How to change brake pad?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by pinktaco808, Aug 8, 2010.
  1. Aug 8, 2010 at 10:03 PM
    pinktaco808
    pinktaco808 [OP] Hot Steppa
    can someone do a write-up on how to change your brake pad thank you mine is a 2006 standard cab. i just wanna change the break pads my self and save some money.
  2. Aug 8, 2010 at 11:04 PM
    06aztaco
    06aztaco Screw you guys, I'm going home.
    Cole
    Phx AZ
    06 Prerunner 2.7
    did you try searching? I know for a fact it is on here, i just saw it without looking for it.
  3. Aug 8, 2010 at 11:05 PM
    Viet2100
    Viet2100 Well-Known Member
    Viet
    South Florida
    2016 Prius 4T
  4. Aug 8, 2010 at 11:05 PM
    06aztaco
    Cole
    Phx AZ
    06 Prerunner 2.7
  5. Aug 9, 2010 at 6:41 AM
    pinktaco808
    ooo nicee thanks
  6. Aug 21, 2010 at 9:06 AM
    Kelson
    Kelson Well-Known Member
    Kelson
    Honolulu, Hawaii
    08 5-Lug Reg. Cab SR5
    SR5 Exterior/Interior (Color matched Front Bumper, Chrome Grille Surround and Chrome Rear Bumper/Silver Scoshe Dash Kit, A/C Bezel, A/C Vent Surround) LED license plate and white interior lights, Wet Okole Seat Covers, iPad in-Dash, JL CL-RLC, JL 13TW5 sub, JL 500/1 Slash V1 amp, JL XR 6.5 Components, Rockford Fosgate 6X9s in Boxes Front XRunner Coils, DJM Control Arms and Rear 4X4 Leafs, Custom 2" Angled Streetacos.com Blocks Front XR Bilstien Struts and Rear XR Bilstien Shocks, CravenSpeen Antennae, RX-8 Rims w/ Fronts:235/40-R18 Sumitomo HTR Rears:245/40-R18 Goodyear Eagle GT, 35% Tint front windows, OEM Sliding Privacy Glass w/ 5% Ceramic Tint, Flowmaster Super 44 dumped before the axle, URD Short Throw Shifter, Door Sill Protectors, Door Edge Guards, OEM Sport Pedals,The Retrofit Source Morimoto Mini D2S Stage III 35W 5K HID Headlights, OEM Fog Lights w/ piss yellow bulbs, OEM Cruise Control, Porsche 944 Bucket Seats, BeefedTaco Skid Plate, Whale
    fyi those are 6 lug brakes our 5 lug ones are single piston and a bit different. i haven't actually changed out the brake pads but when i djm'd the truck i had to take the caliper off of the rotor and it's a bit different from the writeup....
  7. Aug 21, 2010 at 7:07 PM
    pinktaco808
    someone please post a better write up with pics??? also what about re surfacing rotor when do you have to do that??
  8. Aug 21, 2010 at 7:45 PM
    raycie
    raycie Well-Known Member
    Oahu, HI
    2013 DCLB / 2016 4R Trail
    In need of $$$
    I just changed out my pads and turned my rotors.. I turned my rotors because I had some vibes when braking going down hills..
  9. Aug 21, 2010 at 7:48 PM
    pinktaco808
    ok we need pic and a better writeup
  10. Aug 21, 2010 at 8:02 PM
    raycie
    Oahu, HI
    In need of $$$
    Was just looking around because I don't know what the 5 lug brake caliper looks like. Funny enough, when I bought my pads a checkers they gave me the 5 lug pads rather than the 6 lug ones (yes they are different).
    Just popped on a x-runner site, and if the picture of the caliper is correct, looks like my wife's civic. In that case..
    1. jack up the truck
    2. jack stands
    3. on the back of the brake caliper there will be 2 bolts than are obviously holding the caliper cover on.
    4. take off the bottom of the 2 bolts and the caliper cover will hinge upward.
    5. the brake pads are just sitting in some clips. They should pretty much come right out.
    6. take the pads and the top and bottom clip out, clean the clips.
    7. push the brake calipers back in (plenty do it this way and do not bleed the system) * at your own risk
    8. put the clips back in and put the new pads in.
    9. replace bolt
    Of course if you want to turn or replace the rotors there is a couple extra steps but faily simple..
  11. Aug 22, 2010 at 12:51 PM
    pinktaco808
    pics make it easier
    also you dont have to bleed the system after??? also what if you want to make the brake closer or pedal more tighter meaning you can adjust when the pad grab
  12. Nov 7, 2011 at 2:48 PM
    pinktaco808
  13. Nov 7, 2011 at 5:42 PM
    Bosmob
    Bosmob Well-Known Member
    Kevin
    San Diego, CA
    '11 Access Cab SR5 I4 4AT
    Fat Bob's 2.75" front spacers Magnaflow Muffler Doug Thorley Header ImMrYo Mirror Bracket
    WTF?!
    Bump after a full year?:confused:
  14. Nov 7, 2011 at 5:47 PM
    SOSHeloPilot
    SOSHeloPilot My 1st Muscle Car
    S.E USA & S.E. Asia too
    2024 4Runner SR5
    Missing My Last Tacoma --- Had 11 Toyota trucks in the past and many other Toyota cars too.
    Sub'd
  15. Nov 7, 2011 at 5:54 PM
    Bosmob
    Kevin
    San Diego, CA
    Alright... if you still have not solved this problem here's some insight.
    You don't have to bleed the brakes after a pad change because air was never introduced into the braking system. Just think about what you're removing when you do a brake job.
    Also, you cannot adjust a brake pedal to increase pedal feel or when the pad grabs.
