How to calculate payload?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by aboyz, Jan 21, 2021.
  1. Jan 23, 2021 at 7:07 AM
    #61
    frenchee
    frenchee Favorite Member
    Oceanside CA Area
    2003 Tacoma TRD Double Cab 4x4
    Converted to 4WD DD VW MK6 TDI
    Nice rig!!!
    stealthmode[QUOTED] likes this.
  2. Jan 23, 2021 at 7:21 AM
    #62
    melikeymy beer
    melikeymy beer Hold my beer and watch this
    2019 Tundra
    @hiPSI is correct, fuel is not counted against payload. I have a 38 gal tank and 1185 lbs. of payload. If I reduced my payload for the weight of the fuel I couldn't haul my pomeranian in my Tundra. And yes, I have weighed it empty and loaded.
  3. Jan 23, 2021 at 7:25 AM
    #63
    RX1cobra
    RX1cobra Well-Known Member
    19 OR
    I took his response was as fuel does go against payload. Maybe I took it wrong but I don't think fuel goes against payload.
  4. Jan 23, 2021 at 7:32 AM
    #64
    melikeymy beer
    2019 Tundra
    Payload is calculated with a full tank of fuel.
    From a quick Google search:
    Payload is stated on the door sticker and includes everything your vehicle left the factory with, and a full tank of fuel. Anything beyond that, including a driver or accessories must be deducted from payload.Jul 27, 2015
    specter208, abodyjoe and OrangeRa1n like this.
  5. Jan 23, 2021 at 7:32 AM
    #65
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    However it leaves the plant and any additional port mods.
    However... different manufacturers do it different ways. Remember, a "payload" number is whatever number the manufacturer is willing to accept liability to handle. It's a combination of "real" numbers from engineering and "legal" numbers from the lawyers. For example, when a manufacturer buys trucks to convert into wreckers or motorhomes, they change the payload numbers because they accept the liability for those numbers.
  6. Jan 23, 2021 at 8:05 AM
    #66
    melikeymy beer
    2019 Tundra
    Pretty sure all US light trucks adhere to industry standard J2807 now for determining payload?
  7. Jan 23, 2021 at 8:32 AM
    #67
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    Understood and agree, but those are minimum to pass test. For example, several times I exceeded rated payload in my Tacoma and it did fine. My point is the payload numbers are numbers the manufacturer will guarantee. The aftermarket guys put a service or wrecker bed on it and legally change the payload to numbers they guarantee.
  8. Jan 23, 2021 at 9:09 AM
    #68
    calebc
    calebc Well-Known Member
    Keep googling and you’ll find many different answers. The correct answer is each mfg (and even model) is different. Sometimes the manual states exactly what’s included, sometimes it doesn’t. The one true way to really know your payload is to go get on a scale.
  9. Jan 23, 2021 at 9:58 AM
    #69
    OrangeRa1n
    OrangeRa1n Well-Known Member
    Houston Area
    TRD-Offroad 2021
    I agree with this. While you shouldn't go over the ratings, they are set by the manufacturer and have some margin for error (payload capacities differ between the same vehicles in different countries). Additionally, there's more to it than one number. The amount of weight over each axle also matters (this is why 5th wheels and goosenecks exist). The weight distribution hitch DOES weigh something, but at the same time moves some of the weight to the truck's front axle. Because of this, I usually leave them out of the payload calculation. If you go slow with a trailer brake, you should be fine, however, after using this setup for awhile you might realize you want to upgrade. Just my $0.02. While the Tacoma is a small pickup, 4,000lbs is not extreme and I frequently see them tow similar setups on the interstate.
    That aside, I also agree with the users that have suggested weighing the trailer and tongue weight of the loaded trailer. It's good to know what you are dealing with.
  10. Jan 23, 2021 at 10:57 AM
    #70
    melikeymy beer
    2019 Tundra
    After reviewing the J2807 standard it appears I was mistaken (and confused). The standard seems to only apply to GCWR for towing. At any rate, I've weighed my Tundra and I'm confident that fuel is not deducted from payload. I think the calculations in the manual also confirm this.
    specter208 and hiPSI[QUOTED] like this.
  11. Jan 23, 2021 at 12:04 PM
    #71
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    And... it's a minimum standard! How are those old dumbass assholes at Tundraworld?
  12. Jan 23, 2021 at 12:10 PM
    #72
    melikeymy beer
    2019 Tundra
    Lol, still whining about missing transmission coolers.
    hiPSI[QUOTED] likes this.
  13. Jan 23, 2021 at 12:43 PM
    #73
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    They are some needy bastards. I have never went back. I think average age over there is 83 yo. Surprised they can use the internet.
  14. Jan 23, 2021 at 11:56 PM
    #74
    aboyz
    aboyz [OP] Well-Known Member
    Can someone tell me what is the height of the hitch from the ground to the hitch? I can't find that anywhere.. thank you..
    2020 Tacoma TRD Sport 4x4.
  15. Jan 24, 2021 at 1:01 AM
    #75
    abodyjoe
    abodyjoe Well-Known Member
    joe
    2017 Tacoma double cab TRD Offroad. quicksand in color
    you can't measure it?
    Chew and hiPSI like this.
  16. Jan 24, 2021 at 9:48 AM
    #76
    aboyz
    i can.. :) but its raining outside. hahahaah thx
    abodyjoe likes this.
  17. Jan 24, 2021 at 7:20 PM
    #77
    aboyz
    measured it.. it is 19 1/2in. if anyone needed this info. measured from the ground to the top end of the hitch..
  18. Jan 25, 2021 at 7:03 PM
    #78
    frenchee
    Oceanside CA Area
  19. Jan 25, 2021 at 10:10 PM
    #79
    aboyz
  20. Jan 29, 2021 at 4:17 PM
    #80
    a2lowvw
    a2lowvw Well-Known Member
    Justin
    Bothell, Wa
    2019 DCSB Limited
    Stuff and things
    Just for giggles and shits I put my Tacoma on a set of scales we use for corner balancing at work. It looks like with a family of 4 I can haul a wet fart.
    Edit. This was with a full tank of fuel and 60ish pounds of Goodwill stuff in the bed.
