted Pics:
    [​IMG][​IMG][​IMG][​IMG][​IMG][​IMG]
    Before the Install:
    [​IMG][​IMG]
    The bracket I made to mount the compressor and switch:
  14. Jan 18, 2017 at 12:00 PM
    geoyota760
    geoyota760 Allergic to pavement
    PHOENIX, AZ
    2019 TRD OR
    5.29 Nitros Bilstein ICON Kansei BFG
    Gradual progression for me...had a Viair 90 to start. We referred to it as "the socializer" because you stood around chatting while everyone else waited for you to finish airing up.
    Then I upgraded to the Viair 400p, which works well to this day (back up to my current CO2) but is inferior to CO2 IMO.
    Finally, bought a Powertank 10 lb. system and really love how quickly it airs up tires (under a minute going from 15-35 lbs), looks bada$$, and is very accurate with its liquid filled gauge.
  15. Jan 18, 2017 at 12:20 PM
    Gjr003
  16. Jan 18, 2017 at 4:08 PM
    Joe23
    I wish I could fit my twin compressor there.
    monsterkx2fiddy likes this.
  17. Jan 19, 2017 at 7:43 AM
    geoyota760
    PHOENIX, AZ
    2019 TRD OR
    CusterFan and Gjr003[QUOTED][OP] like this.
  18. Jan 19, 2017 at 7:48 AM
    Diablo169
    Diablo169 ROKRAPR
    Max
    Santa Cruz, CA
    99’ Bro-Coma’s Revenge 3RZ 345k+
    Stock
  19. Jan 19, 2017 at 7:52 AM
    ramonortiz55
    ramonortiz55 Not A Well-Known Member
    Ramon
    Texas
    2015 DCSB Offroad 4x4
    stock
    I like this.
    is that the "arb pump up kit" that you are using? - Hose, fittings, chuck, etc.
    moe2o4[QUOTED] likes this.
  20. Jan 19, 2017 at 7:53 AM
    Harry
    Harry Science, Bitches
    Santa Fe NM
    15 TRD Off Road DCSB
    I have a CO2 tank if I need to air up in a hurry. Eventually I will probably go with the ViAir constant duty kit.
    But since I have 120VAC in the bed I have been running a Harbor Freight hot-dog compressor for airing up. So far so good - It's slow but gets the job done - hasn't overheated yet. :bananadead: For $40 I don't expect much and when it blows up I'll just repurpose the tank.
    PottMatter, geoyota760 and Diablo169 like this.
