HOW TO CHANGE A FUEL FILTER.
Discussion in '1st Gen. Tacomas (1995-2004)' started by 96 Tacoma, Oct 6, 2010.
  1. Oct 6, 2010 at 4:37 PM
    96 Tacoma
    96 Tacoma [OP] New Member
    Los Angeles, Ca
    96 Tacoma
    Hey guys, I have a 96, 4 cyl Tacoma and need help changing my fuel filter. any videos or tips on how to do it? Thanks in advance.
  2. Oct 6, 2010 at 4:38 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Its best to go thru the driver side wheel well. Its under the intake manifold. Kind of a pita to get to, but not hard if you take time.
  3. Oct 6, 2010 at 4:49 PM
    magikbean562
    magikbean562 once flirted with danger, danger got clingy
    greg
    socal
    pinto
    33" mudders
    its best to remove driver side wheel. like chris said, its a PITA.
  4. Oct 6, 2010 at 5:41 PM
    crazyasu45
    crazyasu45 Well-Known Member
    Canada
    2013 MGM DCLB 4X4 TRD SPORT
    3" SUSPENSION LIFT
    depressurize the fuel system...remove the gas cap...pull the EFI fuse or disconnect the fuel pump...
  5. Oct 7, 2010 at 2:20 AM
    Wreckless_71
    Wreckless_71 WRECKLESS for Life...
    Justin
    Pullman, WA.
    98 ext cab Tacoma
    3" Lift via OME 881's, Bilstein 5100's, Dakar OME 3" leaf packs, MBRP custom exhaust, HID headlights, CB, Canopy, aluminum wheels, upgraded sound system, full set of studded snow tires and wheels, auxilary lighting, more to come.
    Be re-born as a small Asian engineer/mechanic..... I'm 6'2" and 235 lbs. My arms don't bend in the correct direction and I wrench on a lot of shit. Remove the drivers side wheel and practice your contortionist moves. There are the banjo style bolts on either side and there is a "band" that bolts it to the underside of the manifold. It was a real bearcat but I got the bugger. Don't think mine had ever been replaced until I did it at 200,000 miles.
  6. Oct 7, 2010 at 8:05 AM
    RideFast
    RideFast on the flats.
    Jesse
    Albuquerque New Mexico
    Tacoma
    and have an extra hand if you can!
    Only buy a Toyota genuine fuel filter!!! I don't know why but I was told buy a Lexus Mechanic that had been working on Toyota/Lexus cars for many years not to skimp on this.
    I bought one for my 2.7 and they are just a few bucks more than pep boys.
  7. Oct 7, 2010 at 2:29 PM
    ScootsOFP
    ScootsOFP Well-Known Member
    Scoot
    Wisconsin
    03 PreRunner SR5/TRD
    deckplate, white LED gauges, fog light mod (Beau02 write up), Scion t1814 head unit
  8. Oct 7, 2010 at 2:33 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
  9. Oct 7, 2010 at 2:40 PM
    da0023
    da0023 The One, The Only
    Drew
    Alabama
    99 PreRunner SR5
    none
    drinking a 6 pack before hand isn't a bad idea either, helps take the edge off. like other members have already said, take off the front drivers side wheel, remove fuel cap. put on your slinky fingers, be patient and try not to say to many wordie dirties. I performed this no less than 6 months ago, if I can do it anyone can
