How to calculate payload?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by aboyz, Jan 21, 2021.
  1. Feb 25, 2021 at 8:33 AM
    #101
    Knute
    Knute Well-Known Member
    '06 4.0L Tacoma TRD Sport
    Stock, 4WD, Access Cab, White,
    The "driver" is figured at 150 lbs.
    Full tank is included.
    Not in the Cargo number.
    Typically in the "unloaded weight" number.
    specter208 likes this.
  2. Feb 25, 2021 at 8:34 AM
    #102
    calebc
    calebc Well-Known Member
    100% does not include driver. As was mentioned after my post, some trucks include fuel in their rating, some do not. You would need to verify in the manual if that's the case with the Tacoma.
  3. Feb 25, 2021 at 9:02 AM
    #103
    specter208
    specter208 Well-Known Member
    California
    2017 TRD SPORT ACLB w/ 6MT TRUCK WHITE
    TOYOTA OEM: Cast Aluminum Running Boards Mud Guards Bed Mat All-Weather Floor Liner NIssan Frontier Sliding Bed Extender
    150-175lbs. My particular truck is listed on Toyota’s website as having 1275lbs of payload standard. The actual owners manual and door jamb sticker says 1100lbs.
  4. Feb 25, 2021 at 9:18 AM
    #104
    Chew
    Chew Not so well known user
    Chewy
    Midwest
    19 TRD OR
    Amazon dog poo bed mat mod
    regardless of whether it does or doesn't include driver and fuel, isn't it fair to say; if a 150lbs guy and topping off the tank puts you over the limit,,,, well then you were already waaayyyy too heavy to begin with? I mean, if someone needs to use the bathroom to get over the scales,,,,,
    hiPSI, Knute and calebc like this.
  5. Feb 25, 2021 at 9:42 AM
    #105
    a2lowvw
    a2lowvw Well-Known Member
    Justin
    Bothell, Wa
    2019 DCSB Limited
    Stuff and things
    If you want to know the actual payload of your truck as it sits, you have to weigh it.
  6. Feb 25, 2021 at 9:52 AM
    #106
    abodyjoe
    abodyjoe Well-Known Member
    joe
    2017 Tacoma double cab TRD Offroad. quicksand in color
    That weight difference could be anything. Floor mats, bed liner, leather int, sunroof or any other number of things.
  7. Feb 25, 2021 at 10:11 AM
    #107
    Knute
    The advertised cargo capacity will be based on the lightest weight truck in the model line. Its MARKETING.
    Your actual CC will be the GVWR - actual weight. Every mod will change your weight. Go to a CAT scale with full tank, all mods and you otherwise truck empty, then subtract this weight from the GVWR. Now, you have your exact CC for your truck and your mods.
    Chew likes this.
  8. Feb 25, 2021 at 11:33 AM
    #108
    Chew
    Chewy
    Midwest
    19 TRD OR
    Great suggestion!
    My buddy weighed his combo to adjust the weight distribution hitch and load, as he wanted to do it right. Well, this was first trailer, so he drove it around a little to get used to it and to make sure nothing needed fixed before their big trip out West last year. The day before they were set to leave, he was just being curious and weighed it again, I can't remember the number,,, but he went home and had momma unpack, rethink, and then repack. Initially she threw everything and anything in the trailer while my buddy was at work, not even understanding how much weight she packed in there. Point being, most don't realize how quickly the the weight adds up.
  9. Feb 25, 2021 at 11:35 AM
    #109
    Steadfast
    Steadfast Well-Known Member
    Thane
    S.W. Ontario Canada
    2013 Limited
    What is everyone experiencing when you go over the GVWR? Does it happen when you are 100 lbs over? 500 lbs over or 1000 lbs over? What happens... or what do you think will happen?
  10. Feb 25, 2021 at 11:45 AM
    #110
    crazysccrmd
    crazysccrmd Well-Known Member
    Alaska
    Aprilia Tuareg 660
    I drove 3000 miles across Alaska, Canada and half the US with my 2011 in excess of 1000lbs over GVWR and towing a 3500lb trailer without a single problem. The truck with a full tank of gas and pretty much nothing in it weighed 5220lbs so its daily driven weight for several years was just about the GVWR.
    Edit: After that I bought a bigger truck until I didn't need to tow/haul as much. Now I have an Audi SUV that funnily enough has a higher payload and tow rating than the Tacoma does.
    Steadfast[QUOTED] likes this.
  11. Feb 25, 2021 at 11:50 AM
    #111
    Steadfast
    Thane
    S.W. Ontario Canada
    2013 Limited
    Don't get me wrong crazysccrmd. I'm not in the least bit concerned. It just seems to be a hot topic on here on more than one occasion.
  12. Feb 25, 2021 at 12:08 PM
    #112
    Gearheadesw
    Gearheadesw must modify
    Davenport Fl
    1 truck 1 car 1 motorcycle
    It’s that one accident in front of you. 99% of the times it’s not a problem. But that one time you need to stop short to keep from hitting that school bus......
    abodyjoe likes this.
  13. Feb 25, 2021 at 12:29 PM
    #113
    Steadfast
    Thane
    S.W. Ontario Canada
    2013 Limited
    Ok, so you're saying if you're hauling or towing heavy, you should leave more room in front for longer stopping distances. Isn't this what the big trucks do too?
    This doesn't answer my original question.
  14. Feb 25, 2021 at 12:31 PM
    #114
    Gearheadesw
    Davenport Fl
    It does, an overloaded truck is a danger to all on the road, the numbers don’t lie
    Chew likes this.
  15. Feb 25, 2021 at 12:45 PM
    #115
    Steadfast
    Thane
    S.W. Ontario Canada
    2013 Limited
    What numbers are you referring to that don't lie?
  16. Feb 25, 2021 at 12:46 PM
    #116
    crazysccrmd
    Alaska
    Aprilia Tuareg 660
    You could argue that if the GVWR is 5600lbs and the max unbraked trailer weight is 1000lbs then the truck is essentially rated to stop and control up to 6600lbs. In fact it's probably safer stopping that weight with it all on the truck and not behind it swinging around.
  17. Feb 25, 2021 at 1:01 PM
    #117
    Steadfast
    Thane
    S.W. Ontario Canada
    2013 Limited
    Around here the maximum unbraked trailer weight is 3000 lbs. Even with that, unless the roads are slippy, braking is not a problem if you just don't go too fast and leave more room. Common sense does play a role in towing with truck. Other then road handling, which experience will play a part in, are there any expected, problems with the truck? For example, is the truck going to break in half or break an axle?
  18. Feb 25, 2021 at 2:10 PM
    #118
    specter208
    California
    Toyota’s site has different curb weights for each different trim and cab configuration.
