How to carry long materials? (16 feet long)
Discussion in '2nd Gen. Tacomas (2005-2015)' started by furiousbob, May 14, 2019.
  1. May 15, 2019 at 6:16 AM
    #41
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    I hauled a 32' tower the weight wasn't there just the length I fastened a hitch arrangement to the front and a small two wheel trailer to the back. Not something I would recommend but I got away with followed me up the mountain access road too (I use the word road for lack of any thing better it wasn't much). I vote for the rented trailer.
  2. May 15, 2019 at 6:18 AM
    #42
    fatfurious2
    David
    Ashburn, VA
    2010 TRD OR Access Cab
    Dont think Prinsu makes anything for Regular cabs :ballchain:
    Nunya Bizness likes this.
  3. May 15, 2019 at 6:18 AM
    #43
    pabstsmeared
    pabstsmeared Simulated Weight
    Tappahannock, Va
    '13 Super White DCSB TX Baja
    Mud Tars & Shit
    Correction: Nothing looks cooler than the AMC Matador.
  4. May 15, 2019 at 7:16 AM
    #44
    Wattapunk
    Wattapunk Stay lifted my friends !
    Uncle K
    TX
    2005 DCLB 4WD
    Personally, it would be cheaper and safer to rent a 17ft Uhaul truck versus a trailer. Much easier and faster to load/haul and avoid the wear and tear on the truck.
  5. May 15, 2019 at 7:18 AM
    #45
    stickyTaco
    stickyTaco Fuck Cancer
    Zack
    Reno/Tahoe
    '12 DCSB TRD-OR
    Fox/Dakar with Relentless goodies and stuff
    Just cut the metal tube in half and JB weld it back together.
    fatfurious2 likes this.
  6. May 15, 2019 at 7:25 AM
    #46
    henryp
    henryp Well-Known Member
    Henry
    Montana
    '17 GX 460 and '09 Boosted Taco
    Form follows function
    My way. Not cheap or helpful to OP
  7. May 15, 2019 at 7:49 AM
    #47
    Suplex
    Suplex Unknown Member
    Shane
    California
    ‘15 Prerunner TRD Sport v6 DCLB
    Why not lean it up on the cab and tailgate, and strap it on all four corners of the bed? Or better yet get one utility ladder rack in front. You can get a set of racks cheap on amazon, or get the Tacoma fitted one like in the picture. It’s more expensive but can easily bolt in and out.
  8. May 15, 2019 at 8:04 AM
    #48
    Nunya Bizness
  9. May 15, 2019 at 8:11 AM
    #49
    MPA2point0
    MPA2point0 Well-Known Member
    Evan
    Havertown, PA
    2015 Super White DCLB Trd Sport
    Well done sir.
  10. May 15, 2019 at 8:12 AM
    #50
    Nunya Bizness
    Correction...
    This is the worst ever...
  11. May 15, 2019 at 8:20 AM
    #51
    Nunya Bizness
    Nah...
    Dis
  12. May 15, 2019 at 8:23 AM
    #52
    Nunya Bizness
    ^^^You're right you know^^^
  13. May 15, 2019 at 8:29 AM
    #53
    DETaco17
    DETaco17 Retired
    2023 MGM Tacoma OR DCSB
    Not too much
    Looks like its Friday on a Wednesday all over again.
    Nunya Bizness[QUOTED] likes this.
  14. May 15, 2019 at 8:30 AM
    #54
    Nunya Bizness
    Hi mark :wave:
  15. May 15, 2019 at 8:31 AM
    #55
    Blue Truck
    Blue Truck Well-Known Member
  16. May 15, 2019 at 8:31 AM
    #56
    DETaco17
    DETaco17 Retired
    Not too much
    :hattip:
  17. May 15, 2019 at 9:12 AM
    #57
    MPA2point0
    Evan
    Havertown, PA
    Riiiiight. You should probably look up what triggered means bud.
  18. May 15, 2019 at 10:46 AM
    #58
    Pugzly29
    Pugzly29 Member
    So depending on the weight of the tube hang it on the passenger side of your truck. Use the bed cleats in the bed with straps. up front couple options, depending on weight and distance, (open driver door first) wrap a tie down over top and through cab, and hook another strap to pipe and tie down. you could hook one the pipe and the driver side wheel well. depending on weight. make sure to pad the pipe so you don't scratch your truck. you can hook to your Oh Shit handle as well. depending on the size and weight of pipe use your mirrors arm as support. don't put much weight on this. but depending on you truck set up 2-3 straps hooking it to the bed, 1-3 straps to cab 1-2 across the hood.
    now it would be just as easy to go rent a car hauling trailer from U-haul, but if you are more of a "Honey hold my beer and watch this" (like i am) redneck engineer the shit out of it:transformer:
