How to buy an air compressor?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Gjr003, Jan 18, 2017.
  1. Jan 19, 2017 at 7:58 AM
    moe2o4
    moe2o4 Well-Known Member
    Corey
    Pittsburgh PA
    2016 SR Silver 2.7L 5 Speed
    OME 3" Lift, 32" Tires, Lots of Mods!
    Yes it is Ramon, it's the ARB Pump Kit!
  2. Jan 19, 2017 at 8:50 AM
    CusterFan
    CusterFan Well-Known Member
    Southeastern Illinois
    Silver Sky 2019 Tacoma SR, AC, 4X2, 2.7
    https://www.amazon.com/Viair-00088-88P-Portable-Compressor/dp/B005ASY23I
    I will 2nd that. These are nice little pumps. I bought this one instead of the plug in cigarette lighter type. I also bought the heavy duty tool bag below to put it in. (Wished I would of got a camo one)
    https://www.amazon.com/Rothco-Mecha...rd_wg=3u35Z&psc=1&refRID=G4MJ2RMRGZT05EPRMBMX
    geoyota760 and Gjr003[OP] like this.
  3. Jan 19, 2017 at 9:06 AM
    Spare Parts
    Spare Parts Well-Known Member
    Southern Maine
    2022 Off Road Premium 4Runner Lunar Rock
    are the 24 volt clamp ones better than the cig lighter ones? More power?
    Edit 12 volt.
    geoyota760 likes this.
  4. Jan 19, 2017 at 9:57 AM
    CusterFan
    I bought the clamp on because I was concerned I may blow fuses with the cigarette lighter plug in.
    geoyota760 and shakerhood like this.
  5. Jan 19, 2017 at 10:10 AM
    TBV
    TBV Well-Known Member
    Oakland CA
    2017 TRDOR 6MT
    For TRD Bros™ is there any advantage to running a comp off the 120V outlet as opposed to a cig lighter or battery?
  6. Jan 19, 2017 at 10:18 AM
    0210
    0210 Well-Known Member
    Vancouver, BC
    2016 TRD Sport Upgrade DCLB
    Viair 400P-RV kit.
    Cut the power wire to add a quick-disconnect connector. Added the same connector to the original clip-on wire, as well as a permanently-connected hard-wire. Allows the compressor to be hardwired day-to-day, but to be easily removable and used on another vehicle/application with the original clip-on wire.
    Then build a long, narrow box that will sit on top of the wheel protrusion in the bed, and throw the Viair (along w/ other goodies) inside for instant access whenever you want it, and no connectors to fiddle around with.
    More details in build thread (link in sig).
  7. Jan 19, 2017 at 12:37 PM
    DES2009
    DES2009 Minister of Truth
    Southeast Louisiana
    2017 MGM Limited
    I'm a Millionaire! One Million Posts!!
    That outlet is only 400 watts (assuming it's the same as the one on the Limited). The outlet is probably only good for running a stereo or a light.. pretty much useless for any kind of power tool I'd think.
  8. Jan 19, 2017 at 1:16 PM
    BCJake
    BCJake Well-Known Member
    BC
    2016 Tacoma TRD OR AC MT QS
    -5100's all four corners, fronts set at 0 -888 OME coils, SPC UCA's, Deaver AAL -Driver's sidefront spacer -SCS 16" Ray10's in Matte Dark Bronze -255/85/16 Toyo MT's -Avid Off-Road weld on sliders -RCI Front Skid -SSO Slimline Hybrid front bumper, Smittybilt X20 Winch -Flipster V2 front plate bracket -FabFours Premium rear bumper -Front diff needle bearing delete, ECGS bushing in -Plasti dipped front grille -G-Tek Fab door sill guards -CaliRaised 2X2 Ditch Lights -ARB CKMA12 Compressor & Slee OffRoad Mounting Bracket -Shapeways 2 Switch Plate
    moe2o4[QUOTED] likes this.
  9. Jan 19, 2017 at 2:24 PM
    moe2o4
    Corey
    Pittsburgh PA
  10. Jan 19, 2017 at 2:29 PM
    ramonortiz55
    ramonortiz55 Not A Well-Known Member
    Ramon
    Texas
    2015 DCSB Offroad 4x4
    stock
    303tacoma and moe2o4[QUOTED] like this.
  11. Jan 19, 2017 at 2:35 PM
    Z50king
    Z50king DCLBOR4X4FTW
    Eric
    Southern California
    2016 DCLB Off Road 4x4 Super White
    Stock and loving it
    they are 12 volt. When connected to a running truck battery, they receive 13.8 to 14.3 volts
    no. you will lose much power through the inverter.
  12. Jan 19, 2017 at 3:20 PM
    TBV
    Oakland CA
    2017 TRDOR 6MT
    Makes sense, thanks
    shakerhood likes this.
  13. Jan 19, 2017 at 5:08 PM
    Spare Parts
    Southern Maine
    Oops, ya 12 volt. So basicly the compressor gets more power off the battery versus the cig lighter?
  14. Jan 19, 2017 at 5:52 PM
    Exracer2
    Exracer2 Well-Known Member
    Colchester Ontario
    2017 TRD Off-Road Alpine White ACLB
    BRO grille, KICKER speakers, Key amp, Hideaway sub
    120v 400w = 3.3a.
    I had a 2000w inverter on my old truck which works out to 16+amps. If needed it can run anything you would at home. Had it set up with HD elec forklift quick connects direct to the battery. Pop hood, connect and run whatever I needed. Also had my booster cables set up to use those quick connects for a solid connection when needed.
  15. Jan 19, 2017 at 5:56 PM
    #35
    Diablo169
    Diablo169 ROKRAPR
    Max
    Santa Cruz, CA
    99’ Bro-Coma’s Revenge 3RZ 345k+
    Stock
    You want to run the pump straight off the battery. Most cig ports are good for 10-15amps. Any pump worth buying/ using is going to pop the cig fuse.
    Here is a guide when wiring, pump should list maximum draw.
    geoyota760 and Spare Parts like this.
  16. Jan 20, 2017 at 9:00 AM
    #36
    geoyota760
    geoyota760 Allergic to pavement
    PHOENIX, AZ
    2019 TRD OR
    5.29 Nitros Bilstein ICON Kansei BFG
    Yes. :thumbsup:
    Spare Parts[QUOTED] likes this.
  17. Jan 20, 2017 at 2:18 PM
    #37
    Z50king
    Eric
    Southern California
    Stock and loving it
    the cigarette lighter usually has a 15 amp fuse in line with it. The battery plugs have their own fuse rated to what the pump is designed to draw.
  18. Jan 20, 2017 at 2:23 PM
    #38
    0210
    Vancouver, BC
    For what it's worth, my VIAIR 400p is rated at 30amp draw and has a 40amp inline fuse. Definitely no-go for a cigarette lighter.
    Spare Parts likes this.
  19. Jan 20, 2017 at 2:31 PM
    #39
    nevadabugle
    nevadabugle Desert Rat
    Elko, NV
    2016 DCSB TRDOR manual in quicksand
  20. Jan 20, 2017 at 2:38 PM
    #40
    Spare Parts
    Southern Maine
    Thanks, this is the info I was wondering about. I would have never thought about this, thanks TW for the info.
    0210[QUOTED] likes this.
